Master Vector Analysis with Expert Help: Proven Solutions to Common Problems
The discussion revolves around vector analysis, specifically focusing on the properties of vectors in relation to planes and coordinate transformations. The original poster presents multiple problems involving normal vectors, projections, and coordinate systems.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the definition of "normal" vectors and their relationship to planes. Questions arise about the inner product of vectors, the meaning of projections, and how to express vectors in new coordinate systems. There is also discussion about the implications of the equations provided and the relationships between different vector components.
Participants are actively engaging with the problems, asking clarifying questions and providing hints to each other. Some guidance has been offered regarding the projection of vectors and the conditions for orthogonality in the context of coordinate transformations. However, there is no explicit consensus on the solutions to the problems presented.
There is a noted lack of specific information regarding constants in the equations, particularly the value of D in the plane equation. Participants are also navigating the constraints of homework expectations, with some expressing frustration over their understanding of the problems.
R3DH34RT
Need help on vector analysis :(
Guys, I need ur help please... Can u help me to answer these problems? I'm very confused...
1. Show that the vector Ai + Bj + Ck is normal to the plane which equation is Ax + By + Cz = D, where A, B, C, D are constants
2. n = 0.5i + 0.5j + 0.7071k is the unit-normal for plane A. b = 4i + 5j + 2k, c = 2i + 3j + k. Calculate the area of parallelogram project from b x c to plane A. Calculate components of vectors b and c that are parallel to plane A.
3. New right hand coordinate axes are chosen at the same origin with e1' = (2e1 + 2e2 + e3)/3 and e2' = (e1 - e2) x 1.4. Express e3' in term of e1. If t = 10e1 + 10e2 - 20e3, express t in terms of the new basis ek'. Express the old coordinate xi in term of xk' , xi = f(xk')
Please help me guys... :( Thanks a lot...
What are the relevant equations? How do you define "normal"? What is a projection? How do you define "parallel"?
normal is perpendicular to the plane
What do you know about the inner product of two perpendicular vectors?
The inner product of 2 perpendicular vector is zero, right?
But, is there any relationship? :(
Do you have anymore information about D? What do you know about equations of a plane?
No, I don't have more information about D.
I think that's already the equation of a plane?
Thanks.
Let \boldsymbol x_0 = (x_0, y_0, z_0) be some specific point on the plane. Let \boldsymbol x = (x, y, z) be any point on the plane. Can you write equations that describe the points \boldsymbol x_0 and \boldsymbol x? What is the inner product of the vector from \boldsymbol x_0 to \boldsymbol x with the vector \boldsymbol n = (A,B,C)?
D is just a constant.
The equation of a plane is should be the normal of the vector, right?
Do you mean (x-x0)/x + (y-y0)/y + (z-z0)/z = 0?
The inner product should be zero, right?
No. Where did you get the division?
Yes, but this is what you need to prove.
Expanding on my previous post:
Because both \boldsymbol x_0 and \boldsymbol x are on the plane, Ax_0 +By_0+Cz_0 = D and Ax +By+Cz = D.
(1) What is the difference between these equations?
(2) What is the vector from \boldsymbol x_0 to \boldsymbol x?
You are given that \boldsymbol n = (A,B,C).
(3) What is the inner product between \boldsymbol n and the vector from \boldsymbol x_0 to \boldsymbol x?
Don't guess. Use the answer to question 2. Finally, relate the answers to questions 1 and 3.
The vector from x0 to x is (x-x0) right?
So should I do the inner product between (x-x0) . (n)?
Then I won't get any number, just some equation in x n x0?
Yes. Do that. The reason for doing this is that the vector \boldsymbol x - \boldsymbol x_0 represents any arbitrary vector on the plane. If a vector is normal to every vector on some plane the vector is normal to the plane itself.
Please use English, not TXT-speak. Is it really that much harder to type x and x0?
OK... I'll do that...
Can you please help me with number 2 and 3?
Hi, can anyone help me with the other question please...?
I am so depressed... :(
Need some hints... Thanks...
Redheart, you really do need to show some work before most people here will help you.
I calculated the cross product of b x c, buat I don't know what is the meaning of "projection to plane A"
But for number 3, I can't figure out the meaning. Can you please give a hint?
Thanks...
It tells you what to do in the next sentence: "Calculate components of vectors b and c that are parallel to plane A". Find the projection of b x c on the normal vector you found in 1, subtract it from b x c to find the part parallel to the plane.
Thanks...
Are these new coordinate axes still orthogonal to one another? Check the inner product of e1' and e2' that you are given to make sure. Assuming they are orthogonal, then e3' must be orthogonal to both. How do you find a vector orthogonal to two given vectors? Of course, you have to be careful of the sign- this has to be a right hand coordinate system.
for number 3, I've found the e'3 vector which is 1/3 V2 e1 + 1/3 V2 e2 - 4/3 V2 e3, here V means the square root.
But I still don't know how to make it to ei part...?
I'm sorry, the question should be like this:
New right hand coordinate axes are chosen at the same origin with e1' = (2e1 + 2e2 + e3)/3 and e2' = (e1 - e2) x 1.4. Express e3' in term of ei (not e1, sorry...). If t = 10e1 + 10e2 - 20e3, express t in terms of the new basis ek'. Express the old coordinate xi in term of xk' , xi = f(xk')
Hello...? :(
  • · Replies 16 ·
10K
