Why Haven't Two Clocks on a Table Been Used to Measure Light's One-Way Speed?
  • Context: Graduate
  • Thread starter Thread starter Martin Miller
    Sr
The discussion revolves around the question of why two clocks placed on a table have not been used to measure the one-way speed of light. Participants explore the implications of such a measurement for special relativity and the synchronization of clocks, as well as the challenges involved in establishing a definitive measurement without assumptions.
  • One participant questions the feasibility of using two clocks to measure light's one-way speed, emphasizing the need for a method that proves to be correct without assumptions.
  • Another participant raises concerns about the accuracy of GPS as a test for light speed invariance due to various complicating factors.
  • Some participants argue that current experiments involving two clocks assume one-way invariance and isotropy without providing proof.
  • A participant suggests that absolute simultaneity, as defined pre-Einstein, is not necessary for special relativity, but must be operationally defined for practical use.
  • One participant mentions past experiments that attempted to measure one-way speeds, noting that results were inconclusive or ignored due to the amateur status of the experimenter.
  • Another participant proposes a hypothetical setup using ideal clocks and a measuring stick to illustrate a potential method for measuring one-way speed, while acknowledging the inherent challenges.
  • There is a discussion about the implications of simultaneity on distance measurements and the necessity of synchronization for accurate readings.
Participants express differing views on the validity of existing methods for measuring light's one-way speed and the assumptions underlying them. There is no consensus on the feasibility or correctness of the proposed methods or the implications for special relativity.
The discussion highlights limitations related to assumptions about clock synchronization, the definition of simultaneity, and the complexities involved in measuring one-way speeds without prior assumptions. The challenges of establishing a definitive measurement method are acknowledged but remain unresolved.
  • #151
Nereid said:
2) ring lasers are the heart of many modern gyroscopes, including those in commercial airliners. To underline outandbeyond2004's point, if there were any anisotropies, or other deviations of the kind that wisp and Eyesaw have described, it would seem remarkable that they'd cancel out perfectly in devices like ring lasers. But maybe that's exactly what wisp et al expect?
The principle on which the ring laser gyroscope works is due to an effect that SR cannot explain clearly.
The Sagnac Effect
An article that explains this clearly, but from relativity's viewpoint is given at http://www.mathpages.com/rr/s2-07/2-07.htm.
The first few paragraphs explain the Sagnac effect (you can ignore the section showing loop and area calculations). The argument in support of relativity's explanation is summed up on the basis that the device centres around one particular system of inertial coordinates (centre of circle), and all other inertial coordinate systems are related to it by Lorentz transformations.
But the flaw in this argument is simply this: What happens to the measuring clock when the radius of the circle becomes very large and the clock's velocity small - a limit process?
The Sagnac effect still applies and the clock's motion becomes more linear. In this limit process it is not unreasonable to treat the moving clock as an inertial reference frame in its own right (the Sagnac effect has been tested to great accuracy and so it perfectly reasonable to use a limit process to make the moving clock's frame inertial). Now according to relativity, since this is an inertial frame, light must travel at speed c in both directions. But the Sagnac effect requires that the speed of light must be c+v and c-v respectively, and not c! This limit process shows that relativity contradicts itself, as the real measurements are made in the moving clock frame and not at the centre of the circle. An argument that focuses on one inertial frame that is the centre of the circle is the only way relativity can explain this effect, and so the case for relativity is very weak.
wisp
"particles of nothingness"
  • #152
outandbeyond2004 said:
A ringlaser project that is able to detect the anistropy of the sort theorized by Wisp? http://www.wettzell.ifag.de/LKREISEL/CII/precise.htm
This group says it hopes to achieve resolution of the Earth's rotation to a few parts in a billion! That's much more than we need, if the wisp ether speed of the ring laser on the equator is totally due to Earth's rotation. speed of the r.l/c is about 1 per million or maybe much more. I forgot what the speed of the solar system (divide by c) is wrt the CRB, but it must be much more, I think.
I don't believe that this experiment will detect any galactic ether flow, because it will be affected by "jiggle effect" (wisp theory). It will suffer the same fate of the MM experiment carried out on the surface of the earth.
However, it will measure the rotation of the Earth with incredible accuracy.
wisp
  • #153
You mean relativity isn't preserved by limits? *gasp* Guess what? Neither is mathematics.
Besides, if v is negligably small, then c - v and c + v are negligably different. :biggrin:
  • #154
Exactly how does this limit process that wisp writes about in post #151 work? It seems as though as the circle gets larger, the angular speed gets slower proportionally, so as to keep the linear velocity the same. If that is correct -- so what? The rotating frame becomes more and more like a inertial frame -- neglecting gravitational effects of course. If you keep the measurement time small enough, the rotating frame is indistinguishable from an inertial frame beyond the limits of instrumental technology, and that's far easier to do that with a huge and s-l-o-w-l-y rotating r.l.
One has to be careful in applying SR to situations where the curvature of spacetime cannot be neglected. The huge ringlaser is simply in reality not a subject for SR anyway.
There may be some worth in wisp theory, the explantion of how gravitational effects may arise from wisps is intriguing. However, I am less enthusiatic than before. I will continue to skim wisp's future posts to see if there is any significant change of some nature, but except for one thing, I do not think I will post any more on wisp theory.
  • #155
Cute, isn't it - wisp declares negligible the most important piece of the model in order to disprove the validity of the model.
  • #156
The problem is that as the ring's radius grows to infinity, so does the amount of time it takes for the light to travel around the ring. An infinite amount of time is plenty of time for those negligable errors to build up. :smile:
Basically, he's neglecting the fact that 0 * ∞ and ∞ - ∞ are indeterminate forms.
  • #157
I propose to derive the Sagnac effect from classical physics for the benefit of readers not familiar with the effect. I want then to incorporate reasonable wisp-theory changes. I hope to go on from there and then to show that we have reasonable grounds to expect that wisp theory does predict time-varying signals that ringlasers can detect, contrary to wisp's dismissal of them (post #151).
If my derivations pass muster (e.g. nobody can show any error or show that an assumption is unreasonable), I am going to unsubscribe this thread. Look for the next post . . . (How's that for salesmanship? <smile> )
  • #158
If wisp ever thought that my last post (#157) was an April Fool joke, no, he fooled himself.
The link that wisp gave in #151 on the Sagnac Effect would be helpful tho not necessary.
A laser can be viewed as a chamber that creates conditions for resonance. There must be a positive integer number, called the mode number, N, of whole cycles (no partial cycles) between the ends of the chamber:
N\lambda = L, _________ EQUATION 1
where L is the "optical length" between the ends of the chamber, and \lambda is the wavelength. That is the resonance condition for lasing.
A ringlaser is two chambers, one for counterclockwise traveling photons, and the other for cw photons. Let's consider in this thread only a circular ringlaser of radius R. Let it be at rest in an inertial frame of reference whose origin is at the center of the circle. On a point of the circle is a device that does several things:
1. shoot out photons of the same mode number in either end equally (often many modes appear in the ringlaser, but we can assume just one mode is excited);
2. combine the ccw signal with the cw signal to form a beat frequency;
3. and measure the beat frequency.
Experimentalists would see the above description as an overly simple and impractical model of the laser, but it should suffice for order-of-magnitude estimates.
Let's modify Equation 1 to get the frequency:
f = N/T, _____________ EQUATION 2
where T is the time for a photon to go around the ring from the device and back to it.
Given T_+ for the trip time of a ccw photon, and T_- for that of a cw photon, we have for the beat frequency f_b:
f_b = N|\frac{1}{T_+} - \frac{1}{T_-}|. ________________ EQUATION 3
Of course if no anisotropy existed in the two chambers, and the ringlaser was still at rest ia inertial rf, the beat would be zero. Suppose the irf moved through wisp space at speed v, it will still not change anything. For every ccw photon going at c + w
we also have, on the other side of the circle, a cw photon going c + w; and likewise for photons going c - w, for any speed w <= v.
However, the situation changes when you rotate the ringlaser at a constant angular speed of \omega wrttirf. Then the photon speeds cannot be matched up that way, canceling out all the w's.
Readers may find it helpful for later posts to derive the Sagnac Effect beat frequency.
  • #159
No, the radius of the ring increases, but v stays the same. So c - v and c + v are not negligibly different.
And if the radius were very large, why should errors come into this argument!
wisp
  • #160
Your reasoning is OK, but if no change occurs due to a galactic ether flow, SR supporters would argue that this was expected - just like in the MM experiment.
But wisp theory also predicts a no change. The argument is similar to that used in the MM experiment and is due to jiggle dilation effect.
So SR and Wisp predict no change due to an ether flow component.
However, if the device were operated away from the Earth's surface things would be different. SR would again predict no change, whereas wisp theory would predict change due to the reduced jiggle effect.
See section 7.7 / equation set 7.7 for the affect of jiggle on the MM experiment.
http://www.kevin.harkess.btinternet.co.uk/wisp_ch_7/wisp_ch_7.html
wisp
  • #161
Response to wisp's post #159:
I am sorry that other people misread your prior post. However, your infinitely large ringlaser hardly disproves SR. Did you indeed get the point that SR is only of limited validity (the spatio-temporal dimensions of the irf must be small enough that our instruments cannot detect gravitational/acceleration effects)? Your monstrous rl pushes poor SR out of its limits, shivering and shivering. O! Cruel Wisp!
  • #162
I think that the main problem of SR is the clock traveling together with light.
Any object cannot travel in c except of light. Including the clock.
  • #163
Just to make sure, Wisp: you think that your theory predicts that the motion of the rl through wisp space will not produce any beat whatsoever? No matter how fast it may be rotating and how it is oriented to the motion? If yes, I am surprised that jiggle would cancel things out or balance out so neatly. Oh well, we'll see. . .
You realize, of course, that if you just say that jiggle does this or that so that a null effect ALWAYS occurs, it is just too convenient an ad hoc hypothesis. Your only possible justification for this wondrous pheonomenon is experimental verification. I doubt you can get people to spend scarce time and money on ad hoc experiments to find jiggle without some substantial theoretical foundation.
One correction: I will ignore SR corrections to my calculations. Keep in mind that I specified "optical length." That is not necessarily the same as the circumference of the at-rest, nonrotating rl. That is about all the concession to SR that I have made and that I think I will make. Perhaps after I have presented my theory including the effects of jiggle as I understand it, we can discuss the effects of SR corrections.
  • #164
The argument to which I responded said that v was small. :smile:
Anyways, how did you manage to conclude that if R is large enough so that the observer is in an essentially inertial frame, then the speed of light around the ring was c+v or c-v?
  • #165
Here a ringlaser rotating at angular speed w is moving through the ether at velocity v. Jiggle and wisp space will be considered in later posts but not here.
Source independence is assumed, i.e. EM signals travel through empty ether at c. At the outset of calculating the modified SE beat frequency, let's try to get a clear picture of what is going on. In ether space, each ringlaser photon travels in ether space what we might call pseudo cycloids, but the photon generator/beater travels a true cycloid. It is worth noting that no ringlaser photon travels the same path in ether space as any other; in that sense we do have one-way travel (if this is not acceptable to MM et al. -- why not?).
The following point is not one I am sure ought to be made, but I will make it nevertheless. The photons that beat together in the beater are not photons that start out together, at the same time. Instead of my drawing a diagram, why don't you draw it following these instructions: Draw the following on a piece of paper:
A circle about the size of your fist on a piece of paper.
About the center of the circle, draw a curved arrow going ccw and label it w for angular speed.
A vertical arrow starting near the right side of the circle and label it v for the ring's velocity wrt the ether.
On the circle make a tick somewhere between zero and pi/2 from the direction of v (which we can take to be the x-axis also). Label the tick thetab, for the point on the circle where a ccw photon and a cw photon meet in the beater to create the beat frequency.
Now, the ccw photon had to have started earlier than the cw photon, so you have to draw their respective ticks on the circle as follows:
For the cw photon, simply go a little cw from the first tick and between that and zero angle, draw a tick. Label that theta-.
Again go a little cw and so on except label *that* theta+.
The ccw photon leaves theta+, goes through theta- and then thetab and on all around the circle, ending at thetab. The cw photon goes the other way and on *almost* all around the circle, ending at thetab.
I want to do the math in the ether frame of reference, and am finding it tough going. I never got really good at problems like that. It might be several days before I decide it is good enough to present. Or maybe I will decide on another approach.
  • #166
outandbeyond2004
No, it is not acceptable. The ring laser device that controls the motion of the photons is moving through the ether at speed v.
To mimic the pseudo cycloid motion from the ether frame, a device would have to be made that could accelerate and decelerate the photons, which would make the photons feel forces that were variable.
In the moving frame the forces are of constant acceleration only.
Also in ether frames force devices operate differently, as force dilates as the speed v increases (but, Lorentz symmetry stays the same).
With SR you can swap frames about, but you cannot do this with ether frames.
To start of with a simple model, why not make a square sided laser device, which rotates by pi/2. The sides can be the x-y-axes, and later the model can be made circular.
wisp
  • #167
wisp, I do not understand your post, but I did imply that I will not consider wisp theory for now. Later I will consider it. Then I probably will need considerable amounts of discussion. Got the time for that?
I think I am getting the hang of the problem, anyway. In truth, I caught a blooper. The motion of the beater is pseudo cycloid, not true, because its rotation does not necessarily have the proper relationship to the velocity.
  • #168
My calculations made it obvious to me that the theory of linear addition of speeds plus the postulate of constant speed of light in the ether predicts a modification of the Sagnac Effect:
Multiply it by a factor like
sqrt ( 1 - (gamma*cos(theta))^2 ) - gamma sin(theta),
where theta is the angular position of the beater measured at the center of the ringlaser from the velocity direction and gamma = v/c, v being the speed of the ringlaser wrt the ether.
I am confident that if some ringlasers can resolve the modified Sagnac Effect to better than the order of gamma (v/c), they would disprove SR, provided gamma is known.
My calculations did not reach the point where the Sagnac Effect is modified, but surely time varying signals in it are obviously demonstratable. The calculations are now presented (skip to --------------- if you want) and some discussion follows.
The position P(vector) of a photon at time t starting from theta0 at t = 0 in the ether frame, given
R = radius of the ring
v = speed of the ring wrt the ether, in the x direction
theta = angular position, = theta0 at t = 0, measured at the center of the ring from the x direction:
P = (vt + R cos(theta) , R sin(theta))
Take the derivative wrt t:
dP/dt (vector) = (v - Rsin(theta)*dtheta/dt, Rcos(theta)*dtheta/dt)
Because the photon is supposed to move at the speed of light in the ether frame,
c^2 = |dP(vector)/dt| (square of the magnitude) =
v^2 + (R*dtheta/dt)^2 -2vRsin(theta)*dtheta/dt
Let w = angular speed = dtheta/dt, and solve for it:
w = (c/R)(+/-sqrt(1-(gamma*cos(theta))^2) -gamma*sin(theta))
The ccw photon requires the plus sign in the above equation; the cw photon the minus sign.
Note that the formula given above does not apply to a ringlaser attached to the surface of Earth, if gamma = Earth rotation speed/c, because the ringlaser does not go in a line, rather it revolves in a circle. I don't see, however, that the qualitative picture is any different.
The factor after c/R in the above equation does approximate 1 - gamma*sin(theta) for gamma << 1, but if you take gamma = 0.9 it is obviously asymmetric as a plot shows. Not that we would ever have ringlasers hurtling through ether at speeds like that, but it was interesting at least to me.
Remember the ringlaser that claimed to be able to resolve Earth's rotation to a few parts in a billion? I do not know the particulars of its design, so I cannot really say 100% positively that its operators ought to see ether anistropy effects generated by Earth's motion and rotation like predicted above, but I would be amazed if it were not so. If my calculations and conclusion are correct, I believe we would have seen reports of anisotropy in ringlaser experiments by now if gamma ~ 1/1000 as per Nereid. MM et al would have been happy. Happy now? :smile:
  • #169
w = (c/R)(+/-sqrt(1-(gamma*cos(theta))) -gamma*sin(theta))
I got a quadratic, which gives
w=(v*sin(theta)/R)+/-sqrt((v^2*sin^2(theta)-(v^2)+(c^2))/R)
Anyway, with the jiggle factor (slows light in the perpendicular direction to the Earth's motion through the ether) the v terms will cancel. It did exactly this with the MM formula, which had v terms.
I will use your formula and add in the wisp bits. It should give a formula for w without any v term.
  • #170
Wisp's quadratic result is correct. However, v^2 -(v^2)sin^2 = (v^2)cos^2. My result is the same.
edit - I did leave out the factor ^2, sorry, while copying from my paper. I edited it into that previous post.
  • #171
Anybody know how to solve this analytically?
\int \frac{d\theta}{\pm \sqrt{1-(\gamma cos\theta)^2} - \gamma sin\theta}
  • #172
The readers who want a neat formula for the modified Sagnac Effect:
There is not any, generally speaking. Numerical approximation looks necessary. This post assumes that you have followed the directions in post #165 https://www.physicsforums.com/showpost.php?p=177177&postcount=165
A general procedure goes as follows:
Obtain a formula relating initial angle and final angle for the ccw photon to the trip time:
T_+ = T_+(\theta_+, \theta_b)
Likewise for the cw photon:
T_- = T_-(\theta_-, \theta_b)
We also have
\omega_bT_+ = \theta_b - \theta_+
and
\omega_bT_- = \theta_b - \theta_-
where omega_b is the rotation speed of the beater.
Even if we had analytic formulas for the trip times as functions of the initial and final angles, these equations must still be solved simultaneously. This is in general impossible to do so analytically. I fear this is the case for the rotating ringlaser in translational motion. I am not sure whether I will do the numerical work necessary to show a time-varying signal. I can program my computer, but I must learn how to solve these equations simulataneously on it. I don't know how much time that would take.
It might be worth doing if it were original work and would be accepted in a journal like Physics Review.
  • #173
outandbeyond2004
I can’t see a simple solution either, but I will use your formula to input into mathcad and calculate a set of series equations that will give an approximation answer.
I will do this with and without jiggle.
Jiggle slows light on the Earth's surface in the perpendicular direction to ether motion by
\gamma \equiv \frac{1}{\sqrt{1 - v^2/c^2}}
Initial mathcad plots (without jiggle) of w against theta show that it is affected by the ether flow and varies in a sinusoidal pattern.
I haven’t added the jiggle effect yet, and initially said that the results would cancel any ether flow effect. However, there is a small asymmetry to the jiggle cancellation effect due to device rotation, which will result in an extremely small variation in w, which will be dependent on the ether flow, but its value may be too small to detected.
  • #174
Mathcad! O, you lucky fellow. What I was planning to do is simply to calculate the photon trajectories backwards until omega_b*deltatime = deltaangle for both photons. Probably have to do this several times, a few times integrating forwards rather than backwards like above, until you find a good step size that minimizes numerical error. Then run with the optimal step size for all theta_b. I guess the angle that would give the most trouble is when cos(theta) = 1, i.e. theta ~ pi/2. That's where I would look for optimal step size. No, come to think of it, I'd try pi/4, because the cos term is only of second order in gamma.
I cannot believe the jiggle only operates in the peripendicular direction. I think it has something like a sine dependence. Let v be the velocity (vector) of the rl and n be an unit vector in the peripendicular direction to c travel. then
\gamma_{jiggle} = \frac{1}{\sqrt{1-(v\cdot n)^2}}
Possibly wrong formula, but you get the idea.
  • #175
I looked at the case of a circular ringlaser attached to the spinning earth, ignoring Earth's revolution about the Sun.
Let
v_L =
velocity of photon measured in ether space;
v_E =
velocity of ringlaser center wrt inertial frame centered on Earth's center of mass or in ether space; both velocities are fractions of the inertial speed of light in vacuo.
For the case of a ringlaser on the equator, with its plane parallel to the equatorial plane, let
\theta_L =
angle of photon position measured wrt x-axis of the inertial frame of Earth used above at the center of the rl;
\theta_E =
angle of rl position measured wrt x-axis of the same irf at the Earth center of mass;
So,
v_L^2 + 2v_E cos(\theta_E + \theta_L)v_L - c^2 + v_E^2 = 0
Surprisingly simple. I am not sure what the cos term would lead to in the beat frequency.
  • #176
If we take the beat frequency from a ringlaser like in the last post and that of a same rl but twice as big, that would be more than three x the fun <wild and insane laughter>.
  • #177
The beat frequency from a combination of Earth revolution (orbit about Sun) and Earth rotation is certainly going to be much more complex. I will just await wisp's numerical results for this (Earth rotation only) case before considering the revolution + rotation case, if that's OK.
edit - the position of the beater of the equatorial ringlaser is fixed wrt the Earth, so the rotational modification to the Sagnac effect is constant. To measure that, one needs to know the other contributions to the overall effect, such as that of Earth's revolution about the sun. So, it would be better to look at that instead. But, why not consider the Sun's "orbit" about the Milky Way center? Even better, the Milky Way galaxy's orbit about the barycenter of the local group of galaxies . . . the motion wrt the CRB?
In the next post, I will just consider a simple case to see if it's all right to calculcate each effect separately and add 'em up afterwards (principle of superposition).
  • #178
Outandbeyond2004
I've done some calculations using mathcad and thought on how jiggle affects light in the ring laser. Two things happen:
1. Light is slowed by jiggle in the perpendicular direction and this slows light in all directions by the same amount because, light cannot change its path (unlike its affect on the MM experiment where it can change its path). The result is that all light slows in the ring laser by a factor of jiggle.
2. We must apply the "rules for time dilation compensation" (wisp theory 7.15.4). An observer moving with the ring laser records the speed of light in the ring laser as being increased by gamma (gamma has the same value as jiggle). The result is that the speed of light will be measured as being unaffected by jiggle.
(We ignoring the refractive index for glass and will consider the motion of the Earth through the cosmic ether - not its orbit around the sun).
If we assume that the ring laser moves thought the ether at 340km/s in the direction suggested in your message #165. Then the speed of light will slow by 1 part in 1038422 according to your classical ether calculations. And because jiggle and time dilation cancel out, I see no reason to doubt that this does happen.
If the ring laser is perpendicular to the ether flow then the speed of light will remain fixed at c.
If the tilt of the Earth causes the a component of the perpendicular ether flow to move in the x-axis direction by [sin (35.5) = 0.4] then the variation in light speed is 0.4*(1 part in 1038422) or 1 part in 4153689.
The question that I feel needs answering is:
How does the speed of the Earth through the ether combined with the Earth's tilt affect the beat frequency?
I believe that a very sensitive laser ring device will detect a small sidereal variation in beat frequency.
I will do some calculations using your formula.
  • #179
Whoa, wisp! (1)Either you are getting something wrong, or I am. I don't see how you get the 1 in 1038422 thing. I would have thought it was more like 340e3/c ~ 1.1/1000. See, expand in powers of v/c and sort of use the principle of superposition for the first power. I suspect you assumed that the rl does not rotate to produce the Sagnac effect. You merely assumed zero rotation, did you? If so, well it would indeed be something for the rl to produce a difference in trip time of even that relative size, all right. However zero or very small rotation is simply not practical for at least one technical reason that I won't go into here. You must let the rl rotate with the earth. Not at the equator, either. See (2) please.
(2) To be practical, you have to consider ringlasers lying flat on the ground of the spinning AND moving earth. I have been struggling to get results, and I am getting there. I was never good with multiple reference frames, especially this: One is moving wrt another, which is moving wrt yet another. Right now I am going over the calculations several times to be sure I have everything straight. I can't say when I feel confident enough to post the results here. Maybe Monday evening, if not sooner. Would you wait until then?
  • #180
This is the first part of a three-part post.
A spherical planet of radius R_p (p for planet) hurtles through ether space with velocity \vec v_e (e for ether -- not Ethel!), which is treated as constant for sufficiently brief intervals of time. The planet's angular velocity wrt ether space is \vec\omega_e, also treated as constant. Attached flat to the planet's surface is a circular ringlaser of radius R_L (L for laser). The ringlaser's center is represented by location \vec P_p. The location of a photon in the rl is represented by \vec P_L.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 25 ·
  • · Replies 42 ·
  • · Replies 93 ·
  • · Replies 36 ·
  • · Replies 58 ·
