How many Friday the 13ths would you expect in a year?
  • Context: Undergrad
  • Thread starter Thread starter JakeA
    Year
The discussion revolves around the frequency of Friday the 13ths in a given year, exploring calculations, patterns, and theoretical implications. Participants examine both simple and complex mathematical approaches to determine expected occurrences, while also touching on related concepts in number theory and chaos theory.
  • One participant calculates that with 12 months and a 1/7 chance for each month, the expected number of Friday the 13ths is approximately 1.71, suggesting that having 3 in a year is unusually high.
  • Another participant agrees with the calculation and mentions that determining the maximum and minimum number of Friday the 13ths requires accounting for month lengths and their divisibility by 7.
  • A different participant asserts that chaos theory is not a theory in the traditional sense but a branch of inquiry, and emphasizes that the problem of Friday the 13th is deterministic rather than random.
  • One participant notes that in a 400-year cycle, there are 688 occurrences of Friday the 13th, leading to an expected value of approximately 1.72 per year, reinforcing the idea that 3 is more than expected.
  • Another participant points out that if Friday the 13th occurs in February of a non-leap year, there will necessarily be another in March, highlighting a specific pattern.
  • Several participants discuss the deterministic nature of the calendar, arguing that it does not exhibit randomness as seen in chaotic systems, and that the calendar repeats every 400 years.
Participants express differing views on the implications of chaos theory in relation to the calendar and the occurrence of Friday the 13ths. While some agree on the mathematical calculations, there is no consensus on the relevance of chaos theory to the discussion.
The discussion includes assumptions about the distribution of days and the nature of chaos theory, which may not be universally accepted. The calculations depend on specific definitions of cycles and leap years, and the implications of these calculations are not fully resolved.
JakeA
Today is Friday the 13th. It's the first of 3 this year. Is 3 more than you'd expect in a year?
Here's how I'd calculate it.
12 months, each with a 13th. 7 days in a week, so each month has 1/7 chance of having a Friday 13. 1/7 x 12 = 1.71.
So this year is significantly more unlucky than others, I guess.
OK, if I got this trivial math problem wrong, I'm really embarrassed, but so what.
A more complex question would be whether or not numerically days of the week are evenly distributed, as I have assumed in my calculations. Also, does the occurrence of a Friday 13 effect the probability of another in the year? Interesting number theory questions with hints of chaos theory as well.
Your calculation is spot on and in fact it's possible to determine the maximum number of Friday the 13ths as well as the minimum, but that involves accounting for months lengths and their remaining lengths divisibility 7, whatever days remain can be added successively to determine the amount of Friday the 13ths in any given year leap or otherwise. it is a tad more complicated, in fact I don't want to start working it out as I fear it'll eat up an hour or so and I already know the answer is 3 and 1. :smile:
I wouldn't be surprised though that once you had an answer you could work out the number of friday the 13ths from the first date they fell on accounting for leap years, and in fact I'm sure of it.
By the way, JakeA, Chaos Theory despite its name is not even a theory. It is a branch of inquiry.
There are only fourteen possible calendars. January 1 can start on anyone of the days of the week (seven ...) , and February can have 28 or 29 days (... times two: fourteen).
Theory has a rather different meaning in mathematics than in science. Theory in mathematics means "body of knowledge". In addition to chaos theory there's K-theory, knot theory, measure theory, number theory, ...
That said, there is nothing chaotic in this problem because there is no randomness in the problem. There is nothing random about whether April 13, 2525 falls on a Friday (it does). Determining the day of the week a particular date occurs on is a trick commonly learned by autistic savants. (I cheated and looked up a calendar for 2525.)
In a 400 year cycle there are 688 F13's
So one expects
E[F13]=688/400=1.72 F13/year
So three is more than you expect in a year
though maybe the 28 year cycle that covers all cases likely to arise in the lives of most now living should be used
E[f13]=48/28=12/7~1.7143
in eith case we may note that about one year every 9 has 3 and the next one is 2015
The irony in this correction is that the main subject of chaos theory is deterministic dynamical systems e.g. the most prominent examples of chaos like the lorenz equations, logistic equation, the 3-body problem, etc have nothing to do randomness. Here is the first paragraph of the wikipedia article on chaos theory:
"In mathematics, chaos theory describes the behaviour of certain dynamical systems – that is, systems whose states evolve with time – that may exhibit dynamics that are highly sensitive to initial conditions (popularly referred to as the butterfly effect). As a result of this sensitivity, which manifests itself as an exponential growth of perturbations in the initial conditions, the behavior of chaotic systems appears to be random. This happens even though these systems are deterministic, meaning that their future dynamics are fully defined by their initial conditions, with no random elements involved. This behavior is known as deterministic chaos, or simply chaos."
At the risk of stating the obvious, if Friday the 13th falls in February of a non leapyear, then another must follow in March.
We got two for the price of one this year :smile:
There is no uncertainty in the calendar. The calendar repeats every 400 years. That today is Friday the thirteenth means that February 13, 2409, February 13, 2809, and February 13, 20009 all will fall on Friday. Compare this to a deterministically chaotic system, where we don't know exactly the state of the system. If the system is chaotic, a slight change in that state will result in large changes downstream. That we don't know the exact state at any point in time essentially adds a bit of randomness to the system.
There is a key word in that wikipedia article you quoted: "In mathematics, chaos theory describes the behaviour of certain dynamical systems ..."
The calendar is not one of those dynamical systems.
  • · Replies 66 ·
  • · Replies 20 ·
10K
