Dark matter or variable gravity?
The discussion centers around the explanations for the observed 'excess' gravity around galaxies, specifically contrasting the dark matter hypothesis with alternative theories such as variable gravity and Modified Newtonian Dynamics (MOND). Participants explore the assumptions underlying gravity, the nature of mass and energy, and the implications of different models on our understanding of cosmic phenomena.
  • Some participants question the assumption that mass is the sole cause of gravity, proposing that gravity might arise from an unknown mechanism related to space-time density.
  • Others assert that dark matter, regardless of its composition, behaves as if it has mass and influences gravity.
  • There are claims that variable gravity contradicts general relativity and observational evidence.
  • Some participants mention alternatives to dark matter, such as MOND, which modifies gravitational laws rather than introducing new matter.
  • Critics of MOND argue that it fails to explain various galactic phenomena, including rotation curves and gravitational lensing.
  • Discussions include the relationship between MOND and relativistic effects, with some asserting that relativistic MOND theories do not adequately account for gravitational lensing by dark matter.
  • Participants debate the validity of observations inferred from gravitational lensing and the necessity of dark matter in certain models.
Participants express a range of views, with no consensus reached on the validity of dark matter versus alternative theories like MOND. Disagreements persist regarding the implications of various models and their explanatory power concerning observed phenomena.
Limitations include unresolved assumptions about the nature of gravity, the dependence of claims on specific definitions of mass and energy, and the varying interpretations of observational data related to gravitational lensing.
slooper2112
Can someone explain why 'dark matter' is the dominate explanation for the 'excess' gravity seen around galaxies?
It seems to me that we have made an assumption that mass causes gravity. Isn't it possible that gravity arises from some as yet not understood mechanism?
I may be way off base but it seems to me that if gravity is space-time density, then it would 'seem' that when the Universe was all energy (no mass formed yet) there would have been some variability in the energy and density of space-time itself.
In the more dense areas, energy would condense into mass. So maybe higher density space-time gives rise to formation of mass.
Thoughts?
Shannon
Space news on Phys.org
This may be a redundant question.
The point of dark matter is that, whatever it is made of be it particles or energy, it affects gravity as if it were massive.
Thoughts?
Shannon
Well, the dynamics of dark matter, mainly the way that structures in the early universe formed, demonstrates that dark matter doesn't experience any significant pressure. This is the sort of behavior we associate with free particles that have no electric charge, such as neutrinos (neutrinos just have too little mass, so the dark matter needs to be some sort of neutrino-like particle with more mass).
And by the way, there is no such thing as pure energy. When you get down to it, energy is a property of matter, full stop. Energy cannot exist on its own separate from matter any more than there can be "pure velocity". If there is energy, then that energy is contained in some field or other.
Variable gravity is inconsistent with general relativity, not to mention observational evidence.
Thoughts?
Shannon
There are alternatives to dark matter, where the observed phenomena is not associated to some new kind of matter but to a modification of the gravitational laws. Maybe the more known is MOND (MOdified Newtonian Dynamics) which is well-tested and has been used to make predictions at galactic scale.
MOND is dead and buried. It simply doesn't explain the variety of galactic rotation curves we see, let alone cluster dynamics, the bullet cluster, or the CMB.
There are, of course, always a few people at the fringes of any science that like to work with zombie ideas. But this is one that really deserves to go the way of the luminiferous aether.
MOND also doesn't explain gravitational lensing by dark matter, that has been observed.
MOND is non-relativistic. Gravitational lensing is a relativistic effect, which is explained by relativistic MOND theories.
Correct me if I'm wrong (preferably with an arxiv reference), but the versions of relativistic MOND I've seen incorporate lensing by ordinary matter, but in no way account for lensing by dark matter, as the latter doesn't exist for them, and can't be arbitrarily distributed. My point is that clumped distributions of dark matter have been directly observed by weak gravitational lensing.
Those distributions have been inferred from GR-based gravitational lensing plus ordinary matter distribution. That is not a direct observation.
It doesn't really matter. The MOND model doesn't explain the data. Ergo it's wrong.
juanrga said:
I already explained in https://www.physicsforums.com/showpost.php?p=3546634&postcount=9 why this is not true.
If you're talking about TeVeS, well, first of all that isn't MOND. But in order for TeVeS to explain the cluster data, they have had to invoke a much greater neutrino density than is expected in the standard model. In other words, they need dark matter anyway, and once you have to have dark matter in the model, what is the point of proposing TeVeS in the first place?
I'm also not convinced that you can use the exact same parameters in TeVeS to explain dwarf galaxies, large galaxies, and galaxy clusters, let alone CMB anisotropies.
  • Featured
  • · Replies 18 ·
  • · Replies 35 ·
  • · Replies 31 ·
