Is it possible that speed of a gravitational waves are greater than c?
The discussion centers around the possibility of gravitational waves traveling faster than the speed of light (c), exploring theoretical implications, observational evidence, and the nature of gravitational fields in relation to black holes and general relativity.
  • Some participants question whether gravitational waves could exceed the speed of light, citing the escape velocity at a black hole's event horizon.
  • Others argue that the gravitational field exists prior to the formation of a black hole and may not be static, raising questions about how changes in mass affect the gravitational field.
  • A participant suggests that under quantum electrodynamics, gravity could be mediated by virtual particles, which are not bound by event horizons.
  • Concerns are raised about the assumption that gravitational waves travel at the speed of light, with some participants calling for further testing of this assumption.
  • One participant emphasizes that general relativity predicts gravitational waves travel at the speed of light and has been validated by experimental tests, including observations of binary pulsars.
  • Another participant mentions Lorentz invariance as a key aspect of general relativity that limits propagation speeds to c, suggesting that deviations would contradict established predictions.
  • Some participants express skepticism about the direct observation of gravitational waves and the implications of their speed, suggesting that alternative theories would need to be self-consistent and compatible with observed phenomena.
  • There is a discussion about the implications of gravitational wave speed on the power radiated by orbiting bodies and the orbital decay of binary pulsars, with calculations presented to support the argument that gravitational waves travel at c.
  • One participant notes that if gravitational radiation does not travel at c, it would complicate the framework of relativity significantly.
  • Another participant refers to a controversial attempt to measure the speed of gravity, indicating ongoing debates in the field.
Participants express a range of views, with no consensus on whether gravitational waves can exceed the speed of light. Some support the notion that they travel at c based on general relativity, while others question this assumption and explore alternative possibilities.
Limitations include the speculative nature of some claims regarding gravitational wave speed and the dependence on the validity of general relativity and alternative theories. The discussion also highlights the unresolved status of direct observations of gravitational waves.
Ravi Mandavi
Since at event horizon, the escape velocity of black hole must be greater than speed of light but even light can't escape from black hole so is it possible that speed of gravitational wave > c?
Astronomy news on Phys.org
When the Black Hole formed, the gravitational field was already there, permeating space. It doesn't go away because an event horizon formed.
It would be hard to explain a 21 billion solar mass black hole by saying that the gravitational field was already there when the star collapsed. I think most cosmologists accept that the field grows as the BH accretes mass. But from where does the gravitational field originate?
While a static field is not affected by an event horizon, the process of accreting mass is hardly static. If the gravitational field were an indication of the mass at the singularity then there is a problem of how the increases in the mass of the singularity, resulting in the changes in the gravitational field, propagate from the singularity backwards in time and faster than light in order to escape the event horizon.
On the other hand, there is an explanation that as matter falls through the EH, it leaves its gravitational field frozen at the horizon.
Under quantum electrodynamics, gravity should be mediated by virtual particles. Virtual particles are not bound by event horizons.
I wonder instead why physicists/astronomers are so sure that gravitational waves travel with the speed of light? Why can it not be slower? Is it just an assumption that waits to be tested, or is there a deeper reason for that?
The reason we believe that gravitational waves travel at the speed of light is that gravity is very accurately described by Einstein's equations of General Relativity. General Relativity has passed every experimental test to which it has been subjected, and General Relativity predicts gravitational waves, and predicts that they travel at the speed of light. While gravitational waves have never (yet) been detected directly, their consequence has been seen in the Hulse-Taylor binary pulsar, the discovery and explanation of which earned them the Nobel prize. When gravitational waves are directly seen, probably within the next decade, I would bet a large sum of money that they are seen to travel at the speed of light.
Lorentz invariance is the part of GR that limits the propagation speed of fields to 'c' and it is assumed Lorentz invariace also applies to gravity. Hulse and Taylor received the 1993 Nobel for their work on binary pulsars, which showed timing increases that precisely matched those predicted by GR. If gravity were not Lorentz invariant, the results would not have matched the predictions of GR.
Remember that we have not quite yet observed gravitational waves. The theory that predicts them predicts their speed as c. Until or unless they are observed it is not appropriate to simply speculate whether this one point may vary. You must rather bite off a bigger chunk.
One would be speculating whether there is an alternative theory, also predicting gravity waves but traveling at different speeds, which is self consistent and consistent with observed phenomena.
Good, you answered you own question.
All mass (thus all sources of gravity) started off either before or outside the BH, thus their gravitational fields were indeed already in effect when they fell into the BH.
Power radiated by orbiting bodies:
P = \frac{dE}{dt} = - \frac{32}{5}\, \frac{G^4}{c^5}\, \frac{(m_1m_2)^2 (m_1+m_2)}{r^5}
Orbital decay from gravitational radiation:
\frac{dr}{dt} = - \frac{64}{5}\, \frac{G^3}{c^5}\, \frac{(m_1m_2)(m_1+m_2)}{r^3}
If gravitational wave velocity was greater than luminous velocity, then the amount of power radiated and the orbital decay of binary pulsars would be much less.
If gravitational wave velocity was less than luminous velocity, then the amount of power radiated and the orbital decay of binary pulsars would be much more.
However, the measurements of these functions in nature indicate agreement with these equations in which the intrinsic velocity of gravitational waves is exactly equal to luminous velocity.
Could the gravitational wave velocity be measured directly from nature with is equation?
Gravitational wave velocity:
c = \left[ \left( \frac{64 G^3}{5} \, \frac{(m_1m_2)(m_1+m_2)}{r^3} \right) \left( - \frac{dr}{dt} \right)^{-1} \right]^{\frac{1}{5}}
[/Color]
Reference:
Gravitational wave - Wikipedia
Jimbaugh, do you think Hulse was not compelling evidence of gravitational waves and their Lorentz invariance? phyzguy, apologies I was still pecking away when you posted essentially the same thing.
[/Color]
Reference:
This is an incredibly naive analysis... If you assume gravitational radiation does NOT travel at c, a lot has to change within relativity. If it's slower, well you have a massive graviton which among having a speed <c also admits longitudinal polarizations. The whole situation becomes significantly more complicated. If it's faster, all kind of crazy things go out the window and I don't even know where to start there.
Yes I do. But I do not consider it direct observation. The pulsar observations make it that much harder to speculate outside of GR. One must explain them.
If however we can build a grav. wave detector we needn't speculate, we could measure the speed. Thus it is meaningful to ask what value we might measure.
Until then, this question is of a different type, (i.e. what does theory say) and so supposing a different answer than theory supposes a distinct theory.
Now personally I'll be shocked if we observe other than speed c grav waves...beyond shocked, flabbergasted.
Thanks for the clarification, jambaugh. As you probably recall, Kopeikin and Formalont attempted a direct measurement of the speed of gravity about a decade ago, but, it is considered controversial. I believe it was Steve Carlip who basically accused them of making a backdoor measurement of the speed of light.
what basically happens is that gravity bents space & time fabric. the light travels parallel to space & time fabric so at a point the fabric is stretched and light have to travel twice as long so that's why they say light cannot escape a black hole. As Eisenstein said that c is the optimum speed limit so let's say a particles with mass zero (energy) can travel at the velocity of c
Orion1 said:
What is the gravitational wave frequency equation for the Hulse–Taylor binary pulsar system?
[/Color]
Reference:
PSR B1913+16 - Wikipedia
http://www.nobelprize.org/nobel_prizes/physics/laureates/1993/hulse-lecture.pdf
http://www.nobelprize.org/nobel_prizes/physics/laureates/1993/taylor-lecture.pdf
General relativistic model for experimental measurement of the speed of propagation of gravity by VLBI - University of Missouri - Kopeikin and Fomalont
2x the orbital frequency.
Pardon if this is a naive understanding of it, but I was under the impression that describing gravity in waves is just a way for us to visualize it, but in actuality that's not what's happening.
My understanding is just that mass alters space-time, so for example while the moon appears to be going in a circle to us, it's actually not going in a circle through space-time, because that's an entirely different plane than our spatial 3 dimensions.
So if that's the case (if it's not then please just correct my misunderstanding and ignore this question), why does it take any time at all for gravity to permeate? If you drop a billiard ball onto a outstretched blanket, all points of the blanket are affected at the same time. Similarly, if you just spontaneously created a large amount of mass in the middle of empty space, would not the space-time field be instantly altered?
No, even within your analogy your intuition is failing here. If you imagine a really large sheet and dropping a bowling ball on it, say the sheet goes from New York to Paris, do you really think the guy in Paris will feel the ball that was dropped in NY instantly? No, he will not. The disturbance propagates at something like the sound speed of the material (I have no idea what this is for a taut sheet, but certainly finite!). The analogy with spacetime is decent, in that the disturbance propagates our at the speed of light.
Note that within GR, if I just imagine the moon orbiting the earth, nothing is changing about the spacetime (assume the moon mass is so much smaller than the Earth that it doesn't alter the geometry). The Earth creates some well, and the moon is just moving in a straight line through that well. 'Gravity' is encoded in the curvature of that well, which never changes, so it doesn't make any sense to talk about anything propagating here. Only when I change the situation (remove some mass somehow, or something like that), does the geometry need to respond, and these ripples travel outwards like waves on a pond at precisely the speed of light.
Ok, that explanation makes sense :) I was thinking about it from a mathematical standpoint and not a physical one ... Mathematically speaking, all points would feel it at the same time, but that obviously can't be the case physically
That was the question that inspired my post, if I just created a bunch of mass spontaneously in the middle of empty space, how long would it take surrounding planets to feel the effects of it.
Why would this be so? Why does 'mathematically' mean you'd ignore propagation velocity?
All the points are connected, so if you pull down on any of them they all move ... Similar to if you held a light-year long pole and extended your arm, if you just consider that a line segment then the end of the line moves simultaneously with the end you're holding, which obviously isn't true of the physical world.
But that's just a tangent of mine and not a point of contention, as I mentioned earlier I realized a had a fundamental misunderstanding of the information and now it's been corrected, no reason to argue :)
Yeah but the movement must still propagate.
Haha not to be off topic, but why? It doesn't in the line segment example ... The stretching of the plane could just as easily be simultaneous across the whole plane, the only limiting reason it wouldn't be are physical limitations
A line segment doesn't move. You could measure the distance from your hand to your target as being one light year, then move your hand and measure again. But it's not the same line segment (since it's just a measurement), and it took a finite time between measurements.
The model you used was a billiard ball on a blanket. You can ignore the physical traits of the system and only examine it mathematically, but it is a central cause and a radiating sequence of effects. In a cause/effect system the effect must propagate from the central cause at a finite speed.
Haha ok, we're just kinda talking past each other at this point, and since it's not really relevant to the topic in any real way anymore I'll just say that I understand my mistake from earlier and thanks for helping me :)
It's cool. I like discussing.
Haha ok, cool :)
Basically what I was thinking is that the reason motion propagates is on the molecular level. If you push one atom it moves and then pushes the next one, and so on. Similar to how when a light turns green, the first car starts moving THEN the next car starts moving, etc, instead of all of them moving as soon as it turns green.
However, (presumably), the fabric of space-time isn't molecular. I'm not particularly knowledgeable about the subject, but I would assume that space-time is continuous, not discrete. So if I tug on a string of space-time, it's not individual atoms moving, it's a continuous string so as I pull on my end, the other end moves simultaneously.
strat1227 said:
Haha ok, cool :)
From the perspective of general relativity, that's exactly correct. Just like a string, spacetime itself has some characteristic speed at which waves propagate through it (although in the case of space, it's the speed of light, which is a bit higher than your average wave speed in a string).
Anyway, this bit about propagation speeds of physical effects is quite important, and it's important to always be aware of it. It's often easy to write down a mathematical model for a certain situation that extends off to infinity, and forget that far away from your local area of interest, signal speeds become important. That can be important when dealing with boundary conditions for PDEs, for example.
A black hole event horizon has perfect spherical symmetry, therefore it does not radiate gravitational radiation.
[/Color]
Reference:
Gravitational wave - sources of gravitational waves - Wikipedia
