Is CH3OH a better notation for methanol than CH4O?
  • Thread starter Thread starter soothsayer
    Reaction
The discussion revolves around the notation of methanol, specifically whether CH3OH is a better representation than CH4O. Participants explore the implications of each notation in terms of chemical stability, connectivity, and educational clarity, while also touching on related chemical reactions involving methanol.
  • Some participants question the practicality of the reaction NaOCH3 + CO2 + H2O → NaHCO3 + CH4O, suggesting that the presence of water may not significantly influence the reaction outcome.
  • Others argue that while balanced equations are necessary, they do not guarantee that a reaction will occur, emphasizing the importance of energetics and kinetics.
  • A participant notes that CH4O may be both energetically and kinetically unstable, suggesting that its formation would be minimal and slow.
  • One participant explains that the protonation of sodium methoxide is favorable, leading to the formation of methanol, and discusses the complexities of the equilibria involved in the reactions presented.
  • There is a suggestion that CH3OH notation may provide clearer insight into the molecular structure compared to CH4O, which some find confusing.
  • Another participant reflects on their initial confusion regarding the bonding of carbon, acknowledging a mistake in visualizing carbon with more than four bonds.
Participants express differing views on the appropriateness of CH3OH versus CH4O as a notation for methanol, with no consensus reached on which is definitively better. The discussion also highlights various interpretations of the reactions involving methanol, indicating ongoing uncertainty and debate.
Participants acknowledge that the reactions discussed are complex and depend on various conditions, such as pH and the stability of products, which remain unresolved in the conversation.
soothsayer
The equation is balanced, but would it actually work?
Or would the reaction simply ignore the water in the left hand side and go,
2NaOCH3 + CO2 → Na2CO3 + H2O + C2H4
Or perhaps a little of both? I'm just starting to teach myself Chemistry, so any insight would be great!
Chemistry news on Phys.org
You'd have to do the energetics - but at room temp, reactions are often done in solution ... i.e. the water does not take part.
In general - not every balanced chemical equation will actually happen.
Well, at least a little bit of both, in the sense that every correctly balanced chemical reaction has to go to equilibrium, but if one of your products is really energetically unstable, you could have an incredibly low equilibrium constant for that reaction, in which case you may want to treat that reaction as negligible - you would certainly not be able to say it is the "main reaction". The other issue is kinetics - if one of the products is really kinetically unstable, the production of that product will be really slow and the consumption of any of that product which is produced would be really fast.
CH4O looks to me like it would probably be both very energetically unstable and very kinetically unstable. So, you might get some of it - but that amount would be ridiculously small (I would think) and take a really long time to form. I don't know if C2H4 is that likely to come out of this either but it is probably more likely - so you would get more of it, but still very little, and it would still take a while to form though it would be far faster than the formation of CH4O.
AFAIK in chemistry we do not hear of C making more than 4 bonds and H rarely makes more than 1 - but without doing one of these we cannot have CH4O.
Does CH3OH look better?
What you have written out here is an overall reaction which requires several steps and equilibria. Ignoring the carbon dioxide and just looking at the sodium methoxide and protons, you are describing the protonation of sodium methoxide which is very favorable. The pKa of methanol (a very weak acid) is about 16, so any kind of acid in solution (even the water) will lead to an appreciable amount of methanol.
For example, NaOCH3 + H+ → Na+ + CH3OH
would be favorable in most circumstances unless the pH of the solution is extremely high. Consider that if the pH is ~16 (the pKa of methanol) you will have a 1:1 ratio of methoxide:methanol.
The reaction you have written above is slightly more complicated because the acid would be carbonic acid (and even the bicarbonate because methoxide is such a strong base) which depends on the equilibrium between carbon dioxide in the gas phase, carbon dioxide dissolved in the solution, carbonic acid, bicarbonate and, finally, carbonate. This all really depends on the conditions but in theory (and the short answer) is, yes, it should happen.
This reaction is more complicated because you are essentially dimerizing (kind of, I don't really know the technical name for such a reaction) methanol/methoxide. My organic chemistry is rusty (and my text is at my folks' place because I don't have room in the tiny hovel that is my apartment) so I don't want to comment too much about this process but my gut tells me that this would not be the main product(s) of the system.
CH4O is methanol, a pretty stable molecule. We keep it in large jugs in the flammables closet without having to worry too much about it disappearing. The notation (CH4O) can be confusing if you don't have a good "chemistry vocabulary" which is why I prefer to write it as CH3OH. The latter helps people "see" the connectivity a little bit better.
... that was dumb.
Yup, sorry. For some reason I visualized the C atom having more than 4 bonds, even though I've seen CH4O used for methanol various times.
  • · Replies 17 ·
  • · Replies 19 ·
10K
11K
10K
