What is the current understanding of the nature of photons?
  • Level: Graduate
  • Thread starter Thread starter Mephisto
    Photon
129 replies · 29K views
Mephisto
I'm confused. It's a particle and it's also a wave; I'm actually starting to think that photon is just a distortion of spacetime or something... It's a small electro-magnetic field, where one always induces the other and thus this ever-changing electromagnetic pulse travels through space. Do physicists actually have a well accepted idea of what a photon ACTUALLY is?
I'm also thinking that as photon comes near an electron, the way it gets absorbed would be that somehow the electric field interacts with the electrons electric field and it then pulls/pushes that electron and converts this energy stored in the photon's electric field into the kinetic energy of an electron. Or something like that. I don't know. I haven't exactly figured out emittance of a photon yet.
How right/wrong am I? What is the accepted view?
I believe the simplest answer is that a photon is a quantum of energy. The wave-particle duality is just that - a mathematical duality that accurately describes the same physical object's properties, motion, and so forth. Don't think of it as being a wave but actually a particle but actually a wave...ad infinitum. I don't believe anyone knows why light behaves both as a particle and a wave.
I'm just getting back into physics, so I could be a rusty on everything. Correct me, someone, if I am mistaken!
a photon is a photon, an electron is an electron, etc
What properties they have (particle, wave, pointlike, electric charge) etc, its the physicists role to assign, and how they interact etc.
As far as I know the most stringent definition is something like "an excitation of a tempo-spatial mode".
Basically, every system "contains" an infinite number of electromagnetic modes and each mode can be occupied by 0 or more excitations that we call photons
This is somewhat analogues to other phenomena in e.g. acoustics. There is an inifinte number of acoustic modes in a room, when you clap your hands some modes are excited but when the the room is silent no mode is occupied (but they are still there).
I have the Copyright of that question! :smile:
https://www.physicsforums.com/showthread.php?t=143975
lightarrow i think its pretty funny that the topic name is exactly the same :D
I went through the topic, but it seems that most of the people are really quite vague in their description of a photon, as if they were afraid to say something definite about what it is. My overall impression then is that they simply don't know. They also like to describe it sometimes using math, but it's in reverse! Math should describe the photon, not the other way around.
Moreover, there is a lot of mentions of a detector, but detector has nothing to do with the nature of a photon in the physical realm... But maybe that's just because of the way you phrased the question, talking about the "revelators".
I was just trying to see what it could mean that a photon is both a wave and a particle, and how can it have 0 mass. The picture I came up with i think makes at least some sense. The best answer I saw so far, (and also the one that seems most physical) was made in your topic by hellfire:
"A photon is an excitation of the free electromagnetic field."
even though I am not exactly sure if i understand it correctly.
Mephisto: A photon is a photon. An electron is an electron. (as far as we know today) Why must the answer be anything else?
Also, how can we find information about what an object is and behaves if we did not use detectors?...
"A photon is an excitation of the free electromagnetic field." Is an abstract mathematical approach to it.
If you would ask question: "What my gransma watch is?", you could find one or another answer.
Now, you are looking for a SIMILAR answer to the question "What photon is?"
Unfortunately, there is NO SIMILAR answer. Because in terms of existing physics photon cannot be represented as an entity, consisting of a simpler and easy to understand parts.
In General Physics there is ONE concept of photon.
In Nonrelativistic QM - there is another concept.
In Quantum Fielt Theory - absolutely different from both above.
In String theory - something else.
In Final Theory the photon is just some garbage, when we compare for example photon and electron, which is not garbage.
So, up to you...
According to qunatum physics every particle have wave-like properties. Photon is a particle (like electron and ...) and therefore possesses these wave-like properties. But special relativity implies that there is one difference between photon and other ususal particles: Its rest mass is zero.
I hope my english is not so bad!
I have NO IDEA what is rest mass of photon, because photon never stops.
However, if photon travels, at speed of light of course, it's mass is not zero already.
Its energy = hw
according to equivalence principle,
hw = m*c^2
So, photon equivalent mass should be
m = hwc^-2
Yes. Its relativistic mass is not zero. But according to m = m0 / sqrt(1-v^2/c^2), m0 must be 0, since v = c.
This relationship is good only for v < c
If v = c, it does not have any sence.
Of course you may try introduce any kind of sense to it even if v = c
But, this is just your (and others) misunderstanding... an attempt introduce any sence, when actually there is no sence...
malawi_glenn said:
Bright : now you are just talking rubbish.
Which part of my posts is rubbish?
P.S. Or you think all of them? :)))
Bright: It's simple. Suppose we have a particle of rest mass m0 which is not equal to zero. This particle can't reach to velocity of light, because to do this we must give it energy infinitley. So the m0 of photon must be zero.
Whether a photon has "rest mass" is irrelevant since the photon is never "at rest."
But as Bright's "rubbish," points out the photon does indeed have energy, and therefore momentum, which gives it many of the properties of a massive particle. The question becomes how you define "mass." If mass is energy that obeys inertia, then the photon obviously doesn't have mass. But if mass is simply localized energy, then the photon does indeed have mass.
Here's a more important question! Does light have gravity?
Ahem. :devil: Real Physicists (TM) call it invariant mass and calculate it using
[tex](mc^2)^2 = E^2 - (pc)^2[/tex]
which gives a well-defined value of zero for a real (as opposed to a virtual) photon, for which E = pc.
i appreciate you trying to help me with this, but your answers are probably the most cryptic of them all... I'm asking what a photon is, and you are telling me that a photon is a photon. What kind of an answer is that?! What am I supposed to get from that?
I guess maybe I should rephrase my question... I don't have a clear view right now of the difference between normal matter and a photon... I would be ok with just thinking that photon is a packet of energy, but it seems there is more to it!
Why do they say that light is electromagnetic radiation? Light is made up of photons. So surely photons have to have something to do with electro-magnetism.
An harmonic oscillator of frequency v,excited to an energy level n is equivalent to n photons.
Q: What is a photon?
A: A ripple in the electromagnetic field
And as many have pointed out here, you can THINK of a photon as many things, and describe it according to a theory. Like in string theory, the photon is composite of strings that oscillates in a 11dim space etc. ALL our destriptions of the elementary particles is limited. Which descritption you use depends on what you want to do.
You can easy describe it as an excited mode of the electromagnetic field. And the describtion of the electron, you can also describe it as an excitation of a(nother) field. But the very fundamental, is that photons and electrons are not composite systems, and therefore they are point-like objects with quantum properties.
Going back to the wave vs. particle question:
I believe that when one asks this question (what really is a photon?), he or she is looking for an analogy that compares a photon to a macroscopic phenomenon. This is what physicists are doing in a way, but instead of looking for an analogy they are searching for a mathematical model (since quantum, we have realized that we don't have a macroscopic analogy). We can compare a photon to a particle (a mass that exists at a point) if its wavelength is very small. This is because its small wavelength makes it more likely to be found in a smaller region of space (its position is well defined). Particles that we are familiar with (billiard balls for example), have a well defined position (you can catch a baseball!) and we have a way of describing their motions and interactions. In this way we apply our macroscopic vision of balls colliding, with small wavelengthed photons (x-rays, gamma rays). Alternatively, we can compare a photon to a wave (a periodic variance of some quantity in space and/or time) if its wavelength is relatively large. This is because its large wavelength smears out the probability that a photon will be found in a certain area. So with a bunch of photons, their intensity will be periodic. We are familiar with waves in water, we know how they reflect, refract, act constructively and destructively (not like Tsunamis). This model works well for describing and conceptualizing photons as they travel through space, reflect, refract, and diffract. Now, as De Broglie kindly points out, all particles have a wavelength and all waves have an associated particle. It makes sense to view the distinction between the two as a result of our inability to describe the whole of it as a single entity, due to the fact that there are not many macroscopic phenomena which behave like quantum phenomena (although it is interesting that the phenomena we perceive are a result of quantum principles, however difficult they may be to describe in this way.) All in all, nature does not care whether we think of a photon as a wave or a particle or an excitation of the free electromagnetic field, it keeps acting how it always had, while we do our best to conceptualize and predict.
P.S. Isn't it funny how readily we distinguish between ourselves and nature, and even more funny how we think that we think that we think that we think... ad infinitum. When will we understand what this means?
-PJ
According to general relativity, energy curves space. I would assume this energy wouldn't exclude photons.
I don't know what the original poster meant by "does light have gravity?". But according to general relativity photons "feel" the gravitational force, that's why we have gravity lenses and gravitational red shift. But if a photon itself can deform the space-time, I don't know.
At your place, I would proceed gradually and I would begin by asking if a photon can be described as a "corpuscle" moving from source to detector.
A++
According to General Relativity, the source of gravitational fiels is the MASS-ENERGY tensor. Photon has energy. So, a component of that tensor, which correspond to photon energy is nonzero. Thus, photon creates gravitational field.
There is an independent proof. Assume we have proton and antiproton in a box with mirror wallls. These particles are source of gravitation. Now, assume the particles annihilate and we have high energy photons instead of particles. The gravitation from the box is the same. That means photons are sources of gravitation.
Assume the frequency of electromagnetic field is w and energy of the ripple is E
Now, if E < hw (for instance E = homework / 10 )
then I do not believe that ripple is a photon.
If E = hw then MAYBE that ripple is a photon.
If E = 1.2345 * hw then I have no idea what that ripple is.
Er... this "proof" assumes a priori that there is a "conservation law" for gravitation. Is there such a thing?
Zz.
Normal matter (electrons, protons etc) can stay in REST, v = 0
or can move, v > 0, but v < c
Photon CANNOT stay in the rest. Its velocity can be only v = c (in vacuum)
In Classical Physics, light is just electromagnetic radiation and nothing more.
In Quantum Physics, that electromagnetic radiation is separated in portions, quanta.
The value of energy of each such a quanta is exactly E = hw
