Minimising the perimeter of a tunnel with a fixed area
  • Thread starter Thread starter henryc09
    Area Perimeter
The problem involves minimizing the perimeter of a tunnel cross-section shaped as a rectangle topped with a semicircular roof, while maintaining a fixed area A. The perimeter is expressed as P = πr + 4r + 2h, where r is the radius of the semicircle and h is the height of the rectangle. The area constraint is given by A = 0.5πr² + 2rh. By establishing a relationship between r and h using the area equation, the problem can be simplified to a single variable optimization, which can be solved using differential calculus techniques.
  • Understanding of basic geometry, specifically the properties of rectangles and semicircles.
  • Familiarity with calculus, particularly differentiation and optimization techniques.
  • Knowledge of algebra to manipulate equations and solve for variables.
  • Ability to apply mathematical modeling to real-world problems.
  • Study the principles of optimization in calculus, focusing on finding minima and maxima.
  • Learn about the method of Lagrange multipliers for constrained optimization problems.
  • Explore geometric properties of semicircles and rectangles to enhance understanding of their dimensions.
  • Practice solving similar optimization problems involving fixed areas and variable perimeters.
Students in mathematics or engineering fields, particularly those studying optimization problems, as well as professionals involved in architectural design and construction planning.
henryc09
A tunnel cross-section is to have the shape of a rectangle surmounted by a semicircular roof. The total cross-sectional area must be A, but the perimeter minimised to save building costs. Find its dimensions
I have that the perimeter would equal pi*r + 4r + 2h (where r is the radius of semi circle, h is height of rectangle) and that A=0.5pi*r^2 + 2rh, but am unsure as to how to get started. Any help would be appreciated.
The fact that area must be equal to 'A' has given you a second equation. From it, you can determine the required relationship between r and h...meaning that the problem is reduced down to one variable (either r or h). Finding the value of that one variable that minimizes the perimeter is then just a differential calculus problem.
  • · Replies 29 ·
  • · Replies 16 ·
