Finding the velocity and position of a particle from a graph
The discussion centers on calculating the velocity and position of a particle from a graph depicting its acceleration over time. The initial position is -15 m and the initial velocity is -3 m/s. The incorrect application of the equation v = v0 + at, which assumes constant acceleration, led to errors in determining the velocity and position at 5 seconds. The correct approach involves segmenting the motion into intervals where acceleration is constant and applying appropriate kinematic equations for each segment.
  • Understanding of kinematic equations, specifically v = v0 + at and position equations.
  • Knowledge of how to interpret graphs of acceleration over time.
  • Ability to segment motion based on changes in acceleration.
  • Familiarity with initial conditions such as initial position and velocity.
  • Study the application of kinematic equations for non-constant acceleration scenarios.
  • Learn how to analyze acceleration graphs to determine velocity and position.
  • Research techniques for breaking motion into segments based on varying acceleration.
  • Explore advanced kinematic equations that relate position, velocity, and acceleration over time.
Students studying physics, particularly those focusing on kinematics, as well as educators seeking to clarify concepts related to motion and acceleration analysis.
iamjohnny56
Consider the plot below describing the acceleration of a particle along a straight line with an initial position of −15 m and an initial velocity of −3 m/s.
A. What is the velocity at 5 s? Answer in units of m/s.
B. What is the position at 5 s? Answer in units of m.
v = v0 + at
For part A, V = -3 + 1(5)
= 2
For part B, V = -15 + 2(5)
= -5
Both of these answers are wrong, and I'm not sure why...There was another question with this graph that asked to find the position and velocity of the particle at 1 s, and this worked for that, so I'm not sure what to do now...
The equation v = v0 + at is valid only when a is constant. From the diagram, you can easily see that a is not constant over the range of time.
You have not indicated any equations to determine position as a function of velocity or acceleration.
Are you sure you know how to relate position, velocity, and acceleration?
According to the diagram the acceleration at time t=0 is not 1. And the acceleration changes at time t=2. So you'll have to break up the motion into two parts, the first covering the time interval from t=0 to t=2, the second covering the interval from t=2 to t=5.
For part B you're looking for a position, not a velocity. There's another kinematic equation that applies when you want to find the distance given the initial position, velocity, and acceleration.
