More Complex Logarithm and advanced Math Questions
The discussion revolves around three complex logarithmic and exponential equations needing clarification and solutions. The first equation involves manipulating logarithmic properties to isolate x, while the second equation requires clarification on notation, specifically whether "x" indicates multiplication or a variable. The third equation also calls for the use of logarithmic properties to simplify and solve for a variable A. Participants suggest rewriting the equations for clarity and using substitutions to facilitate solving. Overall, the thread emphasizes the importance of clear notation and the application of logarithmic rules in solving advanced math problems.
jspen30
Hello, was wondering if anyone could please help me with the following questions as for math I have been given a substitute teacher who is of little help.
Any help would be much appreciated, even if its just pointing me in the right direction
Equation 1:
Log (x-3) = 1 + Log 4 - Log x
Equation 2:
2-4a + 2 x 2-2a - 8 = 0
Equation 3:
Without using calculator, find the value of A that makes x = e^12 / 1-2e^12 a solution of the equation:
ln x - ln (ax+1) = 12
Thanks again Jake
Equation 1:
\log (x-3) = 1 + \log 4 - \log x
Rewrite 1 as a logarithm. Use the properties of logarithms to combine the logs on the right side into a single logarithm. Then "drop" the log from both sides, and solve.
Equation 2:
This is unreadable. What does the "-" right before the 4a and 2a mean? Are they subtractions? And is the "x" a variable or multiplication?
Equation 3:
\ln x - \ln (ax+1) = 12
Similar to #1. Rewrite 12 as a natural logarithm. Use the properties of logarithms to combine the logs on the left side into a single logarithm. Then "drop" the ln from both sides, and solve.
Thanks for your fast reply
Sorry Equation 2 is as follows, as the power symbol didnt work:
Thanks again
Thanks again
Again: is the "x" a variable, or is it a multiplication sign? If you mean multiplication, it would be much better to use an asterisk (*), like this: 2^(-4a) + 2*2^(-2a) - 8 = 0.
RGV
Thanks again
Let U = 2-2a; substitute, solve for u then find solutions for x
  • · Replies 16 ·
11K
  • · Replies 21 ·
  • · Replies 26 ·
