Neutrino Antineutrino annihilation possible?
  • Level: Graduate
  • Thread starter Thread starter Claustral
    Annihilation Neutrino
10 replies · 15K views
Claustral
As far as I know, the anihilation of an electron by a positron is an electromagnetic process described by QED. Neutrinos, however, do not participate in the elektromagnetic interaction. Does that mean a Antineutrino will not anihilate a Neutrino of the same kind? Is there an interaction between Neutrino and Antineutrinofields and how does it look like? Maybe the weak interaction can also cause anihilation processes?
Sure, an electron neutrino and an electron antineutrino can be annihilated into an electron-positron pair. In the electroweak standard model the leading-order diagram is a W-boson exchange diagram.
No, it's a [itex]Z^{0}[/itex]-boson exchange, since the total incoming (and outgoing) charge is zero.
There is a key difference between low-energy electron/positron and neutrino/antineutrino pairs, though. The former can annihilate into pairs of photons because the latters' masses (zero) are less than the electrons'. In the case of anti/neutrinos, however, no such lighter particles exist. They can bump into one another and form a Z0, but the latter is off mass shell so has to decay almost immediately, and the only pair it has enough energy to create when decaying is another anti/neutrino pair. In effect, therefore, everyday anti/neutrinos such as ones from the cosmic background cannot annihilate.
It is true that low-energetic neutrinos cannot annihilate similar to electrons/positrons, but with a W-boson exchange there are allowed Feynman diagrams. I would assume that the cross-section is negligible, but not 0.
Neutrinos have non-zero mass; and, as such can, at least in principle, annihilate to photons. The problem with this is that the annihilation involves a loop diagram with a highly off-shell W. This suppresses the cross-section significantly, making it essentially cosmologically irrelevant. But, it isn't correct to say that annihilation to photons is not allowed at all.
There is also t-channel W exchange. I don't know for sure, but suspect that it's the dominant process.
Ah, yes. The difference in cross-sections may be explained by the properties of the corresponding branching ratios for the decay of the corresponding weak vector boson.
