Measuring Speed in the Universe: A Puzzling Concept
The discussion revolves around the concept of measuring speed and time dilation in the universe, particularly in the context of special relativity. Participants explore how speed is relative to reference frames and the implications of this for aging when traveling at high velocities.
  • Some participants propose that speed can only be measured relative to another object, raising questions about how time dilation is defined.
  • Others argue that time dilation occurs as measured from a stationary frame, while the moving object perceives time passing normally.
  • A participant clarifies that the term "relative" in relativity refers to measurements relative to a reference frame, not just another object.
  • Questions arise about the aging of individuals traveling at high speeds compared to those who remain stationary, with some suggesting that the traveler would age less due to their acceleration.
  • It is noted that while speed is relative, acceleration is not, which affects the aging process differently for the traveler and stationary observers.
Participants express multiple competing views regarding the implications of speed and acceleration on aging, and the discussion remains unresolved with no consensus on the interpretations of these concepts.
There are limitations in the discussion regarding the assumptions made about reference frames and the effects of acceleration on aging, which remain unresolved.
This discussion may be of interest to those exploring concepts in special relativity, time dilation, and the nature of speed and reference frames in physics.
davies65
From what I understand, the speed of any object in the universe can only be measured relative to another object in the universe. . . .
If this is the case then how can we say time slows down for an object traveling at super high speed. Who is to say which object is moving at super high speed and which object is stationary?
Cheers,
davies65
Time slows down for a moving object only as measured by the "stationary" frame with respect to which it is moving. As far as the object itself is concerned, time is passing at the usual rate.
No one. Or better, any frame is just as good as any other. Speed is relative to whoever is measuring it and so is time dilation.
Actually, the "relative" in relativity refers to measurements relative to a reference frame, not relative to another object. You can certainly make a reference frame where a given object is at rest, but it isn't necessary. It is a subtle difference, but important.
In any inertial reference frame the moving clock is ticking slow.
Ok thanks. So if take off in my spaceship and zoom around the universe at a velocity close to the speed of light then come back to Earth will all of my school friends be older than me?
More likely they'll all be long dead if you are traveling for any length of time at "close to the speed of light".
But why wouldn't I be the one who has aged more quickley? Who is moving fast and who is stationary?
Because you are the one who accelerated. Your dead friends were not accelerated to a v close to c, but you were. Even though it looked like they were from your point of view, the only one who was actually accelerated was you.
Therefore, you don't age more quickly, they do.
As DaleSpam said in #3, it's motion in an Inertial Reference Frame (IRF) that determines aging. You can do the calculation in any IRF but you will find that they all produce the same results. Your friends could remain at low speed in an IRF but you can't. Maybe you are at low speed for part of the time in a different IRF while your friends are at high speed, but you'll always spend enough time at an even higher speed that you end up aging less.
Probably what you're confused on here is that SPEED is relative but acceleration is not and you, as has already been pointed out, are the one who is accelerating.
Seems reasonable. Thanks for the replies :)
  • · Replies 51 ·
  • · Replies 25 ·
  • · Replies 27 ·
  • · Replies 18 ·
  • · Replies 25 ·
  • · Replies 57 ·
  • · Replies 22 ·
