Helping Friends Connect Behind Military Base Firewall: Tips & Tricks
  • Thread starter Thread starter DarkAnt
The discussion revolves around the challenges of connecting friends to an internet connection from a military base, which is limited by a slow speed and restricted by a firewall and proxy server. Participants explore potential solutions and technical considerations related to internet sharing and connectivity options.
  • One participant describes the slow internet speed on the military base, attributing it to bandwidth limitations shared among many users.
  • Another participant suggests that while it is possible for the friend to use the internet connection, it won't increase the modem's speed due to hardware limitations.
  • A different participant emphasizes that the slow speed is due to bandwidth allocation rather than hardware issues.
  • One participant expresses uncertainty about VPNs being the right solution and seeks clarification on how to allow someone far away to connect to their internet.
  • Another participant requests technical details about the friend's connection setup to better understand the limitations involved.
  • A participant mentions that the connection is through a 56k modem and is routed through a proxy server and firewall, indicating that they believe it is possible to connect despite these restrictions.
  • One participant expresses frustration and suggests deleting the thread, indicating a lack of progress in the discussion.
Participants express differing views on the nature of the limitations affecting the internet connection, with some attributing it to hardware constraints while others argue it is primarily a bandwidth issue. The discussion remains unresolved regarding the best approach to facilitate the connection.
Participants have not reached a consensus on the technical feasibility of connecting to the internet from a distance or the effectiveness of potential solutions like VPNs. Uncertainties about the specific technical setup and limitations of the military base's internet connection are present.
DarkAnt
ok, i was talking to a friend who lives on a military base. There is only one internet option, the military connection. It is supposed to go at 56k but it actually runs about 14k, yea... I know, its sad, mostly because I used to live there too and I had that connection as well. Anyway, when I was talking to my friend he said he knew a person who was able to let my friend connect to his connection. I would like to hook up a friend or two who lives there but I don't know how. Does anyone have any idea how to let someone connect to my connection?
oh, the connection my friend is using is behind a firewall and a proxy server (which could make things a bit more difficult).
Any help or lead in the right direction would be very much appreciated. Thank you
Computer science news on Phys.org
yes, it is possible for your friend to use your internet connection, but it isn't going to speed up his modem. It is a hardware limitation and you can't do anything about it. The only reason you would want to let someone use your net connection is to get around some form of censorship or blocking software on another person's network.
If your still interested you might want to look into virtual private networks (VPN).
thank you, I know it isn't a hardware limitation. its because the army only has so much bandwidth and they use most of it doing stuff on the base, whatever is left over is shared with 2,500 people who want to use the net. Things tend to go slow because of this. Thanks again
ok, I looked at some VPNs but I don't believe that's what I'm looking for .I could be wrong, I'm way over my head. Basically what I want to do is let someone half way across the world connect to my internet connection and be able to use that as their internet connection.
If the army only allows a certain physical connection, then that's all he gets. Its a hardware issue that you can't get around. There is only one set of wires there.
It would help explain it to you though if you could give us some technical info about his connection, for example, does he use a modem or a network card?
Its like a normal internet connection with a 56k modem (no lan involved). You dial up just like a modem connection too. The only difference is that everything it is sent through a proxy server and a firewall. I know it can be done since someone else has already done it.
If you have no idea what I am talking about (mostly because I don't really know what I'm talking about) then could someone send me some places to get some good tunnels?
I give up, someone just delete this thread please.
