1/7 in decimal form is .142857
  • Context: High School
  • Thread starter Thread starter T@P
    Form
The decimal representation of 1/7 is 0.142857, which is a repeating decimal with a cycle of six digits. Each subsequent fraction, such as 2/7 (0.285714) and 3/7 (0.428571), is a rearrangement of these digits. The number 142857 is divisible by 999, and this property is linked to its representation as a cyclic number, where the decimal expansion of 1/n for certain primes results in repeating sequences. The discussion highlights the mathematical principles behind these patterns, including modular arithmetic and the behavior of remainders.
  • Cyclic numbers
  • Modular arithmetic
  • Decimal representation of fractions
  • Prime factorization
  • Study the properties of cyclic numbers in number theory
  • Learn about modular arithmetic and its applications
  • Explore the concept of repeating decimals and their representations
  • Investigate the relationship between prime numbers and decimal expansions
Mathematicians, educators, students studying number theory, and anyone interested in the properties of fractions and their decimal representations.
T@P
2/7 is a rearangement of those numbers, 3/7 is too etc. anyone know why? (btw 142857 is divible by 999)
Mathematics news on Phys.org
\frac{1}{7} = 0. \dot1 4285 \dot7
\frac{2}{7} = 0.\dot2 8571 \dot4
\frac{3}{7} = 0.\dot4 2857 \dot1
\frac{4}{7} = 0.\dot5 7142\dot8
\frac{5}{7} = 0.\dot7 1428\dot5
\frac{6}{7} = 0.\dot8 5714\dot2
The pattern that I can see is that as the nominator increases the first number increases within the numbers there are. 1 then 2 then 4 then 5 etc... Also all the numbers stay in order. Why, though, I do not know.
The Bob (2004 ©)
Nope.1/7 is:
\frac{1}{7}=0.(142857) (1)
,which is a totally different number from the one u've written.Yours is
0.142757=\frac{142857}{1000000}(2)
and has 6 decimals,while mine is
0.(142857)=\frac{142857}{999999}=\frac{1}{7}(3)
and has an infinite number of decimals.
What do u mean by rearrangement??
Daniel.
PS.From (3) u get
142857\cdot 7=999999=999\cdot 1001=999\cdot 7\cdot 11\cdot 13
,from which u get the decomposition of 142857 in prime factors.
i meant rearangement of the first 6 digits, since they repeat you can think of it as 142857/999999, and incidentaly it reduces. actually i think that explains why its divisible by 999.
The same holds for any number n which has the property that \frac{1}{n} has n-1 repeating digits.
Here's what happens:
Code:
     1 = 1 mod 7
    10 = 3 mod 7
   100 = 2 mod 7
  1000 = 6 mod 7
 10000 = 4 mod 7
100000 = 5 mod 7
And, calculating the digits after the decimal point is very much like multiplying the denominator by 10, and calculating the last digit and a new remainder, so you cycle through the six possible remainders.
NateTG has it pretty well figured out, but I never did see until now. By the way, they are called cyclic numbers and can be googled.
We have 1/7 = \overline{.142857}. (Where the overline means the period is repeated and repeated)
The first decimal,1, represents how many times 7 goes into 10 whole , 14 represents how many times 7 goes whole into 100, 142 for 1000, etc.
Thus if we look at 100/7 = 14\overline{.285714}
But 100/7 = 14 +2/7, so we end up with 2/7= \overline{.285714}
Thus as NateTG tells us to get the full array we need to have a cycle of N-1 digits, where 10^(N-1)==1 Mod N. This will only possibly occur when N = p, a prime.
For example, let's look at 1/21 = \overline{.047619}
The powers of 10^x modulo 21 are 1,10,16,13,4,19,1...for x=0,1,2,3,4,5,6...
i.e. 10^6 == 10^0==1 Modulo 21, and the series has finished.
Thus the cycle will repeat for some numbers, say, 16/21 = \overline{.761904}
But, of course, since there are only 6 possibilities, some numbers will not cycle that way, for example we have 2/21 = \overline{.095238}
  • · Replies 171 ·
10K
  • · Replies 25 ·
