1st year high school geometry proof
  • Thread starter Thread starter Iamconfused123
    Geometry Triangle
14 replies · 3K views · last reply
Iamconfused123
Above the sides AB and CD of paralelogram ABCD two equilateral triangle are formed ADN and DCM. Prove that triangle BMN is equilateral.
SAS - side, angle, side
I have proved that triangles around the equilateral triangle are congruent, but I don't know how to prove that they are arranged in such a way that they actually do form an equilateral triangle. Like, do I write that they do form an equilateral because it's given in the problem that triangles are drawn above the AD and CD sides and that because of that the vertices MNB are equally distanced from each other or? Or should I prove that triangle MNB has all angles of 60 degrees? But how do I do that, all I know for sure is that rectangle has 90 degree angles and that triangles ADN and DCM have 60 degree interior angles.
photo is in the attatchments
Thank you
  • Hand-drawn geometry diagram on grid paper: a rectangle ABCD with equilateral triangles drawn outward on sides AD and DC, apexes N and M, and dashed segment NB and MB forming a triangle with vertex B, with tick marks on equal sides and a caption reading triangle NAD congruent BCM congruent MDN by SAS.
What's the definition of an equilateral triangle?
You have three triangles ABN, BCM, DMN. What can you say about them?
The angle NDM can be computed by 360-60-60-90
They have all same sides and all same angles
EDIT: Equilateral has all same sides and all same angles. And these 3 are congruent, they are the same.
I mean, yes, I know. But, like, I still don't know these angles(circled ones)
  • Hand-drawn geometry sketch on grid paper: a square ABCD with triangles MCB and NAD attached outward on sides BC and AD, apex points M and N, with tick marks and blue circled angles; below it reads triangle NAD congruent to BCM congruent to MDN, SAS.
I don't think you need them.
The three dashed lines are all equal and share the three points B, M, and N. Hence you have an equilateral triangle
Equilateral triangles have three properties:
1) three sides are equal
2) three interior angles are equal and hence are 60 degrees
3) there are three lines of symmetry
Just by knowing it's an equilateral triangle from the sides and you know it has three 60-degree angles.
Yes, but for example, what if we had 3 congruent triangles not connected by parallelogram and triangles on the sides of paralelogram, we'd still have three congruent triangles, but they wouldn't form equilateral triangle.
I know that there is equilateral triangle, the scheme is there, all sides equal, all angles equal. But how do I prove that other three triangles are position in such a way that they actually do form an equilateral triangle, since that is the base of our proof(proof is based on the fact that other three triangles are congruent and positioned in a proper way, we have proved that they are congruent , but how do we prove that they are positioned in such a way that they actually form eqlat triangle, we don't know other two angles and they seem to be pretty similar, we can't know for sure).
I feel like I am supposed to explain that the triangle is eqlat with information given in the problem. Like, it's eqlat because eqlat triangles on the sides of the parallelogram form a shape that makes eqlat triangle when NBM points are connected.
It's not so much how can I prove that NBM is qlat triangle, more of a what should I give as a reason for concluding so. If I say because these three are congruent then I need to know how are they positioned and I don't know the angles. The other explnanation would be; because that is the property of the shape we have gotten by drawing eqlat triangles on the side of parallelogram.
If you prove 3 sides of a triangle are all equal , then it's an equilateral triangle. And you have proven - you are done!
You should be more careful. The bottom line of your diagram starts with triangle NAD. Shouldn't that be NAB? One thing you learn in math is to be very careful. It's a learned skill.
It is NAB, not sure what you refer to
Did you take a close look at the hand-written work you posted? That sure looks like NAD to me.
Oh, I see now. I was looking at the sketch, there is all fine, didn't even check the writing. I should be more careful. Thanks
Handwritten geometry sketch on grid paper of a three-dimensional figure with points M, N, A, B, C and D, with coloured edges highlighted and a caption reading triangle NAD congruent to BCM congruent to MDN, SAS.
Strictly speaking we should write: $$\Delta NAB \cong \Delta BCM \cong \Delta NDM\;SAS$$ Letter order is important when you are indicating either congruency or similarity of two or more triangles.
