2-norm Pseudoinverse Upper Bound
3 replies · 5K views · last reply
baggiano
Hello
I'm trying to show that the following upper bound on the matrix 2-norm is true:
[itex]\left\|(AB)^+\right\|_2\leq\left\|A^+\right\|_2 \left\|B^+\right\|_2[/itex]
where + is the matrix pseudoinverse and [itex]A\in\Re^{n\times m}[/itex] and [itex]B\in\Re^{m\times p}[/itex] are full-rank matrices with [itex]n\geq m\geq p[/itex].
Any hint how I can show it?
Thanks in advance!
Bag
Are you sure that [itex]m\ge p[/itex] and not [itex]p\ge m[/itex]?
Also I assume that by pseudoinverse you mean the Moore-Penrose pseudoinverse.
If [itex]n\ge m[/itex] and [itex]p\ge m[/itex], then [itex](AB)^+ =B^+ A^+[/itex] holds, and this identity gives your estimate.
If [itex]n\ge m\ge p[/itex], then [itex]A[/itex], [itex]B[/itex] and so [itex]AB[/itex] are left invertible. For a left invertible matrix [itex]A[/itex], the Moore-Penrose pseudoinverse [itex]A^+[/itex] is the minimal left inverse, [itex]A^{min}_L = (A^*A)^{-1}A^*[/itex].
The minimal left inverse [itex]A^{min}_L[/itex] has the property that for any other left inverse [itex]A_L[/itex] of [itex]A[/itex] we have [itex]A^{min}_L = P_{Ran (A)} A_L[/itex], where [itex]P_{Ran (A)}[/itex] is the orthogonal projection onto the range (column space) of [itex]A[/itex]. In particular, this implies that the norm of the minimal left inverse is the minimal possible norm of a left inverse.
Now let us gather all this information together: both [itex]A[/itex] and [itex]B[/itex], are left invertible, so [itex]A^+[/itex] and [itex]B^+[/itex] are the minimal left inverses of [itex]A[/itex] and [itex]B[/itex] respectively. Therefore, [itex]B^+A^+[/itex] is a left inverse of [itex]AB[/itex]; generally it is not the minimal left inverse, but the minimality property for the norm of minimal left inverse implies
[itex] \|(AB)^+\| \le \| B^+A^+\| \le\|B^+\|\cdot\|A^+\|[/itex]
Hello
Thanks a lot for the details of your illustration.
Yes, [itex]m\geq p[/itex] was actually correct.
In the fourth paragraph of your reply you say that [itex]A_L^{min}=P_{Ran(A)}A_L[/itex]. Shouldn't it be [itex]A_L^{min}=A_LP_{Ran(A)}[/itex] instead?
Thanks again!
Bag
Yes, it should be [itex]A_L^{min} = A_L^{min} P_{Ran(A)}[/itex].
