2D inelastic collision and K of CM
The discussion focuses on an inelastic collision between two cars, where Car 1 (1500 kg) traveling north at 80 km/h collides with Car 2 (3500 kg) heading east at 50 km/h. The resulting wreck's speed is approximately 12 m/s at an angle of 34.44 degrees. The kinetic energy lost during the collision is calculated to be about 360 kJ. The kinetic energy of the center of mass (CM) remains constant before and after the collision, while the lost kinetic energy is attributed to deformation and heat.
  • Understanding of inelastic collisions
  • Knowledge of momentum conservation principles
  • Familiarity with kinetic energy calculations
  • Basic vector analysis for velocity and angle determination
  • Study the principles of inelastic collisions in detail
  • Learn about momentum conservation in multi-body systems
  • Explore kinetic energy transformations during collisions
  • Investigate the effects of deformation and heat in collisions
Physics students, automotive engineers, and anyone interested in understanding the dynamics of collisions and energy conservation principles.
sci-doo
Car 1 (1500kg) is heading north 80km/h, Car 2 (3500kg) is heading east 50km/h. They collide inelastically.
a.) Speed and direction of the wreck (car 1 + car 2)?
b.) The kinetic energy lost?
HERE I HAVE A PROBLEM:
c.) What is the kinetic energy of the two-particle systems center of mass before and after the collision?
d.) Where was the lost kinetic energy hidden before the collision?
2. The attempt at a solution
a. is just vector sum p1+p2 where I can get the velocity by dividing it with the masses (about 12m/s), I can get the angle too (34,438... deg)
b. wrecks K minus K of car 1 and car 2 = - 360532,40... J so about 360 kJ lost
c. But this one I don't understand. I'd say it stays the same, because... well, that's what I calculated (CM from the v-vectors = v of CM), yet I don't really believe it...
d. ... after all shouldn't the K be lost to deformation of bodies (+heat etc.)? Does the K of CM stay the same anyways?
Ok, I found something useful on the net:
http://courses.washington.edu/ph122mo/A08/MT3info.html"
# Inelastic collisions
* momentum is still conserved
* kinetic energy of center of mass motion cannot be lost
* maximum energy loss for items sticking together after collision
And that is really all I needed to know. :approve:
  • · Replies 33 ·
