2nd order ODE's, variation of parameters and the notorious constraint
  • Context: Undergrad
  • Thread starter Thread starter haushofer
The discussion revolves around the method of Variation of Parameters for solving second-order ordinary differential equations (ODEs), specifically focusing on the constraints involved in the method and their implications for the solutions. Participants explore the mathematical derivations and the effects of different constraints on the coefficients of the particular solution.
  • One participant describes the method of Variation of Parameters and introduces a constraint that leads to a unique solution for the coefficients in the particular solution.
  • The same participant questions how a different constraint affects the solution, suggesting that it may lead to the same particular solution despite changing the coefficients.
  • Another participant points out an algebraic error in the first participant's calculations, providing a corrected derivation that shows how the constraints interact with the solution.
  • A later reply acknowledges the correction and expresses gratitude, indicating that the clarification helped resolve their confusion regarding the role of the constraints.
  • Further contributions discuss the nature of the particular solution and how it can be determined up to a complementary function, exploring the conditions under which different choices of coefficients yield equivalent results.
  • Participants explore the implications of the relationship between the coefficients and the Wronskian, noting that certain dependencies can lead to the same overall solution despite changes in the coefficients.
Participants exhibit a mix of agreement and disagreement, particularly regarding the implications of different constraints on the coefficients and the resulting particular solutions. Some participants agree on the necessity of the constraints, while others challenge the algebraic steps leading to conclusions about the solutions.
There are unresolved mathematical steps and dependencies on definitions related to the constraints and their effects on the solutions. The discussion highlights the complexity of the method and the need for careful consideration of the assumptions involved.
haushofer
Insights Author
TL;DR
How to show that if the usual constraint in the method of variation of parameters is replaced by a more general one, the particular solution doesn't change?
Hi folks,
I decided to brush up my knowledge of Green's functions and Differential Equations, and came across this chapter,
https://people.uncw.edu/hermanr/mat463/odebook/book/greens.pdf
of some unknown book (if anybody recognizes it, I'd like to know the title). In 8.3 (page 265) the well-known method of "Variation of Parameters" is treated for 2nd order differential equations in self-adjoint form (which can easily be made more general):
$$\frac{d}{dx}\Bigl(p(x) \frac{dy}{dx}\Bigr) + q(x)y(x)=f(x)$$
So we use for our particular solution the Ansatz
$$y_p(x) = c_1(x)y_1(x)+c_2(x)y_2(x)$$
and plug it in. The first derivative becomes
$$y'_p(x) = c_1(x)y'_1(x)+c_2(x)y'_2(x) + c'_1(x)y_1(x)+c'_2(x)y_2(x)$$
Then follows the notorious constraint which confuses so many students:
$$c'_1(x)y_1(x)+c'_2(x)y_2(x) \equiv 0 \ \ \ \ \ \ \ \ (1)$$
I understand this part: we introduced 2 new functions c_i(x) (i = 1,2), and with only 1 constraint (the original ODE) we will not get a unique solution. If we would have imposed e.g.
$$c_1(x)y'_1(x)+c'_2(x)y'_2(x) \equiv 0$$
we would obtain an equation with 2nd order derivatives for c_i(x) (i = 1,2), which would give us the same kind of problem for these coefficients. So that wouldn't work (but I'm not sure if this would be consistent...) So that motivates us to impose a condition on the derivatives of c_i(x). So we impose the constraint (1) and this leads to two equations for only the two c'_i(x), which is easily solved. An integration then gives us the c_i(x), and the particular solution coincides with the one we would obtain by the Green's function. So far, so good.
My question is about an exercise on page 302 of the notes: exercise 2. It says that if we now impose (this is a restriction, not a mere relabeling!)
$$c'_1(x)y_1(x)+c'_2(x)y_2(x) \equiv h(x) \ \ \ \ \ \ \ \ (2)$$
for some function h(x), "show that one gets the same particular solution". And this is where I get stuck.
So I just redid the calculation but with constraint (1) replaced by (2). I will show my work how the usual results change. With constraint (2) the equation (8.10) is changed as follows:
$$[p(x)h(x)]' + c'_1(x)y'_1(x)+c'_2(x)y'_2(x) = \frac{f(x)}{p(x)}$$
i.e. one gets an extra total derivative [p(x)h(x)]' on the left hand side. Along with the constraint (2) we can solve for c'_i(x) (i = 1,2), in which I denoted the Wronskian with W and drop the arguments for notation sake (every function depends on x):
\begin{split}
c'_1 = W^{-1}\Bigl[hy_2' - (\frac{f}{p} - [ph]')y_2\Bigr] \\
c'_2 = W^{-1}\Bigl[-hy_1' + (\frac{f}{p} - [ph]')y_1 \Bigr]
\end{split}
So our constraint (2) changes these equations (eqn. 8.12 in the notes) as follows:
\begin{split}
c'_1 \rightarrow c'_1 + \frac{hy_2'}{W} +\frac{(ph)'y_2'}{W} \\
c'_2 \rightarrow c'_2 - \frac{hy_1'}{W} - \frac{(ph)'y_1'}{W}
\end{split}
and indeed, the extra terms disappear if we apply the constraint (1) (i.e. h(x) \equiv 0). So if we now integrate both equations, the coefficients themselves are now changed with respect to constraint (1) as follows:
$$\begin{split}
c_1(x) \rightarrow c_1(x) + \int_{x_0}^x \frac{h(\xi)y_2'(\xi)}{W(\xi)} d\xi +\int_{x_0}^x \frac{[p(\xi)h(\xi)]'y_2(\xi)}{W(\xi)} d\xi \\
c_2(x) \rightarrow c_2(x) - \int_{x_0}^x \frac{h(\xi)y_1'(\xi)}{W(\xi)} d\xi - \int_{x_0}^x \frac{[p(\xi)h(\xi)]'y_1(\xi)}{W(\xi)} d\xi \end{split}
If our particular solution is kept unchanged, this means that our coefficients merely change by a constant. So I guess in both expression the two extra integrals which show up due to constraint (2) have to cancel. Or maybe they combine to merely a constant, such that in the total solution the constant coefficients in front of the homogenous part merely changes, but that's not what the exercise says). But I don't see how; some partial integration with the triple product under the integral sign doesn't do it, and the condition p(x)W(x) = cnst. which is mentioned in the notes in equation (8.13) also doesn't help me. If I plug these coefficients into the expansion of the particular solution, I also don't see how terms from both coefficients could cancel against each other.
So my question: how do I show this? Am I right to consider constraint (1) as a particular "gauge choice" of constraint (2), and that both the coefficients merely change by some constants? Or am I misunderstanding the core of the method?
Any help is greatly appreciated! :)
I think you have an error in the algebra.
Substituting the ansatz and condition into the ODE, we should find
$$\begin{split} p(c_1'y_1' + c_2'y_2') &= f - (ph)' \\ c_1'y_1 + c_2'y_2 &= h \end{split}$$ hence leading to $$\begin{split}
c_1' &= -\frac{(f - (ph)')y_2}{pW} + \frac{hy_2'}W = -\frac{fy_2}{pW} + \frac{(phy_2)'}{pW}\\
c_2' &= \frac{(f - (ph)')y_1}{pW} - \frac{hy_1'}W = \frac{fy_1}{pW} - \frac{(phy_1)'}{pW}
\end{split} $$ so that $$\begin{split}
c_1 &\mapsto c_1 + \int_0^x\frac{(phy_2)'}{pW}\,d\zeta \\
c_2 &\mapsto c_2 - \int_0^x\frac{(phy_1)'}{pW}\,d\zeta \end{split}.$$ Since ##pW## is constant we obtain $$\begin{split}
c_1y_1 + c_2y_2 &\mapsto \left(c_1(x) + \frac1{pW} [ phy_2 ]_0^x\right)y_1(x) +\left(c_2(x) - \frac1{pW} [ phy_1 ]_0^x\right)y_2(x) \\
&= \left(c_1(x) - \frac{h(0)y_2(0)}{W(0)}\right)y_1(x) + \left(c_2(x) + \frac{h(0)y_1(0)}{W(0)}\right)y_2(x)\end{split}$$ as required. Thus although ##c_1## and ##c_2## do not change by constants, the linear combination ##c_1y_1 + c_2y_2## changes by a complementary function.
Yes, thanks a lot, you're absolutely right. Reading your post I redid the calculation and indeed was missing a factor of p(x) which makes all the difference! I had a strong feeling pW=const. should play a role, but couldn't see it of course. You saved my day!
I've seen quite some texts on this method, and somehow this is the only text I've seen with this exercise, which makes the constraint a lot more sensible. Didactically it's a very powerfull exercise. So hopefully others with similar issues and seeing this topic will be helped too.
Again, many thanks, it bugged me a lot 😂😇
Thinking about it more closely, we want ##c_1y_1 + c_2y_2## to be a particular solution. But we're happy if it's only determined up to a complemenary function, because we were going to add one anyway. Two choices of ##(c_1 ,c_2)## cause ##c_1y_1 + c_2y_2## to differ by a complementary function if and only if their difference ##(\Delta c_1)y_1 + (\Delta c_2)y_2## is a complementary function. This will be the case if ##\Delta c_1## and ##\Delta c_2## are constant, but will also be the case if $$(\Delta c_1,\Delta c_2) = (\alpha y_2 + \beta, -\alpha y_1 + \gamma)$$ where ##\beta## and ##\gamma## are constant but ##\alpha## can depend on ##x##. I haven't checked, but I am confident that this is the most general form for ##(\Delta c_1,\Delta c_2)## since it is linear in ##(y_1,y_2)## and we are dealing with a linear problem. For this choice of ##(\Delta c_1,\Delta c_2)## we find $$y_1(\Delta c_1)' + y_2(\Delta c_2)' = \alpha W.$$ This is consistent with the working in my previous post, where we can simplify $$
\frac{(phy_i)'}{pW} = \left( \frac{phy_i}{pW} \right)' = \left( \frac{ hy_i}{W} \right)'$$ due to ##pW## being constant.
EDIT: I have now checked, and this is the most general affine dependence of ##(\Delta c_1, \Delta c_2)## on ##(y_1,,y_2)## which results in ##y_1 \Delta c_1 + y_2 \Delta c_2## being a complementary function.
Yes, that's a gread addition. It leaves me with the final question: are all constraints one can impose consistent? And how can we check that? Working everything out for other constraints leaves us in general with second order derivatives and the coefficients themselves, giving the same problem we wanted to solve by introducing those non-constant coefficients.
  • · Replies 0 ·
