3-star triangular orbit possible?
  • Level: Graduate
  • Thread starter CookieSalesman
    Orbit
18 replies · 5K views · last reply
CookieSalesman
Apparently 3-star systems aren't really 'doable' as in two stars, with one in-between- but nested binaries are possible.
So is it 'possible' for 3 stars to maintain at least a somewhat stable triangular configuration?
If you mean "Can three star orbit the same center of gravity with the same orbital period?", the answer is no.
If three stars are placed into such an orbit, then the orbit of the smallest one will always be unstable - a slight change in its orbit which moves it towards either of the other two stars will result in a continued acceleration in that direction. That will break the "triangular configuration" you are looking for. But a figure 8 configuration might be possible.
Here is a link to a page that describes some of these orbits.
http://www.atlasoftheuniverse.com/orbits.html
I'm not sure what you mean.
Can you essentially place 3 stars on equidistant points on a circle?
As a result I don't think there are 'smallest' orbits like you said.
You really should look at the link he provided. That shows the possible stable orbits of 3 stars. It answers your question, which is why he provided it.
Thanks I did look at it.
But anyway no, I didn't understand if it would answer my question. I was unclear if he understood my question properly. I hadn't understood if the page considered my question.
Additionally of course this doesn't explain what the issue with my triangular orbit.
But he DID explain why your proposal is not a stable orbit although I suppose if you were to insist on the staggeringly unlikely existence of 3 stars of identical mass, his explanation would not hold.
IFF the stars are all the same mass then a Kempler Rosette formation can occur. 3 is very minimal and least stable setup, 2 is obviously the most stable but not considered a rosette, but one can make Kempler Rosettes of 3, 4, 5, 6 and 7 or more stars if their masses are the same or very very close to it. They must be in a ring of the same radius and all moving at the same speed about their joint center of gravity. There can also be a star in the center of the formation as well and still keep it's stability.
These orbital ideas were shown and mathematically proven by Kempler. They ARE special cases, and would tend to be either extreme coincidence, or an artificially made structure. Has shown up in various Science Fiction at times, but is based on real math. (Larry Niven does a good example of the form).
Kempler rosettes are unstable.
Lagrange points are stable - if the mass of two orbiting bodies combined does not exceed about 3,8 % of primary mass.
Therefore, it should be possible to have an equilateral triangle of a B dwarf of 5,0 solar masses and two red dwarfs of 0,09 solar masses each.
By smallest one, I meant the smallest star, not the smallest orbit.
If you put three stars of the same mass into an orbit about a common center of gravity where they start out as points on an equilateral triangle with circular orbits, ideally they would stay in those orbits and remain equidistant from each other. But that is not stable. Any slight variation will become amplified and the paths will no longer be circles or ellipses.
The only reason I picked on the smallest one is that, if it is small enough, you basically have a two-body system (which is stable) with a small visitor. So there is always a problem with nudging the smallest one.
Oh of course, right.
Alright well that answers the post. Thanks folks, not necessarily that I understood all words and explanations, but got the idea.
No. The stability of Lagrange points depends on mass. For suitable masses, they are stable.
With a triangle, none are at the Lagrange point of any of the others. I believe I read that with six, there is more stability because they do line up with Lagrange points.
Um, no. Lagrange points L4 and L5 each form an equilateral triangle with the other two masses.
.Scott, I believe you are correct that with 6 masses of same size and orbital speed and distance, within a plane, then they should be able to hold their form, a 7th, central star, of either similar or larger mass, would help to stabilize the system. Each of the masses would be at 60 degrees from each other which conforms to the Lagrangian Point form of balance.
Normal Lagrangian Points L3, L4 and L5, along with the 'prime' mass, about a central point, you would need to add points between L3 and L4, and Between L3 and L5 at the same 60 degrees between masses and orbital distance/speed. As far as I know this is the only basic known theoretical stable Kempler Rosette, with 7 masses being the most stable, but it is of a special set of very unlikely configurations for it to happen very often naturally.
3 masses would be subject to outside distortion of orbits with no or diminishing stabilization from the other masses, the old 3-body problem rears it's head. The 6 or preferably 7 mass solution gets around that as it is a self-reinforcing system of reverberations of orbits that is able to maintain a reasonably long-term stability.
However, Space and Time are a very large playground within to work, and all of that energy matters!
Um? And how stable is that if the masses are slightly different, and distances slightly deviate?
Thanks Tom G. Decades ago, on a 386 puter, I spent a few weeks playing around with similar program for the era, that would take the body masses masses and orbital dynamics and run the calculations to give accurate representation. With careful and precise setup you could form long-lasting 7-point Kempler Rosettes, I had one run for 3 days before I shut it off.
Like I said before, they would be an extremely unlikely thing to form in Nature, but Not Impossible.
But yes, take the time to play with some of the orbital dynamics programs and have then extrapolate for a few millions of orbits with different patterns and setups. There are literally endless possibilities of combinations
There is a stable three-body system that has all three bodies following a lemniscate (figure 8) orbit, provided that all of the bodies have the same mass. The odds that this kind of system might occur naturally are very low. (Like, there might be one of them in this universe low.) This is an exception to the rule in which systems of 3 bodies or more, in primary contact with each other, are unstable on long time scales.
Otherwise, you have to pack binaries in orbital hierarchies. Two stars orbit each other. Another two stars orbit each other. The two sets of binaries orbit on a scale considerably wider than the separation of the most widely separated binary.
