3D Physics problem(Forces and Tension)
27 replies · 4K views
masterchiefo
metal piece = 300N
As this metal piece is in balance, what is the tension in each cable?
Picture of the problem in attachment.
W = 300*[0 0 1]
D to A:
vtda = tda [sin(37), sin(37)*sin(90), -cos(37)]
D to B:
vtdb = tdb [sin(37)*sin(90), sin(37), - cos(37)]
D to C
vtdc = tdc [cos(30)*sin(37), -sin(30)*sin(37), -cos(37)]
solve([0 0 0]=300*[0 0 1])+vtda+vtdb+vtdb, {tda,tdb,tdc}
I have been trying to find the mistake for 3 hours but I really can't find it :/
When I solve with my TI calculator I get a "false"
thank you very much
Let the tensions in the 3 cables be ##T_1##, ##T_2## and ##T_3## .
It is clear that you'll need a system of 3 equations to solve this problem. Luckily, the coordinate system is set-up in such a way that the z axis is the perpendicular from the surface (it is an assumption that I'm making after looking at the diagram, and I'm 99% sure that its the actual case).
You already know that the metal piece is in equilibrium. This means that the resultant of the x and y components of the tensions equals 0, whereas the resultant of the z components of the tensions equals to the weight of the piece. Can you set up the required 3 equations?
One tip: always set up the algebraic/vector equation first, and substitute the numbers later. That way, it's always easier to spot any mistakes.
Hi chief,
1. What is this funny language you are writing in ?
2. What are the units of angle in your TI thingy? degrees or radians ?
3. 37 is approximate, 3/5 for the sine is exact. idem 4/5 for the cos.
4. z is downwards, your coordinate system is left-handed ? Bad habit!
5. In the x-direction vtda and vtdc pull in different directions. I don't see that in your expressions
6. sin(90) = 0. Easier to use the shorter form ? Less insightful, I admit.
[edit] slow typist
@PWiz: solve(...) appears to be solving (almost) exactly the three equations you describe. El Jefe does the right thing, he/she doesn't do the thing completely right, though.
BvU said:
Hi chief,
[edit] slow typist
its in degree
I am using directional cosine.
Also is 300*[0 0 1] correct since Z is downward?
Yes but ropes are not symmetric around, so z components are not equals.
z is downward? how would they be different? only x and y has to be different for each rope.
see again angles and write the correct vectors.
sorry I really don't understand how Z is different to each of the rope, z is same direction for all of them since its downward. and the angle between each rope and the middle line is equal to every rope.
Dear chief,
You are not correct. Z components follow once you found the components in the xy plane.
To get going. do pay attention to my remark #5.
to make zero x and y components the tension on C must be larger than other two.
BvU said:
Dear chief,
yes I fixed that on my calculator put still get false as an answer.
Theo, chief has allowed the tensions to be different!
BvU said:
Dear chief,
W = 300*[0 0 1]
vtda = tda [sin(37), sin(37)*sin(90), cos(37)]
vtdb = tdb [sin(37)*cos(90), sin(37), cos(37)]
vtdc = tdc [-cos(30)*sin(37), -cos(60)*sin(37), cos(37)]
masterchiefo said:
W = 300*[0 0 1]
Your writing notation is rather difficult to follow (it's almost as if you're posting your calculator input). Can you change this?
thats how we have learned to write notation on paper, I am not sure how to make this more easy to understand :(
Looks good to me. I have no problem solving by hand.
Don't know the proper TI incantation language.
Well you could perhaps call the origin of the coordinate system O and the bottom of the hook D.
Then you can describe angles much more easily. For example, cos (DAO) = 0.6 , etc.
I don't know if it's just me, but this is how I learned geometric description in middle school :woot:
How about
solve([0 0 0]=300*[0 0 1]+vtda+vtdb+vtdb), {tda,tdb,tdc} instead of
Oh, and if W is pulling down, it's only fair to have vtda, vtdb and vtdc pull upwards. Since 4/5 is positive, I suggest
solve([0 0 0]=300*[0 0 ##\bf -##1]+vtda+vtdb+vtdb), {tda,tdb,tdc}
BvU said:
:nb)
That is suggestive.
Just curious what the chief has found
Hello everyone,
I appreciate everyone who helped, I thank you.
I found a very stupid mistake in my calculator setting. so everything is good now.
Still curious what the chief has found -- but much more reassured. :nb):biggrin:
For the record, for statistics and for posteriority: what was it ? (And for ego -- or not --) : did it have anything to do with signs, brackets, or any of the items in post #3 ?
Its a very weird bug, but when I take the solve function from my calc in the librairy, it gives me FALSE, but when I write solve with the keypad...it works :O
I don't mean the bug, I mean the tensions
And for the solve incantation, which one was the correct one ?
And for the signs: how did they end up ?
Do you also see how to solve this without a calculator (just in case it let's you down again) ?
tda: -137.26
tdb: -79.2468
tdc: -158.494
yes I figured how to do this by hand.
Well done, thanks!
