4D: mimimum distance between point and parametric line
10 replies · 6K views · last reply
dustydude
There is points:
P=(1,2,3,4)
Q=(4,3,2,1)
and line L passes through P and is parallel to A
A=(1,1,1,1).
X(t) is anypoint on line L.
1. Find the distance between X and Q as a function of t.
2. Find the minimum distance between Q and the line.(which is 2(51/2))
Parametric equations...
distance between two points.
Im really not sure if my approach is right at all... i just want to understand where I am going wrong.
For 1.
I tried the parametric equation of the line which is
X(t)=P+At
to go from X(t) to Q its
X(t)-Q=(P-Q)+At=(-3,-1,1,3)+(1,1,1,1)t
X(t)-Q=(-3+t,-1+t,1+t,3+t)
the distance between X(t) and Q would be
d=||(X(t)-Q)|| or d=((X(t)-Q).(X(t)-Q))1/2For 2.
then the distance squared as a function of t would be
d2=(X(t)-Q).(X(t)-Q)
this gives d2=20+4t2
the derivative is (d2)'=2((d2)'d(2
(d2)'=(2(8t)(20+4t2)
(d2)'=320t+64t3
set the derivative to 0 for minimum and i get
t=(-320/64)1/2
Its clearly not the right answer of 2(5)1/2
I don't know where I am going wrong.
You can also minimise d^2 to get the shortest distance between a point and a line. This is just the normal from the line, can you just use that?
Mat
I've minimised d^2 by taking the derivative and setting to 0
You differentiated incorrectly. What Mat is suggesting is that you minimize f(t)=20+4t2. There's no need to use the chain rule.
How can you minimize f(t)=20+4t2?
Is it not only do when is a minus?
You can do it by inspection. It's a parabola, right?
Or you can solve f'(t)=0. Note I just called it f(t) instead of d2 since the notation seemed to be leading you astray.
y= 20+ 4t2 is a parabola opening upward. It's minimum value is at the vertex (which is very easy to find here- t2 is never negative).
You may be thinking that y= 20+ 4t2 has no maximum- and that y= 20- 4t2 has no minimum.
so t=5 is the time where the distance between the line is at a minimum?
...visualisation helps sometimes
the substitue t into X(t)
and then find distance betweeb X(t) and Q?
No. How did you get t=20?
I see now i get what u mean by minimize.
Find the value of d^2 which is the smallest.
The smallest value of d^2 is 20.
so d=2(5)^1/2
