MHB Finding the Equation of a Circle Passing Through Three Given Points
  • Thread starter Thread starter karush
    Circle Points
The equation of a circle passing through the points $(-1,3)$, $(6,2)$, and $(-2,-4)$ is derived as $(x-2)^2 + (y+1)^2 = 25$. The center of the circle is located at the coordinates $(2, -1)$, and the radius is calculated to be 5 units. The solution involves setting the distances from the center to each point equal, leading to a system of equations that ultimately reveals the center and radius. Additionally, the discussion touches on using TikZ for graphical representation of the circle and points.
  • Understanding of circle equations in Cartesian coordinates
  • Familiarity with distance formula and midpoint calculations
  • Knowledge of perpendicular bisectors and their role in geometry
  • Basic proficiency in TikZ for graphical representation
  • Explore the derivation of circle equations from general geometric principles
  • Learn how to implement the distance formula in various geometric contexts
  • Research advanced TikZ techniques for creating complex geometric figures
  • Investigate the use of graphing software alternatives to Desmos for visualizing mathematical concepts
Mathematicians, geometry students, educators, and anyone interested in computational geometry and graphical representations of mathematical concepts.
karush
MHB
find an equation of the circle passing through the given points
85 Given $(-1,3),\quad (6,2),\quad (-2,-4)$
since the radius is the same for all points set all cirlce eq equal to each other
$(x_1-h)^2+(y_1-k)^2=(x_2-h)^2+(y_2-k)^2=(x_3-h)^2+(y_3-k)^2$
plug in values
$(-1-h)^2+(3-k)^2=(6-h)^2+(2-k)^2=(-2-h)^2+(-4-k)^2$
from this we get (via W|A)
$h = 2,\quad k = -1$
derive the radius by the distance of the center to one of the points
$d=\sqrt{(2-(-2))^2+(-1-(-4))^2}\sqrt{16+9}=\sqrt{25}=5$
thus the stardard circle equation would be
$\left(x-2\right)^2+\left(y+1\right)^2=25$
ok I think this is ok, but I was going to try to do this with a matrix but with the squares in it didn't see how
also want to try to draw the 3 points, center, and circle with tikx
first attempt... need 3 points and ticks and text
\begin{tikzpicture}
\draw (.4,-.2) circle (1cm);
\draw (-2,0) -- (3,0);
\draw (0,-2) -- (0,2);
\end{tikzpicture}
I assume there might be some kill all formula used for this problem.
Mathematics news on Phys.org
slope between (-1,3) and (-2,-4) ... $m = 7$
midpoint between (-1,3) and (-2,-4) ... (-3/2, -1/2)
perpendicular bisector ... $y + \dfrac{1}{2} = -\dfrac{1}{7}\left(x + \dfrac{3}{2}\right)$
slope between (-1,3) and (6,2) ... $m = -\dfrac{1}{7}$
midpoint between (-1,3) and (6,2) ... (5/2, 5/2)
perpendicular bisector ... $y - \dfrac{5}{2} = 7 \left(x - \dfrac{5}{2} \right)$intersection of the two perpendicular bisectors is the circle center, (2, -1)distance between any point and the center is the radius ... $r = 5$
circle equation ...
$(x-2)^2 + (y+1)^2 = 5^2$
well that was certainly very novel..
most of these examples throw you to the general equations and do a lot of gymnastics.
ok I assume that is a Desmos graph...
circle equation ...
$(x+1)^2 + (y-2)^2 = 5^2$
Well, well, well! Someone's been reading their Euclid! (Bow)
Nice job.
-Dan
not desmos ... free graphing program for windows (maybe there is one for Macs, haven't looked to confirm)https://www.padowan.dk/download/
I think I'm mostly interested in what ca be done with tikx.
Albeit with its limitations
$$(-1-h)^2+(3-k)^2=(6-h)^2+(2-k)^2=(-2-h)^2+(-4-k)^2$$
$$(-1-h)^2-(6-h)^2+(3-k)^2-(2-k)^2=0$$
$$-7(5-2h)+(5-2k)=0$$
$$-35+14h+5-2k=0$$
$$-30+14h-2k=0\quad[1]$$
$$(-1-h)^2-(-2-h)^2+(3-k)^2-(-4-k)^2=0$$
$$(-3-2h)+7(-1-2k)=0$$
$$-10-2h-14k=0\quad[2]$$
$$[1]+7*[2]\implies k=-1\implies h=2$$
$$(x-2)^2+(y+1)^2=25$$
so I quess there is no slam dunk one step solution :(
