A follow up of the question about gears of the winder
  • Thread starter Thread starter stephen
    Gears
The discussion revolves around the mechanics and calibration of a winder mechanism involving worm gears. Participants explore the relationship between the gears, their rotation rates, and the implications of the labeling on the counter associated with the winder. The conversation includes technical reasoning and clarifications about the gear interactions and their design features.
  • One participant initially misinterprets the relationship between the gears, believing the worm gears are glued and that they rotate at the same rate, but later corrects this understanding.
  • There is a question about the meaning of the counter label, with a participant suggesting that the calibration seems unusual and questioning the rationale behind the numbering system.
  • Another participant clarifies that the winder records the rotations of the 30-tooth gear rather than the handle itself, suggesting that the labeling is appropriate as it reflects the gear's rotations.
  • Concerns are raised about the practical utility of the outer circle of the counter, which resets every 30 rotations, leading to further inquiry about its purpose.
  • Discussion includes a query about the orientation of the worm gears and their design, with a participant seeking clarification on how the shape of the gears affects contact area and pressure distribution.
  • A participant provides an explanation of the mechanics involved, detailing how gear B's rotation affects the worm gear and the subsequent movement of the 100 and 102-tooth gears.
Participants express differing views on the calibration of the counter and its practical implications, indicating that there is no consensus on the utility of the outer circle or the labeling system. The discussion remains unresolved regarding the optimal design and functionality of the winder mechanism.
Some assumptions about the gear interactions and the presence of idler gears are not fully clarified, which may affect the understanding of the mechanism's operation. The discussion also highlights potential ambiguities in the labeling and its interpretation.
stephen
Hi all!
I open a new thread since I am going to post another picture, and this would overload the old thread.
The first picture shows the number of teeth of the meshing gears.
I was wrong that the pair of worm gears are glued. They are not glued as mentioned by Q_Goest. And the two gears are rotating at different rates.
The second picture shows the label of the counter.
What I am going to ask is the meaning of the label.
From the number of teeth of the gears indicated in the first picture, it is known that the 102 worm gear rotate at a lower speed than the 100 one.
I find that for every 30 turns of gear A would finally cause Gear C(102teeth) to lag behind GearC(100teeth) by 1/51 turns.
So in the label, it can be visualised that when the 30 turns are rotated, the outer point would just finished rotating one complete circle. And the inner pointer would move one little grid. (Some error in the picture drawn, the inner circle should be divided into 51 divisons, instead of 50 divisions. I find this in the real label provided.)
First of all, is my intepretation correct?
If yes, I have got some questions.
Why do the calibration of the inner circle so strange? Why don't it just writes "10, 20, 30, 40, 51" but "1000, 2000, 3000, 4000, 5100" instead?
Second, if I am the user of the this winder, and I am going to count how many revolution of have I rotated the handle. If I am to do so, I need to multipy the readings of 30, right? Don't you think this is strange? Have I interpreted the usage wrongly?
And it seems to me that the outer circle is of no practical use...It only returns to zero for every 30 times of rotation of the handle.
Sorry for such a long thread...I am really such an idiot. Hope to receive your nice help~
oops..
I just knew that I could post pictures in the 'reply'..
sorry for starting another thread...
Please relocate this thread if any inconvenience is caused.
I discovered that I asked a silly question.
The winder is not going to record how many turns the handle retotate but the 30 teeth gear...So the label should really be marked "1000, 2000, 3000, 4000.etc"
I think I now understand the entire mechanism.
But I still don't quite understand the orientation of the pair of worm gears. i.e. the "turbine" shape...
Q_Geost, do you mean the pair of grears' orientation is such that the drive gear would have a greater contact area with the pair of worm gear? And this reduce the pressure?
Each time gear B rotates, the worm gear rotates once and the two gears it is rotating (the 100 tooth and 102 tooth worm wheels) only rotate by 1 tooth. Also, gear B will rotate 100/30 or 3.333 times for each time you rotate the handle. This assumes there is only an idler gear between the two which isn't certain given the picture.
Regarding the "turbine" look of those two gears, I'm assuming you're referring to the slighty slanted angle on the teeth. There's a couple of pictures of typical worm gear and worm wheel assemblies here:
http://www.qtcgears.com/e-store/Images/Worm.jpg
http://www.tasonic.com.tw/images/PAGE6/6-2.JPG
In each case you can see the teeth on the worm wheel are slightly angled so they mesh with the worm gear (screw shaped gear). Is that what you were referring to? If so, the reason for the slight angle on the teeth should be fairly obvious. It allows the worm gear and worm wheels to contact over a larger area.
  • · Replies 18 ·
13K
