A hypothetical question about gravity
  • Context: Graduate
  • Thread starter Thread starter schnorbitz
    Gravity Hypothetical
The discussion revolves around a hypothetical scenario involving a large hole drilled through the Earth between the poles, exploring the consequences of jumping into this hole. Participants consider various aspects of gravity, terminal velocity, and the effects of air resistance, while debating the outcomes of such a fall, including oscillation and potential emergence on the other side.
  • Some participants propose that one would oscillate up and down the hole due to air resistance before settling at the center of the Earth.
  • Others argue that one would emerge on the other side of the Earth at the same speed as the jump, assuming no air resistance.
  • A participant suggests that the journey would take approximately 42 minutes without air resistance, ending with a speed of zero upon reaching the other side.
  • Some contributions highlight the diminishing effect of gravity as one approaches the center of the Earth, suggesting that terminal velocity would decrease significantly.
  • There are claims that a human's mass and drag ratio would affect the ability to pass through the center, with some suggesting that one might not have enough velocity to overcome gravitational pull after passing the center.
  • Participants discuss the need for integrating gravitational effects and drag forces to understand the motion through the hole, indicating a complex mathematical relationship.
Participants express multiple competing views regarding the outcomes of jumping into the hole, with no consensus reached on whether one would emerge on the other side or oscillate indefinitely. The discussion remains unresolved with differing interpretations of gravitational effects and terminal velocity.
Some limitations include assumptions about uniform mass distribution within the Earth, the effects of air resistance, and the mathematical modeling required to accurately describe the scenario. Participants acknowledge the complexity of the problem without resolving the mathematical steps involved.
  • #31
poco9964 said:
Now that has got my mind thinking.
If I reached a point where the mass in the sphere above me was greater than that what was below me. Why does this have no effect would on my mass, and why would the mass above me now not become the greater force?
Sorry if that is a silly question.
The mass "above you" in terms of a spherical shell has no effect on you. The gravity of it cancels itself.
The mass "above you" in terms of a sphere section would only become greater if you pass the center. Then gravity is reversed.
  • #32
A.T. said:
Would the pressure really be enough to make air liquid at the center? I guess it depends on the temperature. But let's assume the tunnel is well insulated.
Anyway, gas or liquid, it would be denser.
Close to the surface, air density doubles every ~8km. This would give conditions similar to the critical point (~3,5MPa, 126K for nitrogen) already 40km below the surface. Give or take a factor of 2, the air would be supercritical in most of the tunnel unless you evacuate it in some way.
  • #33
A.T. and Subductionzon have it right. Gravitational acceleration inside the Earth reaches a global max at the core mantle boundary and then drops to zero per the Preliminary Reference Earth Model.
Reference: Dziewonski & Anderson, Preliminary reference Earth model, Physics of the Earth and Planetary Interiors, 25:4 (1981)
DOI: 10.1016/0031-9201(81)90046-7
Tabular presentation: http://geophysics.ou.edu/solid_earth/prem.html
Paper: http://mh-gps-p1.caltech.edu/uploads/File/People/dla/DLApepi81.pdf
A simple model of gravitational acceleration inside the Earth is that gravitation remains constant at 10 m/s2 from the surface to halfway to the center and then drops linearly from that point inward. This is much more amenable to analysis than is the PREM but still retains the key feature that gravitational acceleration remains high in the crust and mantle.
What happens to air inside the magical tunnel depends on temperature. Assuming this simple model, ideal gas conditions, hydrostatic equilibrium, and a constant temperature of 20 C throughout (magical walls!) would mean an absolutely ridiculously high pressure at the center of 5.5*10493 atmospheres. Assuming hydrostatic equilibrium and adiabatic conditions would mean ridiculously high pressure and temperature at the center.
  • #34
I guess this ridiculous result is due to the assumption that the gas can be compressed without limits, so that density increases steadily?
The molecular hydrogen atmosphere of Jupiter is thicker than one Earth radius. Gravity is in the same order of magnitude in that region. The pressure below that atmosphere is estimated to be 200 GPa. Which is much, but nowhere close to 10493 atmospheres.
http://en.wikipedia.org/wiki/Jupiter
  • #35
Not liquid, that is impossible. Air is far above the critical temperature of the various gases that are in it. It would be as I said a supercritical fluid. I did the math once before when trying to calculate the density of the air using the Ideal Gas Law. I got a ridiculous solution that showed me the law broke down at those pressures.
Using the ideal gas law you don't have a gas column of constant density. You will have one that will continually increase in density. Eventually you are not dealing with a gas anymore. Since the force of gravity goes up slightly for the first half of your journey you can make the problem easier by treating it as a constant for that distance. It should double in density over a constant distance. At sea level the pressure drops off to half at 18,000 feet or 5,500 meters. Going down half way you would have 280 of these intervals. Or the density of the air, if the Ideal Gas Law held up would be 2^280 times that at the surface. This amount would obviously be in error so there is no use in using the Ideal Gas Law. Therefore the need of our magical baffles to keep the air at a reasonable pressure.
  • #36
I see D.H. did a more exact analysis that showed that the air has to be a supercritical fluid and no longer a gas. The reason that the pressure gets so high in the calculations is that the Ideal Gas Law assumes that air is infinitely compressible. As we go down the hole not only would the air be increasing in pressure due to the weight of all of the gas above us, the density of that gas would be increasing with that increasing pressure resulting in exponential growth to the pressure and density. Sooner or later the IGL will fail.
  • #37
I did something dyslexic with my calculation, using R=3678 km rather than 6378 km.
In any case, an adiabatic assumption is arguably better than the isothermal assumption. This yields a temperature of about 48000 kelvin at the center of the Earth and a pressure of about 56 million atmospheres.
Details:
Gravity is constant at 10 m/s^2 down to the halfway point. This yields a lapse rate of 9.953 K/km (c.f. the adiabatic lapse rate of 9.8 K/km for g=9.80665 m/s^2). This makes the temperature at the halfway point be about 32000 kelvin. Below the halfway point gravity drops linearly toward zero at the center. This makes temperature quadratic below the halfway point,
[tex]T(z)=T(R/2) + \alpha*(z-R/2)\left(1-\frac{z-R/2} R\right)[/tex]
where [itex]\alpha[/itex] is 9.953 K/km. This yields a temperature of 48000 kelvin at the center of the Earth. The assumption of adiabatic conditions means
[tex]P=P_0 \left(\frac{T}{T_0}\right) ^{\frac{\gamma}{\gamma - 1}}[/tex]
Using [itex]\gamma=1.4[/itex] yields a pressure of 56 million atmospheres at the center of the Earth.
Bottom line: This air-filled tunnel is very hot and under extremely high pressure.
  • #38
A.T. said:
But a lot of it. 1 bar is from the 100km column above surface at approx. constant g. In the tunnel center the column would be 63 times higher, however at decreasing g. My question was if that is enough pressure to make air liquid.
If you don't make the tunnel to wide, I doubt it. The polar bears could reach the Antarctic and eat all the penguins.
What do you mean? What should stop the air from falling to the center?
The same thing that causes a lack of Air in caves or mine shafts. I understand this hole will be opened both ends, but air will not flow from one end to the other. It would be like getting a pipe and attaching fans either end blowing inwards. They would reach a point where they would cancel each other out. In the centre, I would assume as it is equal forces being excreted. A better analogy would be to block both ends of a pipe so no air can escape, and then use a plunger mechanism on both ends to push them together. You will notice it takes tremendous force to do so. I can not see why the same effect should not occur in this hole.
The lack of gravity will also make air lighter than at the surface, so even though it got denser it does not mean it would get heavier. Gravity would begin to have less of an effect on its mass, the same as it did our own. And at zero point it will have no effect on its mass.
It's increase in density will increase air resistance the further you go down the hole. Yet another factor that I feel would prevent you reaching the core. Also the hotter it got, the more updraught would be created like thermals. giving even more reason as to why the air, like us would not make it to the core. Even if you could control the heat at the core, you would struggle to control the heat generated under the air pressure.
  • #39
Can you explain this, please?
I understand a lack of oxygen (as it is consumed by humans, and finite without ventilation). But I never heard of underpressure without sealing and pumping.
This pipe will have a higher pressure inside.
This is a good sign of a high pressure.
Weight gets lower, density increases. This means that a lot of air is in the center.
  • #40
Sorry, I have not explained myself very well. I was trying to explain the convection effect, that heat makes molecules move faster. And that the force of gravity is temporarily over come all the time these molecules are excited enough. When they cool down gravity grabs them again and brings them back down. This effect will actually prevent the air density becoming any denser. The air will reach a certain point where the heat generated from the pressure above it prevents it going any lower due to the convectional heat (Pressure) being generated beneath it. As gravity gets weaker and the air gets hotter, there becomes less chance they could ever meet. I can not do the maths, but I would expect that to occur long before gravity started to drop off. I hope I have made myself a little clearer.
  • #41
The hole doesn't need to be kilometers wide, so there's no need to worry about that.
I should imagine that the hole would need to be quite a bit wider than a couple of kilometers.
The Earth is tilted and rotates at a tilt so if you made a hole from the north to south poles the hole would have to be wide enougth to acount for the tilt.
Else you would hit the side.
  • #42
Get rid of the tilt by tilting your head. The "tilt" doesn't mean anything unless you are worrying about the relation to the Sun, and seasons and so on.
  • #43
Well I was worrying that you would hit the side of the tunnel if the hole was not wide enough.Ok. I can tilt my head but that won't stop the Earth traveling around the Sun at a tilt. You and I are traveling with it and if we were to throw ourselfs down a hole dug at an angle or tilt would we not hit the side at some point on our journey.
  • #44
What does the Sun have to do with it? The relative motion of you and Earth is a result of Earth’s gravity.
  • #45
Is it not also a result of the Earth's motion around the Sun or can this be ignored.
If you were at a distance from Earth watching the person throw himself down the hole you would see he was moveing with the Earth in it's orbit around the Sun.
  • #46
Perhaps there would be a very small movement due to tidal forces as you fell. I will have to think about the fall and the motion of the barycenter of the Earth and the Sun and that of the Earth and the Moon. Even so they should not have a significant effect. In the evacuated hole you would pass through the Earth in about 40 minutes. Not long enough to worry about a slight change in pull from the Sun or Moon. In the case of the air filled tube aerodynamic effects would keep you from hitting the sides.
  • #47
Where are you getting this 10 m/s acceleration from? That doesn't make any sense. The acceleration of gravity has to decrease to 0 as you go to the center. In fact, you can check wikipedia where it clearly shows a linear decrease to 0 starting at the Earth's surface.
  • #48
It clearly does not show that. Look at the solid curve, the one labeled "PREM", on the graph (depicted below). Starting from the left (the center of the Earth), it shows gravitational acceleration as rising more or less linearly, reaching a maximum at the core/mantle boundary. From this maximum, gravitational acceleration initially drops with increasing distance from the center but then flattens and even starts rising again. It drops again in the upper mantle. The value at the surface of the Earth is less than anywhere in the upper or lower mantle.
  • #49
Opps, I was assuming constant density, which is clearly not true. In either case there is only a small fraction of the core which has a predict acceleration greater than 10 m/s2.
  • #50
However, almost all of the mantle has acceleration greater than 10 m/s2. Using a constant acceleration of 10 m/s2 from the surface down to halfway to the center and a linear dropoff to zero from that point inward provides a nice, simple model (with a couple of nice, simple numbers) that happens to closely match the much more detailed PREM with regard to the period of an object falling in an airless tunnel through the Earth.
  • #51
OK, I see what you are saying. You are worried about the tidal effects of the Sun and Moon gravity on the falling object. We know the scale of that effect by virtue of how far it shifts the equipotentials of the oceans, which I believe is typically perhaps a meter or so. We can estimate a similar scale for the deflection of the falling object-- I think we should expect that a hole much larger than a few meters should not need to worry about hitting the side of the shaft, but your point is well taken that this kind of effect needs to be considered to be sure.
  • #52
I think the "hitting the sides of the tunnel" would be an issue if the tunnel went straight from equator to equator. During the 45 minute journey, the hole on the opposite side of the Earth has moved over 1000Km. I suppose you could dig the tunnel curved to compensate, but this means we now need a second tunnel, curved the opposite way, for the return trip. This project is getting expensive.
  • #53
Install a maglev rail system inside. The involved forces are small, and it keeps you on track with a precision of a millimeter.
  • #54
I don't think the following have been injected into this thread yet but (and this is essentially theoretical, of course).
1. For a planet of uniform density, no atmosphere, cold core etc. the oscillation would be simple harmonic motion and its period would be exactly the same as that of a satellite in (grazingly) low orbit. You would emerge from each end of the tunnel just as a satellite passed overhead each time.
2.An experiment that could easily be done (well. . . fairly easily) if you could get hold of a nice spherical asteroid which happened to be made of all granite (ish) rock. You could drill a hole through the centre and then drop a small pebble down the hole. Its period of oscillation would also be about 90 minutes. This is because the period of oscillation is independent of the amplitude of oscillation. (It would be relatively easy to stop it spinning to avoid bumping into the sides). I imagine the same thing with a rock and a grain of sand would fail because of electric forces becoming significant.
  • #55
Sorry I must be missing something here, let me give a similar scenario.
In a vacuum.
If I had a scaled ball (Earth), with a hole in it, in space, and I dropped a scaled ball (Man) through it. Would it not come out the other side?
Would it inevitable end up in the middle stuck?
If it does not fall out and there is no friction to slow it down, how exactly does it lose the energy put into it each trip by gravity?
My problem is this, I do not think solid doughnut shapes in space collect matter in their centre and begin to fill up, from the inside out.
Space is effectively the only vacuum we could be talking about that has so little resistance to even begin to suggest we could free fall at 17,700 miles/hr. Space contains some gases, but I won't go there. So let's say we accelerate at this speed and neither the decrease in gravity or the decrease to our mass slows our decent to the centre. How does gravity slow us down again given we are traveling at this speed and there is no air resistance at the other end? Does our mass increase slow us down? or does gravity some how apply the breaks to us given enough time?
Basically my biggest issue with this is if there is no resistance, a true vacuum then gravity would oscillate them back and forth for as long as it is present. There would be absolutely nothing to slow this up and down motion. And effectively creating perpetual motion machine. Now I know nobody is going that far, or at least I hope not?
  • #56
Remember that any spin of the rock and the hole would rapidly clog up with captive stuff. The KE would be largely lost. Also, nothing would ever 'just turn up' in the ideal spot for this experiment to happen on its own. There would be some angular momentum to upset things. You would definitely need to be there to make it work.
  • #57
poco9964 said:
In a vacuum.
Assuming a perfect sphere without rotation and without other experimental issues, it would reach the other side.
Right.
Maybe apart from gravitational waves ;).
  • #58
But this is no more 'perpetual motion' than a simple orbit round the outside of the rock! And a much much more special case.
  • #59
About 120 minutes, not 90. Your 90 minute value is for an object whose average density is almost twice that of granite. Note: For an object with a uniform density equal to the average density of the Earth, the period would be about 84.3 minutes.
  • #60
Fair enough. but 84 is pretty near 90, ain't it? Presumably granite is not 'average density'?
If the result of the test came out between one and two minutes, I'd be pretty pleased with myself. Well worth the cost of a launch - and the fees for Morgan Freeman, Clint and Tommy Lee Jones, too.
My point was that things scale. I also realized, during my thoughts on this, that there must be loads of small things out there (in Saturn's rings for instance) circling each other at these sort of rates.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 17 ·
