A manipulative matrix question
  • Thread starter Raghav Gupta
    Matrix
27 replies · 4K views · last reply
Raghav Gupta
If A and B are 2 matrices such that AB = A and BA =B, then B2 is equal to
B
A
Zero matrix
I
We can pre or post multiply a matrix on both sides of equation.
(AB).(BA) = A.B
AB2A = A.B
Pre multiply both sides by A-1
We get B2A = AB
Implies B2AB = AB as (A = AB)
Post multiplying by B-1 and A we get B2 = I
Is this correct?
B
A
Zero matrix
I
(AB).(BA) = A.B
AB2A = A.B
We get B2A = AB
Shouldn't that last equation be as follows?
B2A = B
By the way: Are you certain that matrix, A, has an inverse?
Is this correct?
I don't see anything in the problem that says that either matrix is invertible, so there's no justification for assuming that A-1 exists.
I found it helpful to start with B2 and work with that.
Maybe it was a trick question - nothing involving inverse matrices. Both A and B could be identity matrices. This would satisfy the problem statement in the strictest sense.
I started with A2 .
Mark44 said:
That seems the long way around if the goal it to find B2, but then I don't know what you did.
Well, I suppose we'll have to see what OP does before we can all compare notes.
If you start with ##B^2##,
Then i got A=I.
##B^2=B.B=B.BA=B^2A##
##B^2=B^2A##
A=I satisfies the above equation.
And if i put it on AB=A, then i got B=I.
Then i got A=I.
##B^2=B^2A##
While I satisfied that equation, it's not necessary that A = I .
Then i got A=I.
##B^2=B^2A##
As Sammy said, B isn't necessarily I. Here's a counterexample, using your assumption that A = I.
$$B = \begin{bmatrix} 1 & 0 \\ 0 & 0\end{bmatrix}$$
This matrix satisfies B2 = B2A = B2I, yet ##B \neq I##.
B2A = B (Yes, sorry )
By the way: Are you certain that matrix, A, has an inverse? (No)
Are you certain that matrix, A, has an inverse? (No, as Mark44 10th post example proves that matrix B has determinant=0)
So,
I started with B2 ,
## B^2 = B.B = (BA).(BA) = B(AB)A = (BA)A= BA=B ## Is multiplication of matrices associative which I am doing here?
Starting with A2.
Following the above similar pattern , I get A2= A.
How did you Sammy get B2 value by starting from A2?
Raghav Gupta said:
So,
I started with B2 ,
Starting with A2.
Yes, multiplication of matrices is certainly associative.
How?
Raghav Gupta said:
Oh, I was expecting a easy proof for it. I think we have to go in deep for that topic to understand the proof?
It's not deep, you just have to pay attention to the indices. Ignore the ring stuff. Just use that for real numbers (ab)c=a(bc).
Thanks, got it.
Raghav Gupta said:
So,
I started with B2 ,
Starting with A2.
Of course, I didn't follow that pattern, but, yes, A2= A.
I start with:
A2 = A2
BAAB = BAAB
((BA)A)B = (BA)(AB)
(BA)B = BA
BB = BAdded in Edit:
Here are two such matrices.
##\displaystyle \left[\begin{matrix} 1 & 1 \\ 0 & 0 \end{matrix}\right]##
##\displaystyle \left[\begin{matrix} 0 & 0 \\ 1 & 1 \end{matrix}\right]##
SammyS said:
I start with:
A2 = A2
BAAB = BAAB
How you have written A2 = BAAB ?
I didn't say that.
I said
BAAB = BAABNow that I look at that, I only needed:
BAB = BAB
(BA)B = B(AB)
BB = BA
B2 = B
BAB = BAB
How you have written A2 = A ?
I didn't use that at all. (I did mention in Post #18 that it is also true.)That post (#20) says, instead of starting with the identity BAAB = BAAB,
I could have started with BAB = BAB .
Either of these equations is obviously true.
You seem to not be following my method of working with these equations.
I manipulate each side of the equation independently.
I could have also done it this way.
BAB = (BA)B
= BB
=B2​
BAB = B(AB)
=BA
=B​
Therefore, B2 = B .
Added In Edit:
I left the 2 out of the [ SUP][ /SUP]. DUH !
(Well the little icon has X2, so why no 2 ?) :smile:
SammyS said:
I was simply stating that similar to B2 = B, it's also true that A2 = A.
I know that already and I have solved it as you can see in my earlier post.
What I am asking is you have told that earlier that you started with A2 and when deriving that value of B2 from A2 you don't know that A2 = A.
So how from A2
BAAB comes?
BAB = (BA)B
= BB
=B2​
BAB = B(AB)
=BA
=B​
Therefore, B = B .
I'm pretty sure that you meant Therefore, B2 = B.
So how from A2
BAAB comes?
I said I started with A2, then I revised that (in the post) to say Instead start with BAAB. (Of course that's BA2B .)
After that, I further made the observation that I might just have well started with BAB .
I don't use A2 = A at all.
Okay, got it.
Thanks to all of you.
Learnt quite a lesson from this question.
Raghav Gupta said:
Okay, got it.
The easiest solution of all is to start with AB = A and BA =B, and multiply both sides of the first equation on the left by B, to get B(AB) = BA, or (BA)B = B = B*B because BA=B. That seems to me to be about the simplest solution possible.
