A nice equation with the floor function
  • Thread starter Thread starter Gp7417
    Function
The discussion revolves around solving the equation x · ⌈x · ⌈x⌉⌉ = 82, with one identified solution being 41/9. Participants explore the possibility of additional solutions, questioning whether the function can remain constant or increase with changes in x. It is established that the function f(x) = x · ⌊x · ⌊x⌋⌋ is strictly increasing, suggesting that there can be at most one solution. The analysis leads to the conclusion that x must lie between 4 and 5, and only one valid solution exists within this range. The conversation emphasizes the importance of correctly applying floor and ceiling functions in the context of the equation.
Gp7417
Moved from a technical forum, so homework template missing
Hi all!
I should solve the following equation involving the ceil or floor function:
<br /> x \cdot \lceil x \cdot \lceil x \rceil \rceil = 82<br />
I have found just one solution 41/9, but I have no idea about how finding the other solutions.
Thanks you in advance!
What convinces you that there are other solutions?
Can the expression stay the same or decrease if you increase x?
Can the expression stay the same or increase if you decrease x?
The problem says: 'Find all possibile solutions'. I find this solution numerically.
The expression must be the same.
Right, so can this be possible with a different x?
That does not tell you how many solutions there are.
I propose this solution, check it out!
We must find solution on the positive real axis.
Let be x= n + \delta, where n is the integer part and \delta is the fractional part with 0 \leq \delta &lt; 1.
Given that x \lfloor x \lfloor x \rfloor \rfloor=82 and x \lfloor x \lfloor x \rfloor \rfloor \leq x^3 , we get x \geq 82^{\frac{1}{3}} \approx 4.344. Therefore n \geq 4.
If 5 is not solution the equation, then every number greater than 5 are not solutions. Therefore n=4.
With the previous statements, the equation becames:
(4+\delta)\cdot \lfloor 16+4\delta \rfloor=82
This equation is equivalent to the following equations:
0 \leq \delta &lt; 1/4 and (4+\delta)\cdot(16+0)=82
1/4 \leq \delta &lt; 2/4 and (4+\delta)\cdot(16+1)=82
2/4 \leq \delta &lt; 3/4 and (4+\delta)\cdot(16+2)=82
3/4 \leq \delta &lt; 4/4 and (4+\delta)\cdot(16+3)=82
Only the third equation admits a solution that is \delta=5/9.
What I don't understand here is why there is a solution at all?
Obviously x has to be between 4 and 5, excluding 4 and 5. So the inner ceiling is 5 and the outer at least 21. But four times twenty-one is already 84.
You write the ceil function and then derive things for the floor function? For the floor function that works.
See the floor/ceil mixup.
With \lceil x \rceil I want to denote the floor function of x.
That's how to denote the ceiling function.
Use lfloor and rfloor for the floor function. ##\ \lfloor x \rfloor##
No. The function ##f(x) = x \lfloor x \lfloor x \rfloor \rfloor## is strictly increasing in ##x##, sometimes linearly and sometimes through a jump discontinuity.
To see this, let ##x = n + r## where ##n \geq 0 ## is an integer and ##0 \leq r < 1##. Then the inner floor function is ##\lfloor n + r \rfloor = n##, so
f(n+r) = (n+r) \lfloor (n+r)n \rfloor
The function ## g(n,r) = \lfloor (n+r)n \rfloor## is positve and nondecreasing in ##n## and ##r##, so ##f(n+r) = (n+r) g(n,r)## is strictly increasing.
That means that ##f(x) = 82## has at most one root.
