A possible mistake in Equations (18.204)-(18.205) in Peskin & Schroeder
  • Context: Graduate
  • Thread starter Thread starter MathematicalPhysicist
    Mistake Peskin Schroeder
The forum discussion centers on a potential error in Peskin & Schroeder's equations (18.204) and (18.205) regarding the strong coupling constant, ##\alpha_s(Q^2)##. Participants argue that the correct form should utilize ##\alpha_s(Q)## instead of ##\alpha_s(Q^2)##, as the dimensions of ##Q## and ##\Lambda## must match in logarithmic terms. The discussion references equation (17.17) and highlights inconsistencies across different editions of the text. The correct formula for the strong coupling constant is confirmed as ##\alpha_s=\frac{4 \pi}{\beta_0 \ln(\mu^2/\Lambda^2)}##, with ##\beta_0=11 C_A-2 N_F##.
  • Understanding of Quantum Field Theory (QFT)
  • Familiarity with Peskin & Schroeder's "An Introduction to Quantum Field Theory"
  • Knowledge of the Altarelli-Parisi equations
  • Basic concepts of the strong coupling constant in Quantum Chromodynamics (QCD)
  • Review the derivation of the Altarelli-Parisi equations in QFT literature
  • Study the implications of the running of the strong coupling constant in QCD
  • Examine the differences between various editions of Peskin & Schroeder's textbook
  • Explore one-loop calculations of the strong coupling constant in Quantum Field Theory
Physicists, students of Quantum Field Theory, and researchers focusing on Quantum Chromodynamics who seek to clarify the nuances of the strong coupling constant and its representation in foundational texts.
They write the following on page 646:
Thus, according to the Altarelli-Parisi equations, the n-th moment of ##f^{-}_f(x)## obeys:
$$(18.204) \ \ \ \frac{d}{d\log Q^2}M^-_{fn} = \frac{\alpha_s(Q^2)}{8\pi}a_f^n \cdot M^-_{fn}.$$
To integrate this equation, we need the explicit form of ##\alpha_s(Q^2)##.
Inserting expression (17.17), we find:
$$(18.205) \ \ \ \frac{d}{d\log Q^2} M^-_{fn}=\frac{a_f^n}{2b_0}\frac{1}{\log(Q^2/\Lambda^2)}M_{fn}^-$$
Now, equation (17.17) reads: ##\alpha_s(Q) = \frac{2\pi}{b_0 \log(Q/\Lambda)}##, so if I plug ##\alpha_s(Q^2) = \frac{2\pi}{b_0 \log(Q^2/\Lambda)}## into Eq. (18.204) I get: ##\frac{a^f_n}{4b_0}\frac{1}{\log(Q^2/\Lambda)}M^-_{fn}##.
Perhaps the ##\alpha_s(Q^2)## in equation (18.204) should be ##\alpha_s(Q)##?
For this it works fine, I wonder how come it doesn't appear in the errata this typo?
MathematicalPhysicist said:
They write the following on page 646:Now, equation (17.17) reads: ##\alpha_s(Q) = \frac{2\pi}{b_0 \log(Q/\Lambda)}##, so if I plug ##\alpha_s(Q^2) = \frac{2\pi}{b_0 \log(Q^2/\Lambda)}## into Eq. (18.204) I get: ##\frac{a^f_n}{4b_0}\frac{1}{\log(Q^2/\Lambda)}M^-_{fn}##.
Q has the same dimension as \Lambda so they must appear with the same power in the log. If it works with ##\alpha_s(Q)## then that's correct. It does not appear just because they are not aware of it or they forgot to include it. No all typos are corrected in errata.
At least in my copy, (17.17) reads
##\alpha_S(Q^2) = \frac{2\pi}{b_0\ln Q/\Lambda}## ,
i.e., with a ##Q^2## instead of ##Q## as the argument.
Which edition do you have?
I am actually not sure, the front matter is not particularly helpful. Published by Perseus Books, so rather old if I understand correctly...
Edit: according to this https://www.slac.stanford.edu/~mpeskin/QFTold.html eq. (17.17) in the version I apparently have was corrected in later versions (to be consistent with (17.13)), possibly without changing later equations consistently. I think this is just a matter of convention what argument you prefer for ##\alpha_S##, but in any case, the powers of ##\Lambda## and ##Q## should match of course, as nrqed said...
It's the running of the strong coupling constant. You find the one-loop calculation in my lecture notes
https://itp.uni-frankfurt.de/~hees/publ/lect.pdf
p. 255 ff. I hope I didn't make also some mistake or typo. Note that by definition ##\alpha_s=g^2/(4 \pi)##. At least it's the same as in Schwartz, QFT and the Standard model (given that for SU(3) ##C_A=3## and that ##\ln(\mu^2/\Lambda^2)=2 \ln(\mu/\lambda)## ;-)).
So the correct formula is
$$\alpha_s=\frac{4 \pi}{\beta_0 \ln(\mu^2/\Lambda^2)}=\frac{2 \pi}{\beta_0 \ln(\mu/\Lambda)},$$
where ##\beta_0=11 C_A-2 N_F##, where ##C_A## is the casimir of the adjoint representation and ##N_F## the number of quark flavors in the fundamental representation (as in QCD).
The two contributions come from the two gluon-loop diagrams and the quark-loop diagram, respectively, in the very elegant calculation via the gluon polarization function in background-field gauge provided in my manuscript, orignating from Abbott as cited in the manuscript).
