MATLAB A problem about residues(is matlab wrong?)
  • Thread starter Thread starter oahsen
    Matlab
The discussion revolves around a MATLAB code snippet designed to find the residues of the function 1/(z-i/9)^3. The user encounters an unexpected result where MATLAB returns two residues: 0 and 1, despite the mathematical expectation of only one residue, which should be zero. The confusion arises from the interpretation of residues at poles of higher order, specifically at z=i/9. The conversation highlights the discrepancy between MATLAB's output and the theoretical understanding of residues, leading to questions about the accuracy of MATLAB's residue algorithm. Ultimately, the consensus is that there should only be one residue, which is zero, indicating a potential misunderstanding of the output rather than an error in MATLAB.
oahsen
I have written this simple code fragment to the MATLAB for finding the residue(s) of the function 1/(z-i/9)^3;
b=[1];
a=[1 -i/3 -1/27 i/(729) ];
[r p k]=residue(b,a)
and get the following result;
r =
p =
0.0000 + 0.1111i
0.0000 + 0.1111i
0.0000 + 0.1111i
k =
The poles are true. Function has a pole of order three at z=i/9 . However, there are two different values for the residue: 0 and 1. I could not get the meaning behind that? How can a function have different residue at the same point? Additionally if we assume MATLAB is right then the result of the contour integral should be 2pi*i at the unit circle. However, we can easily show that this contour integral is zero. So, is something wrong with the residue algorithm of MATLAB or there is something I do not consider?
The residue of a pole in a function f(z) at z=a is the coefficient of 1/(z-a) in the Laurent expansion of f(z). In your case, a=i/9 and the coefficeint of 1/(z-i/9) is zero. So the residue (there is only one residue!) is zero.
Yes, logically it should have only one residue which is zero. However, what I did not understand is why has MATLAB find also a residue which is 1 at the pol z=i/9 ?
I don't use MATLAB so I can't help.
