A question about Black Holes and their Gravity
The discussion revolves around the mechanics of black hole formation, particularly focusing on the relationship between a star's density, mass, and gravitational force during its implosion. Participants explore the implications of gravitational force as a star collapses and how this relates to the universal gravitation formula.
  • One participant describes the process of a star's life cycle, noting that it fuses elements until it reaches iron, after which gravitational forces lead to implosion.
  • Another participant suggests that the loss of pressure from fusion is what allows the star to implode, rather than a gain in mass.
  • Questions arise about how a star can have less mass yet exhibit stronger gravitational force during implosion.
  • Some participants propose that the effective distance from the gravitational source decreases as the star collapses, which could explain the increase in local gravitational force.
  • There is a discussion about the implications of distance in the gravitational formula, particularly as the radius of the star approaches zero.
  • A participant uses an analogy of compressing mass to illustrate how being closer to a mass increases gravitational force experienced.
  • Further clarification is sought on how the gravitational force changes locally compared to when the star was in its normal state.
  • Some participants express understanding of the concepts discussed, indicating a grasp of the relationship between distance and gravitational force.
Participants express varying levels of understanding regarding the relationship between mass, density, and gravitational force. While some concepts are clarified, there remains no consensus on the implications of these changes during the star's implosion.
Discussions include assumptions about the nature of mass loss and the effects of distance on gravitational force, but these assumptions are not universally accepted or resolved.
This discussion may be of interest to those studying astrophysics, particularly in understanding black hole formation and gravitational dynamics.
Dean Whaley
So I understand that as a star begins to die, and begins fusion of H, He, C, O... it eventually reaches Fe which cannot be fused to create energy. Then the stars own gravity overcomes it's outward radiation and the star implodes, and eventually a black hole is created.
How can the star's gravitational force increase when it becomes more DENSE. I thought that gravitational force was only related to mass, and distance between centers shown by the formula for Universal Gravitation:
F = (Gm1m2)/d^2 . So as the star imploded I don't see how it's gravitational force became stronger, it didn't gain mass through this process, I would assume it lost mass as it fused various elements. It seems as though all that happened is that the star gained density.
Could someone please explain this to me, and correct any errors in my question?
Thanks!
Astronomy news on Phys.org
It doesn't gain mass, it losses the pressure that is created by the fusion process; that's what changes the balance enough for the runaway implosion/explosion
But how does this implosion create something that has less mass, yet more gravitational force?
The separation from the effective point source is reduced.
It has more gravitational force LOCALLY. If you were outside where the event horizon will form you would not see any difference.
If the star gets smaller, all distances in the star become smaller. As the sizes of stars at the end of their life vary extremely (typically more than a factor of 100), this is much more important than the mass changes.
Are you saying that the distance between the center of the star and an outside object has been reduced because the radius of the star is now almost 0 compared to when it was alive and well and its radius was somewhere around 400 million km? Therefore in the equation F= (Gm1m2/d^2), d could possibly be a lot smaller now if an object got close enough to the black hole. Whereas when the star was alive and well the minimum d could get to would be the radius of the star then the object would get sucked into the star and burn up if it hadnt already.
Dean, think about it this way. Right now you weight X because you are standing on the surface of the Earth. Suppose you took EXACTLY the same mass and crunched it down to the size of a small mountain and you stood on it. Do you see how you would then weigh enormously more?
because I am now far closer to the center of the "earth" which has been compressed to the size of a mountain?
Well, what do you think?
I think that is correct because in F =(Gm1m2/d^2) d would be a lot smaller, which would produce a much larger gravitation force from this new small mountain planet
Right. That's what happens in the runaway implosion the local gravitational force is huge, causing further implosion, causing even bigger local gravitational force causing ...
Thanks a lot for your input, it makes sense now
  • · Replies 17 ·
  • · Replies 22 ·
