What Does Order Mean in the Context of Finite Sets?
  • Thread starter Thread starter Shing
    Sets
In the context of finite sets, the order refers to the number of elements in the set, meaning a finite set of order n contains exactly n members. The Cartesian product A_1 × A_2 × ... × A_n results in ordered n-tuples, where each tuple is a single element of the product set. To prove that the number of subsets of a finite set of order n is 2^n, one can use induction, starting with the base case of a set with one element and extending the argument to k+1 elements. Each subset can be categorized based on whether it includes a particular element, leading to a recursive relationship. Understanding these concepts is crucial for exploring more complex set theory topics.
Shing
I am reading a book named sets & groups,
I would like to ask:
What exactly is a finite set of order n? A_1\times A_2\times A_3...A_n ?
is pair (x_1,x_2,x_3...x_m) counted as a single element? or a set? or an order?
also how should I prove that the number of subsets, including empty set, of a finite set of order n is 2^n?
Thanks!
The order of a set is just the number of elements in a set. So a finite set of order n is a set with n elements.
You can also look at Cartesian products of set, and then the elements of that set will be pairs / triples / (n-)tuples of elements from those sets. You can prove that the order of the product A = A_1 \times A_2 \times \cdots \times A_n is |A| = |A_1| \times |A_2| \times \cdots \times |A_n| where |X| denotes the order of set X.
For your last question: note that if you have finitely many elements you can list them all. One way to proceed is to write down a one or zero for each of them, indicating whether they are in a given subset or not. You can put all of these in an n-tuple. Then show that each such n-tuple corresponds to one particular subset and that each subset can be written as one particular n-tuple; finally count then number of n-tuples you can make.
A set containing exactly n members.
Since you haven't said what A1 etc. are, I can't say!
Well, that's not a "pair" of course, but the "ordered m-tuplet" is a member of
A_1\times A_2\times A_3...A_n.
also how should I prove that the number of subsets, including empty set, of a finite set of order n is 2^n?Thanks!
By induction on n. If A is of order 1, it contains the single element {a} and so has 21= 2 subsets, {} and {a}.
Now, suppose A has k+1 members. Choose one of them, call it z, and note that any subset of A either contains z or doesn't. If it doesn't contain z, it is a subset of A-{z} which has k members. If it does contain z, it can be written as C\union {z}
and C is a subset of A-{z}.
If there are an infinite number of natural numbers, and an infinite number of fractions in between any two natural numbers, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and an infinite number of fractions in between any two of those fractions, and... then that must mean that there are not only infinite infinities, but an infinite number of those infinities. and an infinite number of those...
