A second galaxy with no dark matter
5 replies · 4K views · last reply
If the astronomers who observe this don't know, can you expect an answer here?
MOND predicted that galaxies like this would exist in 1983 due to its "External Field Effect" (which says that dark matter-like phenomena appear at a threshold gravitational acceleration but that the acceleration cutoff must consider both the local field and external gravitational fields in which the system resides). This is the sixth system in which an apparent External Field Effect has been observed. This is discussed in https://arxiv.org/abs/1804.04167 (McGaugh and Milgrom) which said:
MOND and the dynamics of NGC1052-DF2
B. Famaey, S. McGaugh, M. Milgrom
(Submitted on 11 Apr 2018)
The dwarf galaxy NGC1052-DF2 has recently been identified as potentially lacking dark matter. If correct, this could be a challenge for MOND, which predicts that low surface brightness galaxies should evince large mass discrepancies. However, the correct prediction of MOND depends on both the internal field of the dwarf and the external field caused by its proximity to the giant elliptical NGC1052. Taking both into consideration under plausible assumptions, we find σMOND=13.4+4.8−3.7kms−1. This is only marginally higher than the claimed 90\% upper limit on the velocity dispersion (σ<10.5kms−1), and compares well with the observed root mean square velocity dispersion (σ=14.3kms−1). We also discuss a few caveats on both the observational and theoretical side. On the theory side, the internal virialization time in this dwarf may be longer that the time scale of variation of the external field. On the observational side, the paucity of data and their large uncertainties call for further analysis of the velocity dispersion of NGC1052-DF2, to check whether it poses a challenge to MOND or is a success thereof.
From that paper:
MOND also has a good track record of predictive success for pressure supported systems like NGC1052-DF2 (McGaugh & Milgrom 2013a,b; Pawlowski & McGaugh 2014; McGaugh 2016). The analysis in such cases is complicated by the same uncertainties as in Newtonian analyses, such as that in the stellar mass-to-light ratio and the unknown anisotropy in the velocity tracers. Unique to MOND is the external field effect (EFE, Milgrom 1983; Bekenstein & Milgrom 1984; Famaey & McGaugh 2012; Haghi et al. 2016; Hees et al. 2016). Because of the nonlinearity of MOND, the internal dynamics of a system can be affected by the external gravitational field in which it is immersed. When the external field dominates over the internal one, the amplitude of the MOND effect, and the corresponding amount of dark matter inferred, is reduced. Some interesting effects unique to MOND are related to the EFE, such as the prediction of asymmetric tidal streams of globular clusters (Thomas et al. 2018). An essential consequence of the EFE in MOND is that the predicted velocity dispersion of a dwarf galaxy depends on its environment. An object in isolation is expected to have a higher velocity dispersion than the same object in orbit around a massive host. This difference is perceptible in pairs of photometrically indistinguishable dwarf satellites of Andromeda (McGaugh & Milgrom 2013b). Indeed, the EFE was essential to the correct a priori prediction (McGaugh & Milgrom 2013a) of the velocity dispersions of the dwarfs And XIX, And XXI, and And XXV. These cases are notable for their large scale lengths and low velocity dispersions (Collins et al. 2013) — properties that were surprising in the context of dark matter but are natural in MOND. A further example is provided by the recently discovered Milky Way satellite Crater 2 (Torrealba et al. 2016). McGaugh (2016) predicted that this object would have a velocity dispersion of 2.1 +0.9 −0.6 km s−1 , much lower than the nominal expectation in the context of dark matter. Caldwell et al. (2017) subsequently observed 2.7±0.3 km s−1 . Here we take the external field of the host galaxy NGC1052 into account to predict the expected velocity dispersion of NGC1052-DF2 in MOND.
In contrast, the paper notes, this is a big problem for the Standard Model of Cosmology: "With the important exception of tidal dwarfs (Bournaud et al. 2007; Gentile et al. 2007; Lelli et al. 2015), it is thought that a gravitationally-dominant dark matter halo is the sine qua non for the formation of a galaxy. If galaxies such as NGC1052-DF2 are fairly common we may have to revise our concept of what a galaxy is, and come up with alternative pathways for creating galaxy-mass stellar systems."
The 2019 paper is as follows:
A second galaxy missing dark matter in the NGC1052 group
Pieter van Dokkum, Shany Danieli, Roberto Abraham, Charlie Conroy, Aaron J. Romanowsky
(Submitted on 17 Jan 2019)
The ultra-diffuse galaxy NGC1052-DF2 has a very low velocity dispersion, indicating that it has little or no dark matter. Here we report the discovery of a second galaxy in this class, residing in the same group. NGC1052-DF4 closely resembles NGC1052-DF2 in terms of its size, surface brightness, and morphology; has a similar distance of D=19.9±2.8 Mpc; and has a similar population of luminous globular clusters extending out to 7 kpc from the center of the galaxy. Accurate radial velocities of seven clusters were obtained with the Low Resolution Imaging Spectrograph on the Keck I telescope. Their median velocity is ⟨v⟩=1445 km/s, close to the central velocity of 22 galaxies in the NGC1052 group. The rms spread of the observed velocities is very small at σobs=5.8 km/s. Taking observational uncertainties into account we determine an intrinsic velocity dispersion of σintr=4.2+4.4−2.2 km/s, consistent with the expected value from the stars alone (σstars≈7 km/s) and lower than expected from a standard NFW halo (σhalo∼30 km/s). We conclude that NGC1052-DF2 is not an isolated case but that a class of such objects exists. The origin of these large, faint galaxies with an excess of luminous globular clusters and an apparent lack of dark matter is, at present, not understood.
A tweet from van Dokkum (the lead author) states:
@DanieliShany and I found a twin of NGC1052-DF2, with the same weird population of globular clusters and super low velocity dispersion. Meet NGC1052-DF4! https://arxiv.org/pdf/1901.05973v1.pdf … What the paper can't convey is how incredibly surprised we were!
This image was distributed by van Dokkum:
1087182448348286981
The external field effect is notable because:
(1) it is a qualitative difference between GR and MOND-type theories that this data tests experimentally; and
(2) it explains in a way that lambdaCDM cannot, which galaxies will appear to lack dark matter and which will have dark matter phenomena.
The case for an EFF explanation of NGC1052-DF4 is particularly attractive if it happens to be the case that NGC1052-DF4 is closer to NCG1052 than NGC1052-DF2 (since the EFF should be stronger in a galaxy that is closer to NGC1052). I couldn't discern in a quick read of the latest paper if this was the case or not. This is hard to determine because we have a two dimensional view of a three dimensional system and at distances from Earth of 19 Mpc and distances from each other in the plane we see on the order of 40-120 Kpc if they are at the same distance, we can't discern depth at a sufficient level of detail to determine this accurately.
There is a long thread at PF on the previous no DM galaxy in this vicinity. https://www.physicsforums.com/threads/galaxy-with-no-dark-matter-ngc1052-df2.943345/
The fact that the discoverers of this galaxy's interesting properties state that the "origin of these large, faint galaxies with an excess of luminous globular clusters and an apparent lack of dark matter is, at present, not understood," doesn't necessarily imply that nobody else in the astronomy and physics community has an explanation.
In my view, one of the biggest contribution that non-professionals who are active in following developments in science (like contributors at PF) can add to the scientific discussion is a broader awareness of what is going on in the literature outside the narrow subspecialty of professional scientists. We can crowdsource other relevant work in the literature in a way that can be difficult particularly in astronomy which has a very high volume of publications compared to, for example, high energy physics, where there is basically just one active research center in the world producing new data.
As another example, a September 2018 paper also attempts to explain the sister galaxy discovery from a dark matter particle paradigm. It proposes that there should be lots of ultra-diffuse galaxies with little dark matter relative to luminous matter without regard to external field effects:
Surveying dark matter deficient galaxies (those with dark matter mass to stellar mass ratio Mdm/Mstar<1) in the Illustris simulation of structure formation in the flat-ΛCDM cosmogony, we find $M_rm star approximately 2 times 10^8, M_sun galaxies that have properties similar to those ascribed by (vanDokkumetal 2018a) to the ultra-diffuse galaxy NGC1052-DF2. The Illustris simulation also contains more luminous dark matter deficient galaxies. Illustris galaxy subhalo 476171 is a particularly interesting outlier, a massive and very compact galaxy with M_rm star approximately 9 times 10^10 M_sun and Mdm/Mstar ≈ 0.1 and a half-stellar-mass radius of ≈ 2 kpc. If the Illustris simulation and the ΛCDM model are accurate, there are a significant number of dark matter deficient galaxies, including massive luminous compact ones. It will be interesting to observationally discover these galaxies, and to also more clearly understand how they formed, as they are likely to provide new insight into and constraints on models of structure formation and the nature of dark matter.
Hai Yu, Bharat Ratra, Fa-Yin Wang, "Dark matter deficient galaxies in the Illustris flat-ΛCDM model structure formation simulation" (September 16, 2018).
ohwilleke said:
If the Illustris simulation and the LambdaCDM model are accurate, there are a significant number of dark matter deficient galaxies...It will be interesting to observationally discover these galaxies...
I believe there have been numerous low surface brightness, low mass galaxies, similar to these two dark matter deficient galaxies described here, observed by Peter Eskridge circa 1987 pre-Hubble, and also some discussion in the literature by Jay Gallagher about the same time.
Not disagreeing, but the authors of the 2019 paper claimed it was a first of its type as did most lay oriented popular press coverage of the paper.
Rereading I see that these two galaxies are unique in that they have a large population of bright blue globular clusters, while the galaxies I referred to are low surface brightness dwarfs. Wasn't intending to contradict, just alerting to the possibility that the discovery of these galaxies seems to be consistent with the LambdaCDM model...
