A very simple U-sub is wrecking my brain
  • Thread starter Thread starter jinksys
    Brain
10 replies · 2K views
jinksys
Integral Sqrt[16-x^2]*x dx from 0 to 2.
First thing I do is a u-sub, so
u=16-x^2
du=-2xdx
I also my bounds change to upper=12 lower=16.
After I integrate and swap out my U, I get
-1/3*(16-x^2)^(3/2) from 16 to 12.
Am I using the wrong method?
This is probably a stupid question, but why did you change the limits of integration?
Umm, this is actually a trig-substitution problem (which I guess is a class of u-substitution).
Try thinking of it in those terms.
Have you thought of trying a trig substitution?
You sure it's necessary? I get an answer that matches my calculator without incorporating any trig.
EDIT: Oh.
You could do the problem using a u substitution, it's just easier to use the trig substitution.
I actually missed the *x in the problem the first glance through, but I still would go with trig substitution. Necessary, maybe not.
Are my bounds incorrect? I thought you had to adjust your bounds when using a usub.
You adjust if you keep the equation in terms of u, but if you substitute back in for x after integration, you retain the original x boundaries. Seems you substituted back into x and changed the boundaries, which doesn't work.
This clears up a lot. Thanks. I got the correct answer now!
That is one reason why it is a good idea to write the variable in the limits of integration:
[tex]\int_{x= 0}^2 \sqrt{16- x^2} xdx[/tex]
after the substitution [itex]u= 16- x^2[/itex] becomes
[tex]-\frac{1}{2}\int_{u=16}^{12}u^{1/2}du[/tex]
