Example of a non-abelian group where (ab)^2≠a^2b^2
19 replies · 6K views
kathrynag
If G is an abelian group, then (ab)^2=a^2b^2 for all a, b in G. Give an example to show that abelian is necessary in the statement of the theorem.
Abelian implies commutativity.
a*b=?b*a
a^2b^2=b^2a^2
For example ab=ba must be true for the statement to work.
take for example a^2 b^2 and expand it to aabb
what can you do if ab is abelian?
aabb
Implies commutativity so aabb=bbaa
I think there's something with inverse to make this work
Ok so a(ab)b and b(ab)a
so this implies ab=ba
the definition of abelian is not axb = bxa so can't do that
so instead we can swap the ab
I don't really understand. You're saying we can swap the ab, but I don't gte what you mean by this.
(ab)ab=(ab)ba
I don't know what what it making you do. The point was to show that you can find G non-abelian where (ab)^2 is not equal to a^2b^2 for some a and b.
Yeah and I wanted to prove that abelian implied (ab)^2=a^2b^2
Is there a hint for an a and b to use where the 2 aren't equal?
(ab)^2 = a^2 b^2 --->
abab = aabb -------->
cancel the leftmost a and the rightmost b:
ba = ab
well
a^2b^2 = aabb = a(ab)b
because they are abelian ab = ba
so aabb = a(ba)b = (ab)(ab)
what said:
well
But you are supposed to prove that they are Abelian.
Ok I understnd how to prove it now.
I'm having trouble with the example to show abelain is necessary.
It is necessary because:
ba = ab
So, we have that
(ab)^2 = a^2 b^2 implies that ab = ba
This is the same as saying:
Not[ab = ba] implies Not[(ab)^2 = a^2 b^2]
Or, in plain English, if you don't have the Abelian property, you don't have that (ab)^2 = a^2 b^2. So, the Abelian property is a necessary assumption for the identity to hold.
Hmmm, I think I might see this better if I saw a way where it doesn't work. For example (ab)^2 not equaling a^2b^2. Therefore, not abelian
But that's equivalent to Abelian ---> (ab)^2 =a^2b^2
which is the trivial case.
If you know that this is true (so Abelian implies the identity), then should you encounter a case where the identity is not satisfied, you know that the group cannot be Abelian.
that's what I'm trying to do to find a case now where the identity is not satisfied to show then that the group is not abelian
Um, as count Iblis has pointed out *any* non-abelian group will provide a counter example.
You can take some group of matrices. Matrix multiplication does not commute. So, it should be easy to find a particular example where the identity does not hold.
But such a particular example does not show that the fact that the identity does not hold implies that the group is non-abelian. To show that, you need to prove that whenever the identity does not hold, you also have that the group is not abelian.
