About a core-collapse supernova
  • Level: High School
  • Thread starter GIASAL
7 replies · 588 views · last reply
GIASAL
During the collapse of the iron core, the inner part of the core collapses in thousandths of a second—in sonic contact—undergoing a homologous collapse.
Could you explain the meaning to me in more detail?
Thanks
Pretty sure this just means that the relevant part of the core remains at uniform density throughout the process. Everything that was in contact remains in contact - i.e. there's no separation into layers or shells of different density.
Also the shape remains roughly the same as the core decreases in size. Also note that @Bandersnatch 's comment that, "the core remains at uniform density throughout the process" doesn't mean that the density isn't changing. The density is increasing enormously, but at any instant in time the density is roughly constant throughout the core.
I found: the region inside the nucleus where the velocity of falling matter is lower than the local velocity of the sound
That is
If the collapse had occurred in a non-homologous manner, what would the difference have been?
A non-homologous collapse, strictly speaking, just says the velocity is not proportional to r.
In the core of the supernova, the non-homologous part of the collapse is the outer shell which collapses super sonically. That means no signals go from lower down to higher up. Pressure waves still fall down instead of going up.
I will mention that core collapse supernovae, especially if you get into the weeds, is an active research area. It is difficult to give a clear answer at this level of detail for a high school level thread. I would point you to Shapiro and Teukolsky here but that is an upper undergrad / lower grad level book.
Also, I'm sure that the assumption of homologous collapse is only an approximation. If you get into the details, it is probably not completely homologous, and not even spherically symmetric.
