[Abstract Algebra] Field and Polynomial Root problem
8 replies · 3K views
RJLiberator
Suppose a field F has n elements and [itex]F=(a_1,a_2,...,a_n)[/itex]. Show that the polynomial [itex]w(x)=(x-a_1)(x-a_2)...(x-a_n)+1_F[/itex] has no roots in F, where [itex]1_f[/itex] denotes the multiplicative identity in F.
Strategy: We have this polynomial:
When we set it to 0 we see that the (x-a) terms need to equal -1 for w(x) to have a root.
But here's my problem.
I was thinking of trying to use induction on this proof.
But if n = 0, then we have x+1 = 0 and x = i^2 which is in a field, the complex field.
That has a root.
But ok, let's say n = 1. Then we have x-a+1=0 in which case x = 3, a=4 would be a root.
Must I assume that there is more then n=1 elements?
The point is that you already know all possible values for ##x##. What happens if you try them all one by one?
I'm not quite sure what you mean by this. We know all possible values of x? Sure, but couldn't that be from -infinity to +infinity? How does that help?
There must be a deeper understanding to what you are alluding at, but my initial thoughts are that it is confusing. We know all possible values for x?
You are looking for a root of ##w(x)##, i.e. an element ##a ∈ \mathbf{F}## such that ##w(a) = 0##.
Why don't you try all possible ##a## and see what ##w(a)## will get you? There are only finitely many of them, nothing with infinity.
Okay, I am starting to see where you are going with this.
w(x) = (x-a)+1 = 0
w(x)= (x-a1)(x-a2)+1 = 0
[itex]x^2-x*a_2-x*a_1+a_1*a_2+1= 0[/itex]
Couldn't we have a1 = -1 and a2 = 1 and x = 0 ?
w(x) = (x-a)+1 = 0
I think you don't see the forest for all the trees. (Don't know whether this could be said in English, too.)
Again: What is ##w(a)##? (Forget the ##x## for a second.)
w(a) = (a-a)+1 = 1.
So clearly that cannot be a root. So if the product of the (x-a) terms are equal to 0, the +1 disallows it from being a root.
This also works for more terms then just one. As (a-a) = 0, we see (a-a)(a-a1)(a-a2)...(a-an)+1 = 1.
RJLiberator said:
w(a) = (a-a)+1 = 1.
Yes. ##w(a) = (a-a_1) ... (a-a_n) +1_F## but ##a \in \mathbf{F} = \{a_1, ... , a_n\}##. Therefore ##w(a) = 1_F## and ##1_F \neq 0_F## because ##\mathbf{F}## is a field.
Ugh, I can't believe I didn't see this obvious result from the start.
I'm so out of it lately.
That is completely obvious :p.
Indeed.
