Accelerating into a black hole?
In summary, the relativistic effects of falling into a black hole could theoretically balance out the length contraction and spaghettification, but it would still hurt.
spinstate
TL;DR Summary
If falling into a black hole would lead to you being spaghettified, and moving relativistically towards it would contract your length / etc., is there a speed at which they balance out?
I'm sure this has been asked before, but it's lost to me among all the false positives... If falling into a black hole would lead to you being spaghettified, and moving relativistically towards it would contract your length / etc., is there a speed at which they balance out? Seems calculable but there's no way I can do it, unless it's a flawed premise..?
If it is possible, what kind of acceleration would be required to maintain that as you progress? The other relativistic effects are interesting to contemplate as well.
It is. You're not contracted in your own reference frame.
Likes mfb
You could simply free fall into a black hole with sufficient speed so that the elapsed proper time is too short for tidal stresses to result in significant spaghettification before the event horizon is passed.
Or, adopting the faller's frame, before the event horizon passes by.
Yes and no.
Length contraction depends on your speed relative to an observer. It's not something you feel - in the frame of a particle passing the Earth at 0.99c you are severely length contracted, but it makes no difference to you. On the other hand, spaghettification is a very real stretching of you, which would be painfully detectable by you.
So you could certainly pick a velocity profile such that some chosen observers measured your length as unchanging. However it would still hurt since its only the spaghettification that's "really" happening.
Care would be needed in doing the maths since it's necessarily happening in curved spacetime and naive SR results do not apply. Also you'd need a relativistic model of the elasticity of your body to model the spaghettification. It's rather complex.
Right, I see. Your own frame is not contracted of course. One of relativity's gotchas. >.< As with your example of a particle passing Earth at 0.99c, an observer "within" the black hole also see a contracted you coming in, but that doesn't affect what you feel. Got it.
So what about the time dilation effects? Traveling relativistically slows your clock relative to another that is not, right? So in the same scenario, what happens? From your perspective, the black hole itself is contracted. Would it be like slamming into a brick wall? But then... I've heard that certain particles from space penetrate deeper into the atmosphere before decaying than non-relativistic estimates would predict because the Earth is contracted. So from an observer's perspective, would you be get any closer before being spaghettified? Or is it incorrect to compare those two things?
Actually, maybe I can rephrase my original question too: Would accelerating, as in a booster pushing you from behind, reduce the tidal effects?
Likes PeroK
There is nothing to slam into. The event horizon is an imaginary surface. Coming up to and through it has no local effect.
Locally, the event horizon is like an imaginary surface moving at light speed toward you. You can pass through it inward toward the singularity. Once past it you cannot turn around and get back out because it is receding at light speed.
Yes, but only by approximately a factor of two.
If you have a booster pushing from behind, there is compressive stress throughout your body. It is greatest at your feet where the entire weight of your body is supported by the floor. It is zero at the top of your head.
If you have tidal stresses stretching you out, there is tensile stress throughout your body. It is greatest at your midriff and zero at your head and toes.
So if you try to cancel tidal stretching with booster compression, you have the problem that the stress profiles do not match. That's what I'm hand-waving as "a factor of two".
Edit: Blood circulation is more of a problem. Standing on an accelerated floor does nothing to ensure that blood gets back from your head and toes to your heart.
No - length contraction only applies in flat spacetime. There isn't an easy way to say what size and shape a black hole "actually is" from the perspective of an infalling observer. It's relatively straightforward to say how it looks to such an observer, and to write the 4d path of the light you use to see it. However, untangling which part of spacetime you regard as "space" in order to say what the black hole "actually" looks like now (removing the light speed lag) is pretty much an arbitrary process, unlike in flat spacetime where more or less any sensible approach gives you the same answer.
1. What happens when an object accelerates into a black hole?
As an object approaches a black hole, it experiences extreme gravitational forces that cause it to accelerate. As it gets closer to the black hole, the acceleration increases, eventually reaching the speed of light. At this point, the object is considered to have crossed the event horizon, the point of no return, and is pulled into the black hole's singularity.
2. Can anything escape a black hole's gravitational pull?
No, once an object has crossed the event horizon of a black hole, it is impossible for it to escape the gravitational pull. This is because the escape velocity, or the speed needed to overcome the gravitational pull, is greater than the speed of light.
3. How does the acceleration of an object change as it gets closer to a black hole?
The acceleration of an object increases as it gets closer to a black hole. This is due to the strong gravitational pull of the black hole, which becomes more intense as the distance between the object and the black hole decreases.
4. What is the role of time dilation in accelerating into a black hole?
Time dilation is a phenomenon that occurs near massive objects, such as black holes. As an object accelerates towards a black hole, time appears to slow down for an outside observer. This is because the intense gravitational field of the black hole warps spacetime, causing time to pass at different rates for different observers.
5. Can we observe the acceleration of objects into black holes?
Yes, we can observe the effects of objects accelerating into black holes through various methods, such as measuring the gravitational waves emitted during the acceleration or observing the distortion of light from objects near the black hole. However, direct observation of the actual acceleration is not possible due to the extreme conditions near a black hole.
