Required Precision for GPS Distance Measurement
The discussion centers on the precision required for GPS distance measurement, specifically determining the percent accuracy needed for a 2-meter uncertainty when measuring a distance of 20,000 km. The calculated percent accuracy is 0.00001%, confirming the need for high precision. Additionally, it is established that 8 significant figures are necessary to ensure that the last digit represents a 1-meter accuracy, which is essential for achieving the desired 2-meter precision in GPS measurements.
  • Understanding of GPS distance measurement principles
  • Knowledge of significant figures and their importance in precision
  • Familiarity with relative uncertainty calculations
  • Basic proficiency in unit conversion (kilometers to meters)
  • Research "GPS accuracy and precision" to understand factors affecting measurements
  • Study "significant figures in scientific measurements" for better clarity
  • Explore "relative uncertainty calculations" for practical applications
  • Learn about "GPS signal processing techniques" to enhance measurement accuracy
Students studying physics, particularly those focusing on measurement accuracy, as well as professionals in fields requiring precise GPS data, such as surveying and navigation.
DSG3002
GPS can be used to determine positions with great accuracy. The system works by determining the distance between the observer and each of the several satellites orbiting Earth. If one of the satellites is at a distance of 20,000 km from you, what percent accuracy in the distance is required if we desire a 2-meter uncertainty? How many significant figures do we need to have in the distance?
I'm new to Physics and I'm just taking it this year, so all I could figure is converting 20,000 km to 20,000,000 meters. That's all I know to do, though.
And 2m is how many percent of 20,000,000m?
So that makes the percent accuracy 1 x 10^5 % (or 0.00001%)?
What about significant figures in the distance? I don't understand what the question means by that... (This is from a worksheet I have.)
Chrisas said:
Watch out for your typo...that should be 10^(-5)%. But other than that, I think that's right.
See this for significant digits rules/examples
http://www.batesville.k12.in.us/Phy...t/Significant_Digits.html#counting sig digits
With an uncertainty of 2 meters, the range measurement could be any where from
20,000,002 meters to
19,999,998 meters.
How many digits are required to write those numbers?
So, 8?
Thanks for your help. I figured this would be overlooked since it looks like cake compared to the other questions I've seen asked here.
I would say 8 is correct. No problem, hope it's right :)
19,999,998 meters.
Technically it's asking how many digits are needed to write the distance to the satellite so that the precision represented by the last digit is less than the desired uncertainty. In this case, if you write 8 digits, the last of those digits represents 1-meter accuracy (remember the place value system?). If you only had 7 significant digits, the last of those digits would represent 10-meter accuracy, so the distance 20,000,000 with seven significant digits (the last zero being an insignficant digit) would have an inherent uncertainty of 10 meters. That's too large to be able to tell where you are to 2-meter precision.
But bottom line, I agree with 8 digits being the correct answer here.
  • · Replies 19 ·
