Adding scientific notation question =)
The discussion revolves around the addition of three values in scientific notation: (9.8x10^3s), (9.9x10^4s), and (0.017x10^6s). The user attempted to submit answers of 125800 and 1.26x10^5, but both were marked incorrect, likely due to issues with significant figures. The correct approach involves aligning the numbers to a common exponent and ensuring the final answer adheres to the proper significant figures. The consensus is that the user needs to adjust their answer to reflect the correct number of significant digits. Understanding significant figures is crucial for correctly solving problems in scientific notation.
dolpho
Add (9.8x10^3s)+(9.9x10^4s)+(0.017x10^6s)
None
I have entered 125800, as well as 1.26x10^5 but the website marked both of those wrong. I've done this problem every way you could do it I think and it comes out to the same answer but the program won't accept it.
I presume this has to do with significant digits a.k.a significant figures.
(9.8x103s) + (9.9x104s) + (0.017x106s) = (0.98x104s) + (9.9x104s) + (1.7x104s)
So I worked out your problem also and it gave me 125800 and it just says add, but I'm guessing it doesn't want the answer but what you gave instead. Ugh I hate mastering physics... :(
You were already pointed to significant figures. Both numbers you have tried have too many.
  • · Replies 27 ·
13K
11K
  • · Replies 35 ·
11K
