Advanced Arithmetic: Find Min Digits for Fraction Decimal
  • Thread starter Thread starter Michele Nunes
    advanced Arithmetic
The discussion revolves around determining the minimum number of digits required to express a given fraction as a decimal. The problem involves understanding the implications of dividing by specific numbers and how that affects the decimal representation.
  • Participants explore the process of dividing the fraction by 2 and how this affects the number of decimal places. There are attempts to clarify the reasoning behind adding digits based on the oddness of the numerator. Some participants question the validity of separating terms in the division process and whether it leads to correct conclusions.
The discussion is ongoing with participants providing insights and seeking clarification on various aspects of the problem. Some guidance has been offered regarding the division process, but there remains uncertainty about the separation of terms and the overall approach.
Participants note that calculators are not allowed, which adds a layer of complexity to the problem-solving process. There are also references to specific numbers and their properties that are under examination.
Michele Nunes
What is the minimum number of digits to the right of the decimal point needed to express the fraction
as a decimal?
a) 4
b) 22
c) 26
d) 30
e) 104
One possible solution is: "We can rewrite the fraction as
. Since the last digit of the numerator is odd, a
is added to the right if the numerator is divided by [PLAIN]https://latex.artofproblemsolving.com/4/1/c/41c544263a265ff15498ee45f7392c5f86c6d151.png, and this will continuously happen because [PLAIN]https://latex.artofproblemsolving.com/7/9/0/79069377f91364c2f87a64e5f9f562a091c8a6c1.png, itself, is odd. Indeed, this happens twenty-two times since we divide by https://latex.artofproblemsolving.com/4/1/c/41c544263a265ff15498ee45f7392c5f86c6d151.png twenty-two times, so we will need
more digits. Hence, the answer is [PLAIN]https://latex.artofproblemsolving.com/8/9/7/897cab64b41a26c4bf59f579a975ec600cf2441b.png."
So I understand how they rewrote the fraction, however I'm totally lost by everything after that. I'm not exactly sure why a 5 is added to the right if the numerator is divided by 2 and how that has anything to do with the last digit being odd. Also, a calculator is not allowed on this. If someone could either clarify the explanation given or give a more simplified alternate solution, that would be appreciated.
I think it is a bit more clear if you do the division by 104 at the end.
123456789=123456788 + 1. Divide it by 2 : it becomes an integer + 0.5 that means one decimal.
Divide that number by 2 gain, you get an integer, + 0.25, so you have two decimals. Do again: it is something + 0.125. Repeat: the number of decimals increases by one at every division by 2. The first term becomes odd after some divisions, but that will have less decimals than the division of 1.
So how many decimals are there if you divide by 222 (that is, you do 22 divisions) ?
Okay I'm kind of making sense out of it. If you divide 1 by 222 then you will have 22 decimals, and then if you divide 123456788 by 104 then you will have 4 decimals, and 22 + 4 = 26, I don't know though something about that process seems off, I feel like you can't just separate them like that, can you?
Is 123456789 = 123456788 +1?
Is (a+b)/2 = a/2 + b/2 true?
try with a smaller number : How many decimals are there in 9/23?
Yes, but I would have 123456788/(222 * 104) + 1/(222 * 104)
and if I ONLY divided 123456788 by 104, then where did the 222 in the denominator go
and if I ONLY divided 1 by 222, then where did the 104 in the denominator go, do you see what I mean?
##\frac {A}{b c}= \frac {A/b}{c} ##. If you have a product of two numbers in the denominator, you can divide by one number, then you divide the result by the other.
Here, you divide by 222 first, then you divide the result by 104.
If you evaluate ##\frac{36}{3*4}## you can do it by dividing 36 with 12 or first dividing 36 by 3 (you get 12) then dividing 12 by 4 - the result is 3 with both methods.
Do you understand it now?
Yes for the most part, thank you!
  • · Replies 19 ·
