Age of the Universe and the Cosmological Constant
  • Context: Undergrad
  • Thread starter Thread starter Ranku
The discussion revolves around the implications of the cosmological constant on the age of the universe, exploring the relationship between the Hubble constant, expansion rates, and different cosmological models. Participants examine theoretical frameworks, mathematical formulations, and the effects of dark energy on cosmic expansion.
  • Some participants suggest that the presence of the cosmological constant leads to an older universe due to a longer time taken to reach the current expansion rate.
  • Others argue that the age of the universe is not simply the inverse of the Hubble constant in general, particularly in models with dark energy.
  • A participant proposes that if galaxies had a lower recession velocity in the past, they would require more time to reach their current positions, suggesting that dark energy influences the perceived age of the universe.
  • There is a discussion about whether the age of the universe can be calculated using Friedmann's equations and the scale factor, with some asserting that it involves multiple components like radiation, matter, and dark energy.
  • Some participants question the validity of assuming a single component dominates the expansion history when calculating the age of the universe.
  • One participant mentions that the current expansion rate is a crucial parameter, indicating that previous rates would be lower in a constantly accelerating universe.
  • There is a call for clarity on the standard formula for calculating the age of the universe, with participants noting the lack of a universally accepted formula without specific assumptions.
Participants express disagreement on several points, particularly regarding the relationship between the Hubble constant and the age of the universe, the role of the cosmological constant, and the validity of different models. No consensus is reached on these issues.
Participants highlight the complexity of cosmological models, noting that assumptions about the dominance of certain components can significantly affect calculations of the universe's age. The discussion reflects varying interpretations of the implications of the cosmological constant and the mathematical formulations involved.
Ranku
The presence of the cosmological constant means that the universe is older than it otherwise would have been if it were a purely matter dominated universe. The physical rational is that "a cosmological-constant universe is older because it took longer to reach its present rate of expansion". I am having a hard time understanding quite what that means. Since the age of the universe is the inverse of the Hubble constant, as in 1/H = D/V, so one would expect a higher age would require a lower value of V. However, the cosmological constant accelerates the expansion of the universe, which would lead to a higher V than would be the case if the universe were expanding purely gravitationally deceleratingly. So, what is the missing piece here that leads to a higher age with higher V?
Space news on Phys.org
No, it isn't.
In a ##\Lambda=0## universe, ##1/H## is the age of the universe. Not in general.
I suppose one way to think of it is if you think of two galaxies on opposite sides of us at the same redshift, if you calculate backwards assuming they had constant recession velocity then they'd be coincident with us at some time in the past. But if their recession velocity was lower in the past they'd need more time to get from coincident with us to where they are now. So factoring in dark energy the singularity is longer ago than if you assume constant recession speed.
I'm not sure even that is true. I think it's only true in the edge case of the Milne universe.
The age of the universe was calculated with Friedmann's equations involving the scale factor?, or do I remember wrong?
The actual age of the universe is calculated using our best current model of the time dependence of the scale factor. This model involves Friedmann's equations, yes, but with multiple functions for the density and pressure (one each for radiation, matter, and dark energy--our best current model is spatially flat so there is no term for spatial curvature in it, although one does see that term in more general presentations), and those functions have different time dependences. So the behavior of the scale factor over time is not just one simple function.
Note that this model is decelerating (radiation dominated until a few hundred thousand years after the Big Bang, then matter dominated) until a few billion years ago, and then accelerating (dark energy dominated) after that. But it still gives a longer age of the universe than a purely matter dominated model with the same Hubble constant at the current epoch would give.
So does this logic also apply to a universe where the recession velocity was less than constant, such as in a gravitationally decelerating expanding universe?
The opposite would apply: the singularity would be a shorter time ago than if you assume constant recession velocity.
So when you add the cosmological constant, to a universe that was expanding deceleratingly, the singularity would be even a longer time ago, compared to a universe that was expanding with uniform velocity.
You don't do that. You're not taking a universe with matter in it and adding a cosmological constant. You're comparing different models, one of which has a cosmological constant and one of which doesn't. (Actually, if you include the "constant recession velocity" model, you have two which don't, one matter dominated--the decelerating one--and the other of which has nothing in it at all--the "constant recession velocity" one.)
In the Friedman equations with the cosmological constant, doesn’t the energy density rho include the energy density of the cosmological constant?
With the cosmological constant, yes. But that doesn't mean you can take a model without a cosmological constant, and ask what happens if you add one. That's a meaningless question. The only meaningful question you can ask is about a comparison between a model that has a cosmological constant and a model that doesn't, and how well each model explains the data we have.
Perhaps what you're not taking into account is that the parameter we know (because we've measured it) is the current expansion rate. For a constantly accelerating universe, all previous rates are less than the current one, while for a decelerating one, the opposite is true.
(To avoid confusion, I clarify that the most widely accepted current model doesn't fit either of the two described above.)
Anyone wants to put the standard formula for calculating the age of the universe using the Friedman equations - l am seeing different versions of it strewn around.
It is not. Assuming one component dominates the entire expansion history it is a numerical factor multiplied by 1/H. Iirc, this factor is 2/3 for a matter dominated universe, but don’t quote me in that …
There is no standard formula except if you assume domination by one component. Generally you have to solve the Friedman equations to find out.
The current age of the universe ##T## can be calculated using the following formula:
$$T = \frac c {H_0} \int_0^1 {\frac {a \hspace{2mm} da}{\sqrt{\Omega_{r_0} + \Omega_{m_0} a + \Omega_{k_0} a^2 + \Omega_{Λ_0} a^4}}}$$
To connect to what I said above, I meant that there is no algebraic closed form expression for the general case. The integral here is in essence the solution to and results from integrating the Friedman equations. The general case has no closed form solution, but of course the integral can be solved directly if only one ##\Omega## is non-zero.
For example, if ##\Omega_{m_0} = 1## we obtain
H_0 T = \int_0^1 \sqrt a \, da = \frac 23
$$ as mentioned earier for a matter dominated universe.
I just noticed an error in my list of equations and remembered using it here, so I'm correcting it:
$$T = \frac 1 {H_0} \int_0^1 {\frac {a \hspace{2mm} da}{\sqrt{\Omega_{r_0} + \Omega_{m_0} a + \Omega_{k_0} a^2 + \Omega_{Λ_0} a^4}}}$$
  • · Replies 19 ·
  • · Replies 19 ·
  • · Replies 20 ·
