Air compressor pump HP requirement?
  • Thread starter Thread starter Ryoko
The discussion centers on the challenges faced when replacing an air compressor pump with a Harbor Freight unit that requires 1050 RPM and 5 HP. The existing motor, rated for continuous duty at 230V and 15A, is likely only capable of around 3.7 HP due to efficiency losses, leading to overheating issues. Participants suggest that the motor's specifications may be misleading and recommend de-rating the motor and resizing the pump. Additionally, they discuss the importance of cooling the compressed air and adjusting system settings to prevent overheating.
  • Understanding of air compressor components and specifications
  • Knowledge of motor efficiency and power ratings
  • Familiarity with cooling mechanisms for compressed air systems
  • Basic electrical knowledge regarding timers and relays
  • Research "air compressor motor efficiency ratings" to understand real-world performance
  • Learn about "compressor pump sizing" to ensure compatibility with motor specifications
  • Investigate "cooling methods for compressed air" to enhance system performance
  • Explore "timer circuits for compressor control" to prevent overheating issues
This discussion is beneficial for air compressor users, mechanics, and DIY enthusiasts looking to optimize compressor performance and troubleshoot overheating issues effectively.
Ryoko
I replaced the pump on my air compressor with a Harbor Freight unit. The new pump says it requires 1050RPM and 5HP to drive it. The compressor has a 5HP motor which is supposed to be rated for continuous duty according to its spec plate. But it's unable to drive the new pump for more than a few minutes without tripping the overheat breaker on the motor. This is leading me to believe the pump is drawing more than 5HP. I've tried reducing the drive pulley size so the pump is now running around 800 RPM. But it still wants to trip the overheat breaker. The old pump had no issues until it croaked. So I'm wondering what's going on. Should the pump be undersized vs the motor to run reliably?
The 5 HP spec on your old motor is quite likely false. If the motor has a spec for continuous amperage draw that will give you an idea of what it actually is.
I think you're right. I looked up the specs again on the motor and it says 230v @ 15A and claims to be 5HP. The power specs work out to 4.6HP. So they rounded up. But that also assumed 100% efficiency. Since this is an induction motor, I'm guessing the actual HP is around 80% of the ideal figure or 3.7HP. This may well explain why the motor is struggling. As an added handicap, the line voltage is 220V rather than 230V which is probably contributing to the problem. So I guess I need to de-rate the motor accordingly and resize the pump.
They have creative ways of lying about the spec. Maybe the service factor is significantly reduced. This effectively says it will start a load typically suited for a 5 HP motor and run it for a short time. This is basically what you have experienced. When it's sold as a package the user is happy. It pumps and doesn't trip on overload. The company will say that you have modified it by replacing the pump so tough luck.
My shop compressor is a very old Quincy pump with a rusted out tank. The rusted out tank simply serves as the mount for the pump and motor. There is 200 gallon tank along side that I pump into. It's slow because I had a spare 3 HP motor to use in place of the 5 that came on it so the pump is slowed down so the motor can take it.
What was the capacity of the old pump in cubic feet of free air per minute?
How does that compare with the replacement?
Did the original pump have an unloading valve in the head, does the replacement pump have the same? Or is the motor turning off when the set pressure is reached?
Consider also the immediate cooling of the compressed air. The outlet from the pump will be hot air, which should be cooled at the head, before it enters the reservoir. Cooling the pump head will lower the peak pressure reached during compression.
The outlet pressure setting on the system, or the pump RPM and capacity, should be reduced for an under-rated motor.
I don't know the old pump's specs. It was extremely noisy. The unloading valve is built into the pressure switch. I already have a radiator on the pump outlet which works quite well.
200 Gal air resivoir tank is big .... I don't know what you use this for , most aplications only require short bursts of use (tyre pressure in garage etc), so compressor is only on for a short time... you could just leave things as they are , the overheat breaker is protecting from damage ... If the breaker requires manual reset this might be annoying , in which case install a timer which switches off before the breaker does .... so the timer is constantly switching on for 1 minute , off for 10 minutes (to allow cooling) this will let the compressor run only if tank pressure is low .... timer circuitry $5 ..... switching a 50A AC Solid State Relay $5
Or, you could pay attention to which poster is posting what.
  • Haha
LOL, that confused me too. I had to use a Search on the thread to figure out where he got the 200 gallon number from. :smile:
Just out of curiosity, though, why such a huge compressed air storage tank?
Very large tires, some sandblasting now and then, air tools, etc.
  • · Replies 19 ·
  • · Replies 33 ·
  • · Replies 16 ·
11K
