Algebra II Equations Containing Radicals Part 2
  • Thread starter Thread starter velox_xox
    Algebra Radicals
5 replies · 2K views
velox_xox
I managed to get the other problems right, but this one I've been fiddling with and can't seem to get the right answer.
[tex]\sqrt {3b -2} - \sqrt {2b + 5} = 1[/tex]
Answer: [itex]22[/itex]
For this I tried the method of leaving the equation as is and squaring both sides, since this is the way the textbook seems to want me to learn it for this lesson.
[itex]\sqrt {3b - 2} - \sqrt {2b + 5} = 1[/itex]
[itex](\sqrt {3b - 2} - \sqrt {2b + 5})^2 = 1^2[/itex]
[itex]3b - 2 - 2\sqrt {6b^2 - 10} + 2b + 5 = 1[/itex]
[itex]5b + 3 - 2\sqrt {6b^2 - 10} = 1[/itex]
[itex]5b + 3 = 2\sqrt {6b^2 - 10}[/itex]
[itex](5b + 3)^2 = (2\sqrt {6b^2 - 10})^2[/itex]
[itex]25b^2 + 30b + 9 = 4(6b^2 - 10)[/itex]
[itex]25b^2 + 30b + 9 = 24b^2 - 40[/itex]
[itex]b^2 + 30b +49 = 0[/itex]
At this point, I realize that 22 isn't a factor of that final equation. I've also tried the other methods, such as [itex]\sqrt {3b - 2} = \sqrt {2b + 5}[/itex], and I get b = 7.
I've tried to look through it for obvious arithmetic mistakes or my tendency to create incorrect products of the form (a + b)^2, but I didn't see anything. It could be the sheer volume of the problem has me spooked or tripping up.
Any help would be greatly appreciated. Thanks in advance.
This is how I would do it, but you have omitted a term.
The equation should be ##\sqrt {3b - 2} = \sqrt {2b + 5} + 1##.
Now square both sides.
Starting from the original equation, move the second radical to the other side and square both sides. You should end up with:
[itex]3b - 2 = (1 + \sqrt{2b + 5})^2[/itex]
After foiling, combine like terms and solve for the [itex]2\sqrt{2b + 5}[/itex] term. You should end up with b - 8 on the other side.
Square both sides once more.
[itex](b - 8)^2 = 4(2b + 5)[/itex]
Foil/distribute and set equal to zero.
Factor the remaining equation and you should end up with zeroes of 2 and 22.
Plug both answers back into the original equation to see which ones work.
Good luck :)
You're missing the +11b term from multiplying out (3b-2)(2b+5).
You also forgot to subtract the 1 on the right side over to the left side.
Aaah, I see. Apparently, I have trouble with my factoring instincts. A.k.a. I need to factor things out the old fashioned way as opposed to doing mental math.
I see where I went wrong and even though my textbook seems to want me to keep the radicals all on one side, I think I'm going to make exceptions for cases such as this. It gets incredibly messy and too advanced for me the other way. Nevertheless, I tried it out just to try and understand what I was missing; and even though, I couldn't arrive at an answer that way, thanks to everyone's pointers I see where I went wrong here again.
So, thank you Mark44, Hertz (thanks for the luck; I need it! :D), Bohrok, and Villyer.
Here's what I got the last time:
[itex]\sqrt {3b -2} - \sqrt {2b + 5} = 1[/itex]
[itex](\sqrt {3b - 2})^2 =(\sqrt {2b + 5}+ 1)^2[/itex]
[itex]3b - 2 = 2b + 5 + 2\sqrt {2b + 5} + 1[/itex]
[itex](b - 8)^2 = (2\sqrt {2b + 5})^2[/itex]
[itex]b^2 - 16b + 64 = 4(2b + 5)[/itex]
[itex]b^2 -16b + 64 = 8b + 20[/itex]
[itex]b^2 - 24b + 44 = 0[/itex]
[itex](b - 2)(b - 22) = 0[/itex]
b = 2 or b = 22
'2' doesn't work; it produces 2 - 3 = 1; '22' checks out with an 8 - 7 = 1. So, unless I bent the rules of algebra to solve this, case closed.
Thanks once again everyone!
