Is There a Trick to Solve for Theta in this Algebraic Equation?
  • Thread starter Thread starter scavok
    Algebra
The discussion revolves around solving for theta in an algebraic equation involving a constant g and a square root. Participants explore various strategies to manipulate the equation to isolate theta.
  • The original poster seeks a method to simplify the equation, particularly questioning the possibility of canceling the denominator within the square root. Some participants suggest alternative approaches, such as substituting variables and squaring both sides of the equation.
Participants are actively engaging with the problem, offering hints and discussing potential methods to manipulate the equation. There is a focus on variable substitution and the implications of squaring the equation, though no consensus has been reached on the correctness of the approaches taken.
There are indications of confusion regarding the physical implications of the solutions derived from the quadratic equation, with one participant expressing concern over the results obtained.
scavok
http://home.comcast.net/~andykovacs/equation.GIF
g is a constant. I need to find theta.
Is there some trick I can do to cancel out the denominator in the root?
Hint:
Set
y=\sqrt{\sin\theta}
and see what type of equation you get for y.
No, you can't cancel- but you can square. I would first divide the entire equation by g sin(\theta) to get
\frac{20}{g sin(\theta)}= \frac{14}{g sin(\theta)}+ \sqrt{\frac{14}{g sin(\theta)}}+ 8.41
I would even write it as
\frac{10}{7}\frac{14}{g sin(\theta)}= \frac{14}{g sin(\theta)}+ \sqrt{\frac{14}{g sin(\theta)}}+ 8.41
because then I can let y= \frac{14}{g sin(\theta)} and have
\frac{10}{7}y= y+ \sqrt{y}+ 8.41
That gives
\frac{3}{7}y- 8.41= \sqrt{y}
Square on both sides:
(\frac{9}{49}y- 8.41)^2= y[/itex]<br /> <br /> Solve that quadratic equation for y and then solve <br /> y= \frac{14}{g sin(\theta)}<br /> for \theta.
Do you get y=-11.2432 and y=-1.0611 after solving the quadratic equation? If so then I probably screwed up with the physics.
  • · Replies 21 ·
  • · Replies 21 ·
