All the lepton masses from G, pi, e
  • Level: Graduate
  • Thread starter arivero
    Lepton Pi
Multiple poll: Check all you agree.
  • Logarithms of lepton mass quotients should be pursued.
    Votes: 21 26.6%
  • Alpha calculation from serial expansion should be pursued
    Votes: 19 24.1%
  • We should look for more empirical relationships
    Votes: 24 30.4%
  • Pythagorean triples approach should be pursued.
    Votes: 21 26.6%
  • Quotients from distance radiuses should be investigated
    Votes: 16 20.3%
  • The estimate of magnetic anomalous moment should be investigated.
    Votes: 24 30.4%
  • The estimate of Weinberg angle should be investigated.
    Votes: 18 22.8%
  • Jay R. Yabon theory should be investigate.
    Votes: 15 19.0%
  • I support the efforts in this thread.
    Votes: 43 54.4%
  • I think the effort in this thread is not worthwhile.
    Votes: 28 35.4%
  • Total voters
    79
492 replies · 177K views · last reply
granpa said:
from post #342:
it allows 4 generations if you count m=0
If you'll look carefully at the formula, you will find that putting 4 into the equation gives you the same masses as if you'd put 1. This is because trig functions repeat every 2 pi.
I'm preparing a submission for Phys Math Central on the subject of Koide's mass formulas for the hadrons. I'm supposed to have something ready by January 10th. The latest cut is here:
http://www.brannenworks.com/koidehadrons.pdf
Carl
I was using this formula:
Equation Q = (m_e + m_mu + m_tau) / (sqrt(m_e) + sqrt(m_mu) + sqrt(m_tau))^2, a ratio of the summed lepton masses to the squared sum of their square roots.
a mass of zero can be added to numerator and denominator without changing anything.
CarlB said:
I
Carl
Hi Carl,
I would use some more group notation. Instead of your 6x6=36, I'd vote by 6 x bar6 = sum of irreps.
Second, besides to the "extraordinary" case you put, I'd include more of the "Ordinary" case, meaning the original argument of Koide about his formula for composite particles, along the lines of the original PhysRev.
there are obviously an infinite number of formulas relating the masses of the electron muon and tauon. the beauty of the koide formula is its simplicity and elegance. especially the fact that Q=2/3 which is exactly halfway between the upper and lower limits of 1 and 1/3.
as wikipedia puts it:
Not only is this result odd in that three apparently random numbers should give a simple fraction, but also that Q is exactly halfway between the two extremes of 1/3 and 1.
the formula involving cos given above seems to me to lack this elegance. it should be obvious that anyone can always find a formula involving cos that will pass through any 3 points quite easily.
arivero said:
Hi Carl,
Hmmm. The only place I've got 36 in the thing right now is the calculation for the square of a set of MUBs. In terms of color, this would be
[tex](3+\bar{3})\times (3+\bar{3})[/tex]
i.e. (R+G+B+/R+/G+/B)^2,
and I guess the symmetry would be, (hems and haws whilst trying to recall Georgi), uh, let's see, maybe
[tex](3+\bar{3})\times (3+\bar{3})<br /> = 8+\bar{8}+6+\bar{6}+3+\bar{3}+1+\bar{1}[/tex]?
Yes, as usual, your comment is brilliant and I will incorporate it.
In a certain sense, what I'm doing is taking the
[tex]3\times \bar{3} = 8+1[/tex]
definition of gluons and claiming that I can compute in qubits with it using 3x3 matrices. [If you can read this, then PhysicsForums let me edit out a silly comment about 6+3-bar.]
Because both can be faithfully represented by 3x3 complex matrix addition and multiplication. From the symmetry point of view, it's a matter of selecting a certain ratio of the coupling constants.
You mean the 1982 article I suppose. I guess I'll have to hike over to the university and read the article. Somehow I don't think I've ever downloaded it. One of the things I'm trying to do is to avoid talking about the preon model. There are two reasons for this. First, it doesn't apply to hadrons, and second, it gets into hot water with Coleman Mandula or (worse) spin statistics.
I think I should be ready to release a first cut in a few days. It still doesn't have "results" and the abstract is obsolete. But I've redone the results section to be make an argument that hangs together better.
The most recent arXiv included a hep-th article that I thought was pretty cute.
Symmetries of Nonrelativistic Phase Space and the Structure of Quark-Lepton Generation
Piotr Zenczykowski.
According to the Hamiltonian formalism, nonrelativistic phase space may be considered as an arena of physics, with momentum and position treated as independent variables. Invariance of x^2+p^2 constitutes then a natural generalization of ordinary rotational invariance. We consider Dirac-like linearization of this form, with position and momentum satisfying standard commutation relations. This leads to the identification of a quantum-level structure from which some phase space properties might emerge. Genuine rotations and reflections in phase space are tied to the existence of new quantum numbers, unrelated to ordinary 3D space. Their properties allow their identification with the internal quantum numbers characterising the structure of a single quark-lepton generation in the Standard Model. In particular, the algebraic structure of the Harari-Shupe preon model of fundamental particles is reproduced exactly and without invoking any subparticles. Analysis of the Clifford algebra of nonrelativistic phase space singles out an element which might be associated with the concept of lepton mass. This element is transformed into a corresponding element for a single coloured quark, leading to a generalization of the concept of mass and a different starting point for the discussion of quark unobservability.
http://arxiv.org/abs/0901.2896
Taunus said:
Let Me be the mass of the electron, Mp be the mass of the proton, and Mn be the mass of the neutron. Then observe that
Mn/Me - Mp/Me is approximately equal to ln(4*pi) = 2.5310...
Of course, it is really the quotient between the electromagnetic isospin breaking, (Mn-Mp), and the mass of the electron.
ellipsoid of volume
4pi(4pi-1/pi)(4pi-2/pi) = 1836.15...
Which is approximately equal to Mp/Me (a very old result)
Hmm not sure how old is this "ellipsoid". A really old approximation to Mp/Me as 6 pi^5 has been discussed in the middle of this thread.
I hesitate to put in measured values since Mp/Me has changed several times. At one time the ellipsoid volume was within one standard deviation of the accepted CODATA value, but the accepted value changed. I simply rest my case with the mathematical formulae.
A pseudoconvention in this thread is to put both the exact quotient between left and right sides of the equality AND the one-sigma error of this quotient. In this way it is clear how much we can expect the fit to change.
A tradition in this thread is to put both the exact quotient between left and right sides of the equality AND the one-sigma error of this quotient. In this way it is clear how much we can expect the fit to change.
In any case, according current pdg data:
mn − mp = 1.2933317 ± 0.0000005 MeV
Me= 0.510998910 ± 0.000000013 MeV
thus
(mn-mp)/me=2.530987199 ± .000001 MeV
and
(mn-mp)/me :: ln(4*pi) = 0.999 985 36 ± 0.000 000 4
As Hans says, the important point is that the agreement is of 99.998 5 %. The one-sigma adjustment is not important because the explerimental precision is a lot better. But this thread stresses that reaching the empirical bar of 99.99% in a simple formula in not easy.
Walter Smilga has rewritten his justification of Wyler's approximation of the fine structure constant in a nice clean article:
Probing the mathematical nature of the photon field
Walter Smilga
The mathematical content of the interaction term of quantum electrodynamics is examined under the following assumption: It is presumed that the apparent degrees-of-freedom of the photon field reflect the kinematical degrees-of-freedom of the two-particle state space of massive fermions, rather than independent degrees-of-freedom of the photon field. This assumption is verified by reproducing the numerical value of the fine-structure constant.
http://arxiv.org/abs/0901.4917
Of course I see everything through the lens of what I'm doing. So I see the above as evidence that in understanding the color force, one should do something similar with gluons. My recent paper analyzes the mesons in terms of what happens to the quarks, pretty much ignoring the gluons. And it also finds that things turn out simpler than expected.
http://foros.astroseti.org/viewtopic.php?t=4529&postdays=0&postorder=asc&start=180
legna said:
franc said:
Entonces Legna, (perdona mi ignorancia) ¿qué significa la cifra resultante de 522?
saludos
Existen, como sabes, 5 grupos excepcionales ( a veces los llamo especiales ) de Lie y son:
[tex]\[<br /> E8,E7,E6,F4,G2\][/tex]
[tex]\[<br /> dim(E8)=248\][/tex]
[tex]\[<br /> dim(E7)=133\][/tex]
[tex]\[<br /> dim(E6)=78\][/tex]
[tex]\[<br /> dim(F4)=52\][/tex]
[tex]\[<br /> dim(G2)=14\][/tex]
En el grupo excepcional [tex]\[<br /> E8\][/tex] están contenidos los otros 4 grupos excepcionales de Lie.
Este grupo [tex]\[<br /> E8\][/tex] tiene 240 raíces no nulas, número que es el producto
de los 5 primeros términos de la sucesión de Fibonacci.
[tex]\[<br /> 240=1\times2\times3\times5\times8\][/tex]
[tex]\[<br /> dim(E8)+dim(E7)+dim(E6)+dim(F4)+dim(G2)=\Omega\][/tex]
[tex]\[<br /> \Omega+(8-5-3-2-1)=522\][/tex]
Saludos
legna said:
La tabla de caracteres del grupo [tex]\[<br /> E8\][/tex] se compone de una matriz de [tex]\[<br /> 453060\times453060\][/tex]
http://gaussianos.com/category/noticias/page/3/
[tex]\[<br /> \frac{\pi^{5}}{120}\][/tex] es el factor de volumen de una hiperesfera de 10 dimensiones
http://es.wikipedia.org/wiki/3-esfera
Momento magnético anómalo del electrón
Límite del error experimental máximo:
[tex] \[<br /> 1+\frac{\Omega+(\frac{\pi^{5}}{120})^{-1}}{453060}=1+\frac{\alpha}{2\pi}+\frac{2\alpha^{2}}{3}(\frac{\alpha}{2\pi})-\frac{4}{3}(\frac{\alpha}{2\pi})^{2}\][/tex]
http://en.wikipedia.org/wiki/Anomalous_magnetic_dipole_moment
Saludos
http://foros.astroseti.org/viewtopic.php?t=4529&postdays=0&postorder=asc&start=210
Hola
legna said:
legna said:
[tex]\[<br /> (\frac{m_{e}}{m_{e}}+\frac{m_{\mu}}{m_{e}}+\frac{m_{\tau}}{m_{e}})\approxeq(2^{7}+\frac{1}{\sqrt{2^{7}}})^{-1}(\frac{m_{W-}}{m_{e}}+\frac{m_{W-}}{m_{e}}+\frac{m_{W-}}{m_{e}})\][/tex]
[tex]\[<br /> (\frac{m_{e}}{m_{e}}+\frac{m_{\mu}}{m_{e}}+\frac{m_{\tau}}{m_{e}})\approxeq(\alpha^{-1}(M_{Z})-\sin(\frac{2\pi}{6}))^{-1}(\frac{m_{W-}}{m_{e}}+\frac{m_{W-}}{m_{e}}+\frac{m_{W-}}{m_{e}})\][/tex]
[tex]\[<br /> m_{e}=\][/tex] masa del electrón
[tex]\[<br /> m_{\mu}=\][/tex] masa del muón
[tex]\[<br /> m_{\tau}=\][/tex] masa del tauón
[tex]\[<br /> m_{W-}=\][/tex] masa del bosón W con carga negativa -1= 80,398 Gev
[tex] <br /> \[<br /> \alpha^{-1}(M_{Z})=128,95\][/tex] o valor de la "constante" estructura fina a la escala de unificación electrodebil o masa del bosón Z
muon-electron mass ratio
http://physics.nist.gov/cgi-bin/cuu/Value?mmusme|search_for=atomnuc!
tau-electron mass ratio
http://physics.nist.gov/cgi-bin/cuu/Value?mtausme|search_for=atomnuc!
Saludos
[tex]\[<br /> [\frac{M_{Z}}{m_{e}}-(\frac{m_{e}}{m_{e}}+\frac{m_{\mu}}{m_{e}}+\frac{m_{\tau}}{m_{e}})]=174764=\sum_{p=2}^{137}p^{2}\][/tex]
Donde los corchetes en
[tex]\[<br /> [\frac{M_{Z}}{m_{e}}-(\frac{m_{e}}{m_{e}}+\frac{m_{\mu}}{m_{e}}+\frac{m_{\tau}}{m_{e}})][/tex]
significa la función parte entera de lo que contiene
Y [tex] \[<br /> \sum_{p=2}^{137}p^{2}\][/tex] es el sumatorio del cuadrado de todos los números primos menores o iguales a 137
[tex]\[<br /> M_{Z}=91,1876\; Gev\][/tex]
[tex]\[<br /> [(\frac{M_{W}}{m_{e}}){\cos\theta_{W}}]=\sum_{p=2}^{127}p^{2}=138834\][/tex]
Recuérdese que para la inversa de la "constante" de acoplamiento electromagnética en la escala de unificación elctrodébil ( masa bosón Z ), 128,95; el número primo inmediatamente inferior a su parte entera [128,95] es el primo de Mersenne 127
[tex]\[<br /> 127=2^{7}-1\][/tex]
Saludos
Hola
legna said:
[tex]\[<br /> N_{C}(E8)+(1+\cos\theta_{W})(1^{3}+2^{3}+3^{3}+5^{3}+8^{3})=(137\cdot\ln137)^{2}\][/tex]
[tex]\[<br /> 1\times2\times3\times5\times8=240\][/tex] Cantidad de raíces no nulas del grupo E8. Los 5 primeros números de la sucesión de Fibonacci.
[tex]\[<br /> N_{C}(E8)=453060=\][/tex] Número de la matriz generadora de los caracteres del grupo E8
[tex]\[<br /> (1^{3}+2^{3}+3^{3}+5^{3}+8^{3})=[\sqrt{N_{C}(E8)}]=[\sqrt{453060}]=673\][/tex]
Hola
legna said:
[tex]\frac{1}{\ln(\frac{\alpha^{-1}-21\varphi}{2})}=\frac{\pi^{4}}{384}[/tex]
Donde Pi^4/384 es la densidad de enpaquetamiento de hiperesferas en dimensión 8. Grupo E8.
http://mathworld.wolfram.com/HyperspherePacking.html
Alpha= constante estructura fina= (137,035999084...)^-1
Phi= 1+SQR(5) /2 = número aureo= 1,618033989...
Hola
legna said:
[tex]\[<br /> (\frac{m_{PK}}{m_{e}})^{2}\cdot\varphi\cdot\cos(2\pi/10)\approxeq\alpha^{-21}\][/tex]
[tex]\[<br /> m_{PK}=\][/tex] masa de Planck= 2.176 44 x 10E-8 kg
http://physics.nist.gov/cgi-bin/cuu/Value?plkm|search_for=universal_in!
[tex] \[<br /> m_{e}=\][/tex] masa del electrón= 9.109 382 15 x 10E-31 kg
http://physics.nist.gov/cgi-bin/cuu/Value?me|search_for=atomnuc!
[tex]\[<br /> \alpha^{-1}=137,035999084\][/tex]
[tex]\[<br /> \varphi=\frac{1+\sqrt{5}}{2}\][/tex]= límite del cociente entre
2 términos consecutivos de la sucesión de Fibonacci.
[tex]\[<br /> 21=1\times3\times7\][/tex]= septimo término de la sucesión de Fibonacci
1, 2, 3, 5, 8, 13, 21,...
[tex]\[<br /> [\alpha^{-1}]=137\][/tex]
[tex]\[<br /> [\alpha^{-1}]=137=2^{2}-1+2^{3}-1+2^{7}-1\][/tex]
Saludos
Hola
legna said:
[tex]\[<br /> \ln((\frac{\ln\ln\varphi}{\sum_{p}^{137}1/P}+137)/21)\approxeq\sum_{p}^{137}1/p\][/tex]
Donde: [tex]\[<br /> \sum_{p}^{137}1/p=1,872603466...\][/tex] es el sumatorio del inverso de los números primos menores o iguales a 137
[tex] \[<br /> \varphi=\frac{1+\sqrt{5}}{2}=1,618033989...\][/tex]
Hola
legna said:
[tex] \[<br /> (\frac{M_{Z}}{m_{e}})(\frac{\alpha}{2\pi})=\frac{m_{\mu}}{m_{e}}a_{\tau}a_{e}\][/tex]
[tex] \[<br /> m_{Z}=91,1876\]<br /> $\: Gev$[/tex]= 1.625566473 E-25 Kg
[tex] \[<br /> m_{e}=9.10938215E-31\: Kg\][/tex]
[tex] \[<br /> \alpha=1/137,035999084\][/tex]
[tex]\[<br /> a_{\tau}\][/tex]= momento magnético anómalo del tau=[tex]\[<br /> \frac{g-2}{g}\][/tex]=[tex] \[<br /> 1.00117721\][/tex]
The tau lepton anomalous magnetic moment
http://arxiv.org/abs/hep-ph/0702026
[tex]\[<br /> a_{e}=\frac{g_{e}-2}{g_{e}}=1.00115965218\][/tex]= momento magnético anómalo de electrón.
http://physics.nist.gov/cgi-bin/cuu/Value?ae|search_for=atomnuc!
[tex] \[<br /> m_{\mu}=1.8835313E-28\: Kg\][/tex]=masa del muón
Hola
legna said:
legna said:
http://img522.imageshack.us/img522/8949/27nx3mz9.jpg
[/URL]
Espacio de 10 dimensiones ( 9 espaciales y una temporal )
6 dimensiones enrolladas-compactadas.
http://img224.imageshack.us/img224/9769/29pm8.jpg
[/URL]
http://foros.astroseti.org/viewtopic.php?t=4529&postdays=0&postorder=asc&start=165
Hola
legna said:
http://img385.imageshack.us/img385/4326/30ya8.jpg
Masa de la Tierra= 5,9736E 24 Kg
Hola
legna said:
exp(137 + 2Phi) X Tiempo de Planck= Edad del Universo=
13700 millones años= 13700 x 1E6 x 365 x 24 x 60 x 60= 4,320432E 17 segundos
Phi= (1 + SQR(5) )/2= numero aureo= 1,618033989...
exp( 137 + 2Phi ) = 8.012176286E 60
Tiempo de Planck= 5,3912 E -44 segundos
http://es.wikipedia.org/wiki/Tiempo_de_Planck
Good is the architect of Universe
Esto se pone interesante con la colaboración de todos :lol:
Cabibbo–Kobayashi–Maskawa matrix
In the Standard Model of particle physics, the Cabibbo–Kobayashi–Maskawa matrix (CKM matrix, quark mixing matrix, sometimes also called KM matrix) is a unitary matrix which contains information on the strength of flavour-changing weak decays. Technically, it specifies the mismatch of quantum states of quarks when they propagate freely and when they take part in the weak interactions. It is important in the understanding of CP violations. A precise mathematical definition of this matrix is given in the article on the formulation of the standard model. This matrix was introduced for three generations of quarks by Makoto Kobayashi and Toshihide Maskawa, adding one generation to the matrix previously introduced by Nicola Cabibbo. This matrix is also an extension of the GIM mechanism, which only includes 2 of the 3 current families of quarks
Perdón, señores, se me olvido el link de la cita
http://en.wikipedia.org/wiki/Cabibbo–Kobayashi–Maskawa_matrix
[tex]\[<br /> \theta_{C}=\][/tex] Ángulo de Cabibbo
[tex]\[<br /> \theta_{W}=\][/tex] ángulo mezcla electrodebil
[tex]\[<br /> \theta_{W}=\frac{4\varphi\theta_{C}}{3}\][/tex]
[tex] \[<br /> \frac{20\pi\alpha}{3^{2}}\approxeq\sin^{2}\theta_{C}=(0,2257)^{2}\][/tex]
[tex]\[<br /> 1+\sin(3\theta_{C})+2\cdot3^{2}\approxeq\frac{1}{\sin^{2}\theta_{C}}\][/tex]
Ángulo áureo= [tex]\[<br /> \frac{2\pi}{\varphi}\][/tex]
[tex]\[<br /> \frac{\tan(2\pi/\varphi)}{2\cdot3^{2}}\approxeq\mid V_{cd}\mid^{2}=(0,2256)^{2}\][/tex]
[tex] \[<br /> \left(\frac{1}{\mid V_{ud}\mid\cdot\mid V_{us}\mid\cdot\mid V_{ub}\mid}+\frac{1}{\mid V_{cd}\mid\cdot\mid V_{cs}\mid\cdot\mid V_{cb}\mid}+\frac{1}{\mid V_{td}\mid\cdot\mid V_{ts}\mid\cdot\mid V_{tb}\mid}\right)^{-1}=\pi^{4}+\frac{2}{5^{2}}\][/tex]
Saludos:smile:
[tex]\left(\sum^{137}_{p=2}p^{2}\right)\frac{\sqrt{8}}{\pi}=\frac{M_{W}}{m_{e}}[/tex]
Sum over all prime numbers <= 137
[tex]M_{W}=80,398 Gev[/tex]
Gravitational radiation from binary systems
http://en.wikipedia.org/wiki/Gravitational_waves
[tex]P=\frac{32\cdot G_{N}^{4}\cdot M_{\odot}^{2}\cdot M_{\oplus}^{2}\cdot(M_{\odot}+M_{\oplus})}{5c^{5}d}\cdot\frac{1}{(1-e^{2})^{\frac{7}{2}}}\cdot(1+\frac{73e^{2}}{24}+\frac{37e^{4}}{96})$[/tex]
[tex] P=\frac{32\cdot G_{N}^{4}\cdot M_{\odot}^{2}\cdot M_{\oplus}^{2}\cdot(M_{\odot}+M_{\oplus})\cdot t_{year}}{5c^{5}d}\cdot\frac{1}{(1-e^{2})^{\frac{7}{2}}}(1+\frac{73e^{2}}{24}+\frac{37e^{4}}{96})=M_{pk}\cdot c^{2}\cdot\sqrt{10}\cdot\left[\frac{1}{(1-e^{2})^{\frac{7}{2}}}\cdot(1+\frac{73e^{2}}{24}+\frac{37e^{4}}{96})\right]^{2}$[/tex]
[tex]M_{\oplus}=5,9722\cdot10^{24}Kg$\medskip{}[/tex]
[tex]M_{\odot}=1,98842\cdot10^{30}Kg$ \medskip{}[/tex]
Where :
[tex]A.U, d=1,49597870700\cdot10^{11}m$\medskip{}[/tex]
[tex]t_{year}=315581449,76\, s$\medskip{}[/tex]
[tex] M_{pk}=[/tex] Planck'mass = 2,17644 E-8 Kg
[tex] e=1,6710218\cdot10^{-2}$\medskip{}[/tex] ( Earth's Orbit eccentricity )
Particle Physics Booklet (rpp-2008-booklet ), pág 6 :http://pdg.lbl.gov/2008/download/rpp-2008-booklet.pdf
Efecto casimir: energía del vacio entre 2 placas cuadradas conductoras de area L y a una distancia d
[tex] \[<br /> E_{vacio\; Casimir}=-\frac{\pi^{2}\hbar cL^{2}}{720d^{3}}\][/tex]
Fuerza de Casimir:
[tex]\[<br /> F_{vacio\; Casimir}=\frac{\pi^{2}\hbar cL^{2}}{240d^{4}}\][/tex]
Presión de Casimir:
[tex] \[<br /> P_{vacio\; Casimir}=\frac{\pi^{2}\hbar c}{240d^{4}}\][/tex]
http://en.wikipedia.org/wiki/Casimir_effect
Investigation into Compactified Dimensions: Casimir Energies and Phenomenological Aspects
http://arxiv.org/abs/0901.3640v1
Página 31
[tex] \[<br /> E_{vacio\; Casimir}=-\frac{\hbar cL^{2}}{[\frac{240}{\alpha^{-1}\pi^{3}}+\ln(\frac{M_{PK}}{m_{e}})]\sqrt{2}d^{3}}=-\frac{\pi^{2}\hbar cL^{2}}{720d^{3}}\][/tex]
Donde: [tex]\[<br /> \alpha^{-1}=137,035999084\][/tex]
[tex]\[<br /> M_{PK}=2,17644E-8Kg\][/tex]
[tex]\[<br /> m_{e}=9,10938215E-31Kg\][/tex]
http://foros.astroseti.org/viewtopic.php?p=77266#77266
I noticed a classical argument from Nigel
http://nige.wordpress.com/carl-brannen-and-the-koide-formula-how-to-derive-the-koide-formula/
about Koide-ish square roots, which could be of some value: Simply consider the total kinetic energy of the mass center of a system of three particles and compare it with the sum of the energies of the components.
[tex] E_{CM}=\frac 12 {{ (\sqrt{2E_1m_1}+ \sqrt{2E_2m_2}+\sqrt{2E_3m_3})^2} \over m_1+m_2+m_3}[/tex]
and compare it with the total Energy [itex]E_T=E_1+E_2+E_3[/tex]. <br /> <br /> In the simplest "dirac delta" partition where [itex]E_1=E_2=E_3[/itex]<br /> we have that<br /> <br /> [tex] { E_{CM} \over E_T} = \frac 13 {{ (\sqrt{m_1}+ \sqrt{m_2}+\sqrt{m_3})^2} \over m_1+m_2+m_3}[/tex]<br /> <br /> and then Koide "3/2" is the condition that the CM energy is one half of the total, free, kinetic energy. Funny.Disclaimer: I am not sure if I am being careful or standard when calling [itex]E_{CM}[/itex] to this energy.<br /> Edit: A guess is that some related but quantum conditions could be found by playing with the available phase space for scattering, using golden rule and all that.[/itex]
Of course, the total energy in an arbitray reference frame is the energy of the CM in this frame plus the ("rotational?") kinetic energy in the CM reference frame. No jokes about Lubos website, please :smile:
So Koide is the relationship for masses in a frame where
- the kinetic energy of all the particles is the same, and
- The "traslational" energy of the CM in this frame is equal to the "rotational" energy of the particles in the CM frame.
- all the particles travel in the same line and orientation. (this is, to take the positive square roots and one dimensional sum)
Hi Alejandro,
This is interesting. I'm going to have to play around with it as I'm not very intuitive about relativistic mechanics.
Marni and I just finished up the FFP10 conference in Perth, Australia. It went very well. I had a couple grad students ask for copies of my latest paper, which puts the Koide relation in the context of spin path integrals:
http://www.brannenworks.com/Gravity/EmergSpin.pdf
One of the talks was about quasars. It seem that there's evidence that they have intrinsic redshifts. They're born with very high redshifts, and then the redshifts decrease, in quantum jumps. The jumps correspond to changes in z of about 0.229, pretty close to the 2/9 in the Koide formula.
So I typed up a few extra PPT slides and wrote up an outline of a theory of gravity where gravity becomes repulsive inside of a black hole so that instead of having a single event horizon, they end up with a series of shells where their gravity is neutralized. The basic idea is to describe gravity as a vector field (see The River Model of Black Holes), and describe the vector length as a Wick rotated boost of something proportional to the gravitational flux. I'll post something at my blog when I get the time.
Actually, it is classical. It is not easy to read across Nigel's blog, it is not very concrete and it deviates from the path or misses the target very easily. But it is really straightforward, what he does in the deep, even without knowing it, is to ask for classical quantities where the angle with the vector [tex]\vec \sqrt m_i[/tex] is relevant. And he finds one.
Let me rewrite it in one line:
[tex] {E_{CM} \over E_{CM} + E_{Rot}}={E_{CM} \over E_{Tot}}=<br /> { \frac 12 (\sum m_i) ({\sum m_i \sqrt {2 E_i/m_i}\over \sum m_i})^2 \over \sum E_i}<br /> = { ({\sum \sqrt m_i \sqrt {E_i} })^2 \over \sum m_i \sum E_i}<br /> = \Big({ \vec m^{1/2} . \vec E^{1/2} \over |\vec m^{1/2}| |\vec E^{1/2}| }\Big)^2[/tex]
This is a general formula for freshman physics, and then if we put all the three energies equal it simplifies to
[tex]{E_{CM} \over E_{Tot}}=<br /> { E_{1/3} ({\sum \sqrt m_i })^2 \over 3 E_{1/3} \sum m_i } = \frac 13 {({\sum \sqrt m_i })^2 \over \sum m_i }[/tex]
And thus Koide's happens to be the mass restriction that allows necessary conditions to find a frame where simultaneusly [itex]E_{CM}=E_{Rot}[/itex] and [itex]E_1=E_2=E_3[/itex]. Note that [itex]E_{Rot}[/itex] in classical kinematics is frame-invariant.
With a little more of work, using the approximation v << c, it should be possible to do the same arguments in the relativistic kinematics of 3 body decay. Also, It could be seen not as an explanation of the origin of the relationship but as a consequence with kinematic repercusions.
Good to hear of it.
Of course, if all the three masses are equal, then it is the kinetic energy triple the one which holds Koide's relationship. Amusing.
The only thing I am worried here is about taking the positive sign of the square root for all the three velocities; this is an extra requirement to the reference frame, to see all the three particles in the same direction. And also that they are all the three in the same line. On other hand, the "different sign" case is the one used by Carl in the neutrinos.
