Alternating current : Solving for low-pass filter
The discussion focuses on solving for the output voltage of a low-pass filter circuit with an AC input of 10 mV. The user attempts to calculate the output voltage as a function of frequency, using relevant equations for impedance and current. They express uncertainty about applying Kirchhoff's law due to current splitting at the resistor-capacitor junction. The suggestion is made to treat the circuit as a voltage divider by expressing the impedance of the resistor and capacitor as complex numbers. The conversation emphasizes the importance of considering the output connected to a high resistance to simplify calculations.
rohanprabhu
Q] The figure below shows a typical circuit for a low-pass filter. An AC input V_i~=~10~mV is applied at the left end and the output V_o is received at the right end. Find the output voltage as a function of \nu~(\textrm{frequency})
http://img252.imageshack.us/img252/3724/lowpassfilterrb2.jpg
well.. maybe:
<br /> Z = \sqrt{R^2 + (X^2_C - X^2_L)}<br />
<br /> i = i_o sin(\omega t + \phi)<br />
<br /> \phi = tan^{-1}\left(\frac{X_C - X_L}{R}\right)<br />
Well.. I'm just thinking that the voltage across the capacitor will be the output voltage. I found out the current in the circuit using the equations and it is coming to be:
<br /> i = i_o sin\left(\omega t + tan^{-1}\left(\frac{10^6}{2\pi \nu}\right)\right)<br />
This is the current in the first loop. I thought of using Kirchoff's law first.. but i have no idea how to do this in this case as the current will split at the resistor-capacitor junction.
Any help is appreciated. Thanks.
I think you can assume that the output will be connected to a very high resistance (such as an oscilloscope), so there's no current going into the output.
You know how to express the impedance of R, C and the input voltage as complex numbers? then the circuit is just a voltage divider.
  • · Replies 16 ·
