Angle of the slope when the object start moving
  • Thread starter Thread starter goldfish9776
    Angle Slope
5 replies · 2K views
goldfish9776
when the object is moving , why the theta is larger than the theta(s) when the object is started moving ?
I was told that when the object is moving , the Fk will become smaller than Fs , right ? so, IMO , the theta should be larger than the theta(s) , am i right ?
tan(theta k)= Fk / N = = μ k (N) / N
tan (theta s) =Fs / N = μ s (N ) / N
angle is directly proportional to μ k and μ s
They could have written >=, but the exact border case rarely has physical relevance - no slope is perfectly flat and so on.
Sliding friction is usually smaller than static friction. Once the object starts moving, you can reduce the tilt angle and the object will continue sliding.
do u mean when the object is sliding , no matter the angle is larger than μ s or the angle is slightly smaller than μ s , the object will still sliding down the plane ?
μ s is not an angle.
There is an angle ##\theta_0## where the object starts sliding (it starts sliding for all angles larger than that, and does not start for all angles smaller than that). There is a different angle ##\theta_1 < \theta_0##, between those two angles an object that is sliding keeps sliding (forever), but won't start sliding on its own if it is at rest.
mfb said:
θ1<θ0
as you stated , why the book gave θ(when it's moving ) will bigger than θ(when it's about to move ) ?
The logic is in the other direction: if the angle is larger, it is certainly moving.
