Annihilation Operators: Prove af(a^\dagger)|n>=df(a^\dagger)/da|0>
  • Context: Graduate
  • Thread starter Thread starter Shadowz
18 replies · 4K views
Shadowz
So we all know about [tex]a[/tex] and [tex]a^\dagger[/tex].
My problem says that if [tex]f(a^\dagger)[/tex] is an arbitrary polynomial in [tex]a^\dagger[/tex] then [tex]af(a^\dagger)|n> = \frac{df(a^\dagger)}{da}|0>[/tex] where |0> is the ground state energy. How can I go about proving this?
A hint would be highly appreciated.
Thanks,
Thanks,
Since [tex]f(a^\dagger)[/tex] is a polynomial.
It suffices to show that
[tex]a (a^\dagger)^n |0\rangle = n(a^\dagger)^{n-1}[/tex]
where [tex]n = 0,1,2,\cdots[/tex]
And you know the commutator of [tex][a,a^\dagger] = ...[/tex]
Maybe I don't quite get it but you said we can assume [tex]f(a^\dagger)[/tex] be [tex](a^\dagger)^n[/tex]
But then if I consider the LHS, will that operator raises |n> to |2n-1>? (each [tex]a^\dagger[/tex] would raise |n> to |n+1>) but the RHS has |0>.
Thank for your help,
The formula
[tex] af(a^\dagger)|n> = \frac{df(a^\dagger)}{da}|0>[/tex]
Is written very sloppily. It should be written as
[tex] af(a^\dagger)|n> = f'(a^\dagger)|0>[/tex]
Why? Because [tex]f(a^\dagger)[/tex] does not depend on [tex]a[/tex].
Thank you for pointing that out.
So is it correct to consider
[tex]a(a^{\dagger})^{n-1}(a^{\dagger})|n> = \sqrt{n}a(a^\dagger)^{n-1}|n+1>[/tex]
and then I have to find a way to do [tex]a|n+1> = \sqrt{n}|n>[/tex] in order to get to the form [tex]n(a^\dagger)^{n-1}[/tex] but the RHS has |0> so I don't know how to get it.
Thanks,
Why not start with something like [tex][A,BC]=A[B,C]+[A,B]C[/tex], thus
[tex][a,(a^\dagger)^n]=a^\dagger [a,(a^\dagger)^{n-1}]+[a,a^\dagger](a^\dagger )^{n-1}=\ldots ...[/tex]
in order to compute [tex][a,(a^\dagger)^n][/tex]
If my algebra is correct then [tex][a,(a^\dagger)^n] = (a^\dagger)^{n-1} +(n-1)(a^\dagger)^{n-1} = n(a^\dagger)^{n-1}[/tex]Should I try to operate both sides with |0>?
So, your algebra can be generalized to
[tex][a,f(a^\dagger)]=f'(a^\dagger)[/tex]
Don't you think there is a mistake on the LHS of the equation you want to prove? Don't you think there should be |0> there rather than |n>? The RHS does not depend on n, how the LHS can?
Yes. So the RHS is close, but then we still have to break the commutator and somehow put in n and 0.
By the way, thank you!
and so I rearrange it to be
[tex]af(a^\dagger) = f(a^\dagger)a + f'(a^\dagger)[/tex]
but then how can we prove that [tex](f(a^\dagger)a + f'(a^\dagger))|n> = f'(a^\dagger)|0>[/tex]?
I am 95% sure that the expression I try to show is correct because it also says that " |0> is the ground state energy and |n> is any harmonic oscillator state."
PS: Although I think it would make a lot of sense to have |0> on both side since [tex]f(a^\dagger)a|0> =0[/tex]
Just think of n=1000 and [tex]f(x)\equiv 1[/tex]
Then on LHS you will have 999th excited state a|n>, on the LHS you will have just 0 (because f'=0 in this case).
Yes that is exactly what my 3rd post said (or not exactly, but similar idea)
Now I think that [tex]\frac{df(a^\dagger) }{da}[/tex] can make a difference.
Isn't there a relation between n and the degree of f?
It seems to be true for any polynomial (of degree = n)
if you take |0> on each side of the equality.
You're right. I got it. Thank all of you for help!
Hi,
How can I write [tex]\Delta x[/tex] and [tex]\Delta p[/tex] as operators? I want to show that [tex]\Delta x|\alpha> = c\Delta p|\alpha>[/tex] where [tex]|\alpha>[/tex] is coherent state.
I feel like I have to write x and p in terms of annihilation operators, but I always think that [tex]\Delta x[/tex] and [tex]\Delta p[/tex] are numbers, not operators.
Thanks,
It is not clear by itself what [itex]\Delta x,\Delta p[/itex] can mean in this context. One can try to guess their meaning, but it is not evident.
So all I try to do was to show that the coherent state has minimum uncertainty equally distributed between x and p. And the hint given was to show that [tex]\Delta x |\alpha> = x\Delta p |\alpha>[/tex], and thus it makes me think that I should treat [tex]\Delta x[/tex] and [tex]\Delta p[/tex] as operators rather than numbers.
For minimum uncertainty you need to calculate [tex]\langle \alpha|(\Delta x)^2|\alpha\rangle=\langle\Delta x\alpha|\Delta x\alpha\rangle[/tex], where [itex]\Delta x=x-\langle\alpha| x|\alpha\rangle .[/itex] Now you can plug in your anihilation and creation operators. The same for [itex]\Delta p[/itex].
