Antimatter and matter canceling out
  • Context: High School
  • Thread starter Thread starter Lunct
    Antimatter Matter
Antimatter and matter undergo a process known as "annihilation," resulting in the creation of other particles and electromagnetic radiation, rather than simply ceasing to exist. This process adheres to the law of conservation of energy, as energy and mass are conserved through the transformation into new particles and radiation. A common misconception is that antimatter consists of negative mass, which is incorrect. The phenomenon of pair production allows photons to convert back into matter under specific conditions, such as the presence of a heavy nucleus.
  • Understanding of antimatter and its properties
  • Familiarity with the concept of annihilation in particle physics
  • Knowledge of the conservation of energy and momentum
  • Basic grasp of pair production and its requirements
  • Research the principles of particle annihilation and its implications
  • Study the conservation laws in physics, focusing on energy and momentum
  • Learn about pair production and its role in particle physics
  • Explore the properties and applications of antimatter in modern science
Physicists, students of particle physics, and anyone interested in the fundamental concepts of antimatter and energy conservation.
Lunct
Antimatter and matter cancel each other out. What does this mean? Do the particles just cease to exist? Does this go against the law of the conservation of energy?
HELP
You would first have to learn what is meant by Antimatter. For instance, it does not consist of Negative Mass (that's a popular misconception).
As usual, Wiki, although not a definitive source, can be a good place to start. You should read that link.
I wouldn't say that they "cancel each other out". The process is called "annihilation", and always results in the creation of other particles and/or EM radiation.
Nope. Energy and mass are fully conserved through the creation of other particles and radiation which carry away whatever mass and energy the original particles had.
I think I understand, the particles turn into energy, and the amount of energy is in accordance the equation E=mc^2.
That would make sense.
Pop science has to over simplify everything...
Lunct said:
but is it possible for photons to turn back into matter?
Yes.
Google for "pair production" - a sufficiently energetic photon in the vicinity of a heavy nucleus can turn into an electron-positron pair.
(The heavy nucleus is needed because without it there's no way of conserving both energy and momentum).
Nugatory said:
Yes.
but wouldn't the positron and electron want to collide together as they have opposite charges and annihilate?
Not if they have sufficient resulting Kinetic Energy to take them apart ( aka Escape Velocity).
They might, and then you get a pair of photons out. That case looks from the outside as if the nucleus absorbed the incoming photon and immediately emitted two less energetic photons. However, if the electron and positron have enough kinetic energy (the incoming photon has substantially more than two electron masses worth of energy, by ##E=mc^2##) then the two particles will fly apart more quickly than the attractive force can pull them together.
makes sense, you are very good at explaining things.
Thanks
  • · Replies 21 ·
13K
  • · Replies 21 ·
  • · Replies 35 ·
