Fixing a Rusted Snowboard Edge with REDOX Reactions
A snowboard's rusted edge is caused by oxidation from air oxygen and humidity, not sunlight. While redox reactions can theoretically reverse corrosion, they won't restore the snowboard's original properties, such as shape and strength. It is recommended to consult a professional service to assess the damage and determine if the snowboard can be salvaged. Attempting to fix it through a DIY redox reaction may not yield satisfactory results. Seeking expert advice is the best course of action for restoring the snowboard.
ashsully
Hi all,
I'm fairly new to physics forums so cut me some slack for being a noob. I've just noticed that my brand new snowboard's edge has rusted (oxidised). I live in Australia and it's been stored in my room receiving sunlight everyday. I'm guessing this probably caused the rusted edge? Anyway, I learned about Redox reactions in chemistry and I'm thinking maybe I can fix my snowboards rusted edge by creating a Redox reaction.
I can't seem to find the exact metal the edge is made out of, but most of the info I found was that it was made from a type of steel. Therefore, if we make the snowboard's edge the oxidising agent and make it undergo reduction it will receive electrons. Would this reverse the oxidising process?
If this would reverse the oxidisation, could anyone recommend how I will go about creating this redox reaction?
Thanks in advance,
Ash
E0 values I'm guessing?
None yet[/B]
It is not the sunlight that is a culprit, but air oxygen and humidity.
Technically you are right about the corrosion being a redox process that can be reversed but it won't restore properties (shape, strength) of the steel used for the edge. You need the edge to be pretty sharp. Visit the service and ask if they can save the board, or if it has rusted beyond hope.
17K
22K
  • · Replies 19 ·
10K
