Applying Bernouilli to calculate pressures
  • Thread starter Thread starter Xengine
7 replies · 2K views
Xengine
http://imgur.com/ktfgCAL
flow rate: 0.057 m^3/s
cross sectional area of all pipes: 1.864*10^-2 m²
frictional losses inlet pipe: 1.83m
frictional losses outlet pipe: 3.66m
Asked:
pressure at inlet
pressure at outlet
necessary pumping power
Bernouilli: http://imgur.com/EEptkNX where h_A is the energy added by the pump and h_r and h_l are the losses
pumping power= q*rho*g*h
first of all, i am not sure what location they actually mean exactly by pump inlet and outlet (is it in the tank or really at the pump?)
inlet: I assumed p1 to be 0, v1=v2 and z1=0 and z2=3.05m which results in a p2 of 47.87kPa (i assumed h_A to be equal to 0, not sure if this is correct)
outlet: using the previous value as p1 now, assuming v1=v2 and z1=0 and z2=12.2m i found a p2 of 107.71 kPa
power: 0.057*1000*9.81*15.25 = 8.53kW
Apparentely, all my answers seem to be wrong. I'm fairly sure that I am making a critical mistake for the pressure calculations, but I really don't understand what could be wrong in my power calculation.
Thanks in advance :)
The pressure at the top of the water in the lower tank is atmospheric (zero gauge), and the velocity at the top of the water in the lower tank is zero. Between the lower tank and the pump inlet, there is a vertical distance, there is a equivalent vertical distance to allow for the frictional pressure loss, and there is a water velocity in the pipe. You need to use these to get the pressure at the very inlet of the pump (which will be less than zero gauge).
What value do you get for this pressure at the pump inlet (either in absolute or gauge pressure)?
Chet
Thank you for your reply!
from
0+0+0-1.83 = p2/(1000*9.81)+3.05+3.0579^2/(2*9.81) (i calculated the speed by dividing the flow by the cross sectional area: 0.057/(1.864*10^-2)
i find p2= -52548.18 Pa
I wonder, if this is correct, if I have to substitute this value in absolute value or not for p1 in the calculation of the outlet pressure...
Since when i use the negative value further i find from
-51548.18/(1000*9.81)+ 0 - 3.66 = p2/(1000*9.81) + 12.2
that p2= -208134.78 Pa which is also negative and i feel like it should be a positive value in the discharge pipe...
from
This looks OK so far (I didn't check the arithmetic). This is the gauge pressure at the inlet.
If you are trying to get the pressure at the outlet of the pump, the signs on the 12.2 and the 3.66 are wrong. You should be working your way down from the surface of the water in the upper tank, which is likewise at 1 atm.
Chet
P.S. PLEASE DO NOT DO DUPLICATE POSTS AGAIN. IT IS CONTRARY TO PHYSICS FORUMS RULES.
Chet
Allright, when changing the signs of both the 3.66 and 12.2, i find an outlet pressure of 31229.22 Pa.
Do you have any idea what I am doing wrong with calculating the necessary power? Do i have to work with only the highest head of 12.2m and not with the sum of both maybe?
Thanks!
P.S.: sorry for cross posting, won't happen again.
Thanks!
OK. Using the pump elevation at the datum for potential energy:
0 + 0 + 12.2 = p/(1000*9.81) + v2/2g + 0 -3.66
Chet
Chet
Ah, i forgot that the velocity wasnt the same on both sides apparentely, so i find 150991.10 Pa using your equation.
I also think i know what I'm doing wrong for the power... I think I have to add both losses to the the total head, is that correct?
so P= (3.05+12.2+3.66+1.83)*0.057*1000*9.81=11597.19 watt
The pump power is the pressure increase across the pump times the volumetric flow rate.
